Old 07-28-2003, 04:54 PM   #1
orndog
Member#: 34670
If she smokes she
pokes
Default Hella Supertones help!
Tried a search, got confuseder
Okay, are our horns "positively" or "negatively" connected to the "horn push". I think negatively. The diagram shows power run from the battery, but then also to another "+". 2 power wires?
orndog is offline   Reply With Quote
Old 07-28-2003, 06:59 PM   #2
saggioWRX
Member#: 18994
08 GTS
05 AW STi
The wire going to our stock horns is a positive wire. Just hook this wire to the Hella's and then ground the negative wire to a bolt in the same area. Also, you don't need the relay! Just hook it up like the factory horns are and you'll be on your way to LOUD ass horns!!
Dave
saggioWRX is offline   Reply With Quote
Old 07-28-2003, 07:13 PM   #3
orndog
Member#: 34670
If she smokes she
pokes
Thanks. I did that, but they don't work. Neither do my factory ones now. I had the neg cable sisconnected when I was working on it, and my fuse is still good!
Old 07-28-2003, 07:29 PM   #4
saggioWRX
Member#: 18994
08 GTS
05 AW STi
On the back of the Hellas theres a silver connection, and a brass conection. Did you hook these up right?
Brass = positive
Silver = negative
Hmmmm Wierd!
Old 07-28-2003, 07:53 PM   #5
orndog
Member#: 34670
If she smokes she
pokes
Hella's pdf doesn't mention a difference I'll go check though!
Oh, and the relay clicks when I lock/ unlock the doors with the remote, there's just no beep.
Old 07-28-2003, 08:52 PM   #6
orndog
Member#: 34670
If she smokes she
pokes
Some how, I guess I had them both hooked up backasswards. The posts are both silver though.
Old 07-28-2003, 09:07 PM   #7
orndog
Member#: 34670
If she smokes she
pokes
BTW I found these:
http://www.griotsgarage.com/pdfs/77573.pdf
so much better than what they send with the horns.
Old 07-29-2003, 10:53 AM   #8
makofoto
Member#: 25243
2006 Legacy Outback
My understanding is that if you don't use the relay and power directly to the battery they won't be as loud as they could be ....
makofoto is offline   Reply With Quote
Old 07-29-2003, 01:06 PM   #9
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Yep - I can vouch for that!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 07-29-2003, 02:22 PM   #10
bemani
Member#: 5673
2002 WRX/2005 LGT
09 Ducati M696/ZX6R
Maybe it is so for the old rs, but on the WRX, the stock relay has more than enough power for the hella. The stock horn relay is good for IIRC 15A.
bemani is online now   Reply With Quote
Old 07-29-2003, 08:49 PM   #11
Jester
Member#: 16207
2002 WRX Wagon
Dirt
Smile
I used the supplied relay and retained the stock horn on the driver's side for extra effect. Essentially, your using one of your original horn's leads to switch the relay for the Hellas, which are in turn hooked directly to the battery and to another ground.
I didn't try to hook it up with the stock relay only, so I can't vouch for the difference between using or not using the supplied relay. I can however say that my setup definately gets the attention cell phone talking soccer moms who aimlessly meander their Ford Excursions all over the road, but I digress...
Jester is offline   Reply With Quote
Old 07-30-2003, 09:58 AM   #12
orndog
Member#: 34670
If she smokes she
pokes
As in the pdf I posted a link to above, Hella says don't worry about the relay in our style of wiring. Has somebody with a newer Suby tried it both ways?
Old 07-30-2003, 07:47 PM   #13
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Thats exactly what I did, but I used the drivers side horn for the relay and left the one in the middle (so I have a triangle of horns in the front of my car). Wired it directly to the battery. Anyone who has heard my alarm go off can vouch how loud it is
DDMan is offline   Reply With Quote
Old 07-31-2003, 07:22 AM   #14
orndog
Member#: 34670
If she smokes she
pokes
I might get energetic and try that.
Old 07-31-2003, 12:42 PM   #15
rockt104
Member#: 19111
Default hijack
One question: I know they are loud...but are they deep sounding? Or do they sound like a normal car horn, just very loud? Maybe try to rate them 1 = stock and 10 = Goliath from Knight Rider.
Kev
rockt104 is offline   Reply With Quote
Old 07-31-2003, 12:56 PM   #16
makofoto
Member#: 25243
2006 Legacy Outback
from inside the car they sound strangely puny ... but in front they are loud ... but it's not a bassey sound ... a bit thin, kind of shrill ... I would have left my regular horns in also if I was doing it again ... there was a fellow walking along the edge of the freeway ... I gave him a warning blast from maybe a good 30/40 yards ... and he JUMPED!
Don't know Goliath ...
Old 07-31-2003, 01:05 PM   #17
orndog
Member#: 34670
If she smokes she
pokes
They project forward in a fairly narrow band I think. Best for highway use. It's a noise that will send chills up your spine.
Old 07-31-2003, 03:17 PM   #18
netZ
Member#: 5743
2007 Kia Optima
gold brick
don't know Goliath from Knight Rider?
http://www.fortunecity.com/lavender/...eason2/218.htm
it's one bad mofo truck!
netZ
netZ is offline   Reply With Quote
Old 07-31-2003, 04:00 PM   #19
rockt104
Member#: 19111
AMEN, badass...I remember that episode so well, I was truly scared for Kitt.
netZ
Old 08-01-2003, 02:49 AM   #20
Penphoe
Member#: 269
Ah, yes! A tri-tone setup! I did the same thing with my RS - kept the stock horn and used its voltage to trigger the relay which turns on my other horns. My other two horns aren't Supertones though, they're WRX horns given to me by my friend! Not as loud as the Supertones, but still very annoying out front hearing three dissanant tones.
LaterZ!
Darren!!
Old 08-02-2003, 02:05 AM   #21
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Originally posted by orndog
BTW I found these:
Why do they have them wired in series. That would just increase the load and equal less output.
They should be wired in parallel.
..or does this not affect the horns as it would a pair of speakers?
moogoob is offline   Reply With Quote
hella supertone help!? smithrcing17 Electrical & Lighting 8 04-07-2009 04:48 PM
Hella Supertones help. Jcrite8987 Newbies & FAQs 23 07-29-2008 02:29 AM
Help with hella supertones/hella foglight install.... Super_HKS North West Impreza Club Forum -- NWIC 18 04-24-2008 10:12 AM
hella supertone help cleofis Bay Area Impreza Club Forum -- BAIC 2 06-19-2004 08:46 PM
Hella supertones install help? BOB YOUNG General Forum Archive 2 04-03-2001 02:32 PM
Message Board Statistics All times are GMT -4. The time now is 03:18 AM.
