Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-28-2003, 06:09 PM   #1
TheWeis
Member#: 17939
2002 WRX Sedan
Default heater hose ok for oil lines?
I changed my injectors this weekend, the cover for the driver side injectors has a metal section of line to join two rubber lengths between the driver side cylinder head oil line and the line attached to the intercooler. I removed these metal injector cover plates (or whatever they are) because I don't think they really do much.
In doing this, I had to replace that oil line system, so I bought some heater/coolant hose at the hardware store. It seems more robust than the original hose and is reinforced. I just want to know if the oil will somehow degrade this hose?
Thanks
Paul
TheWeis is offline   Reply With Quote
Old 07-28-2003, 07:34 PM   #2
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Yes, it will degrade/deterioate the hose. Make sure that you get "trans fluid" or "Oil" rubber hose. Fuel MAY work, but if wouldn't use anything but oil, or transmission fluid hose.
cavymeister is offline   Reply With Quote
Old 07-28-2003, 09:45 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Have you ever seen a radiator hose that expanded like a bubble? Thats from oil. The oil makes the rubber hoses soft.
Old 07-28-2003, 11:34 PM   #4
TheWeis
Member#: 17939
2002 WRX Sedan
Default Thanks!
great, exactly what I needed. Thanks guys!
Off to a proper auto parts store then!
FS: OK New Perrin 2.4" Turbo Inlet hose RED New and New Oil line for FP Green Turbo casionerd Engine/Power/Exhaust 4 09-23-2007 02:49 PM
WTT: My T3/T4 Oil Line for your Stock Oil Line dubluv17 Private 'For Sale' Classifieds 2 07-05-2005 10:51 AM
heater hose works for oil return line? WRX Jim Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-19-2005 01:06 PM
Nylon hose fittings OK for coolant lines? scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-24-2004 10:26 PM
Is Silicone Hoses ok for intercoolers? TrizzyDizzy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-12-2004 01:36 AM
