Old 07-28-2003, 07:12 PM   #1
jackansi
Member#: 23894
'07 3.2L Audi A4
Default Hitting 100% IDC with stock turbo?
Is it really possible to hit 100% IDC on the stock turbo at 16.5psi max?
I just about freaked when I saw my UTEC log for the first time.
TIME RPM MAP MAF TPS MLP Knock O2 IGN#1 INJ#1 IGN FUEL BOOST
dig dig dig mA deg duty deg % (OL)
00848134 1486 80 103 123 00 00 -01.0 +18.6 6.0 ECU. +0.0 ECU.
00848534 2279 91 124 144 10 00 +01.7 +32.6 11.0 +20.0 +0.0 ECU.
00848934 2261 102 129 144 10 00 +00.1 +30.9 13.0 +20.0 +0.0 ECU.
00849334 2052 114 126 149 10 00 -02.0 +32.2 11.0 +24.5 +0.0 ECU.
00849734 1764 116 124 150 10 00 -00.6 +28.1 11.0 +26.6 +0.0 ECU.
00850134 1646 119 118 148 10 00 -01.0 +23.6 10.0 +28.8 +0.0 ECU.
00850534 1419 121 113 163 10 00 -02.2 +21.7 8.0 +30.0 +0.0 ECU.
00850934 1638 123 116 173 10 00 -02.0 +23.4 9.0 +28.2 +0.0 79.00
00851334 1733 124 120 182 10 00 -02.0 +24.9 10.0 +26.4 +0.0 84.00
00851734 2025 125 126 192 10 00 -02.8 +31.9 13.0 +24.0 +0.0 80.00
00852134 2295 126 131 199 10 00 -03.0 +30.2 15.0 +20.0 +0.0 80.00
00852534 2506 126 138 200 10 00 -02.8 +28.0 18.0 +19.8 +0.0 75.00
00852934 2827 128 143 199 20 00 -03.4 +25.8 21.0 +17.0 +0.7 75.00
00853334 3063 132 152 200 20 00 -04.9 +22.2 27.0 +17.0 +1.5 75.00
00853734 3346 137 164 200 30 00 -06.7 +18.2 34.0 +17.0 +1.5 75.00
00854134 3813 146 178 200 40 00 ---.- +16.5 51.0 +18.0 +1.5 80.00
00854534 4345 156 188 198 60 00 ---.- +15.6 70.0 +17.0 +1.1 80.00
00854934 4866 167 197 198 70 00 ---.- +19.6 84.0 +21.7 +0.6 80.00
00855334 5359 174 202 198 70 00 ---.- +22.0 89.0 +22.0 +0.3 80.00
00855734 5757 179 207 199 70 00 ---.- +23.0 96.0 +22.0 +0.6 80.00
00856134 6184 177 210 198 60 00 ---.- +24.4 100.0 +23.0 +0.7 80.00
00856534 6680 173 211 196 50 00 ---.- +28.2 14.0 +23.0 +0.7 80.00
00856934 6734 165 178 50 00 00 ---.- +41.4 32.0 ECU. +0.7 ECU.
00857334 6161 137 104 29 00 00 ---.- +10.6 9.0 ECU. +0.8 ECU.
00857734 5491 111 108 29 00 00 +06.4 +10.9 9.0 ECU. +0.0 ECU.
00858134 4938 92 168 138 10 00 +09.8 +18.9 35.0 +22.4 +0.5 ECU.
00858534 4050 89 173 198 10 00 ---.- -3.2 45.0 +20.8 +0.7 80.00
00858934 4368 111 188 200 30 00 ---.- +16.7 65.0 +20.6 +0.5 80.00
Thats first gear with the shift to second at the end. Hit 100% in second, and almost in 3rd before I ran out of room to run.
Also what does it mean when its just ---.- for the IDC?
Looks like the STi injectors and pump will be going in sooner than I thought now that I have a UTEC I just didn't think there was so little headroom on the stock ones.
jackansi is offline   Reply With Quote
Old 07-28-2003, 07:27 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: Hitting 100% IDC with stock turbo?
Rob,
IDC is about airflow, not about PSI..
Put a 20G on your car... you'll be all out of injector by 12 PSI....
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-28-2003, 07:35 PM   #3
jackansi
Member#: 23894
'07 3.2L Audi A4
crazy stuff
I'm learning more in the 6.5 hours since lunch than I have in the past 6 months... This just kicks ass Looks like I'll be taking it a bit easier for now.
BTW I'm going to be a real pest in this forum now
Old 07-29-2003, 01:05 AM   #4
wyowrx
Member#: 34157
00 Toyota MR-S
Can't make head or tails of your log.... But, if you are running close to static on the injectors with the stock turbo, you are probably way too rich. I would call Turbo XS and email them your logs, for a bit of help...
wyowrx is offline   Reply With Quote
Old 07-29-2003, 09:52 AM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
As you know by now, yes. You'll hit 100% IDC at even 15.7psi when it's 40F outside...
jblaine is offline   Reply With Quote
Old 07-29-2003, 10:10 AM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I used to hit 100% IDCs stock turbo/ injectors by 5200 rpm with my stage 3. Your probably not that rich, so only remove fuel if your using a wideband.
mbiker97 is offline   Reply With Quote
Old 07-29-2003, 10:42 AM   #7
jackansi
Member#: 23894
'07 3.2L Audi A4
Whats a safe ammount of fuel to trim off the stage 2 map once I get the STi injectors in there?
Old 07-29-2003, 10:46 AM   #8
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Just load up the stage 4 map, but control your boost levels to stock tapers. The stage 4 maps are fleshed out enough to handle you until you get properly tuned.
If you see knock, then do a #1 log and either give it to me in IRC, or post it here, either way, recommendations can be made.
Jorge (RiftsWRX)
www.ProjectWRX.com
EJ20 Built with stock turbo,how much boost can stock turbo hold? dblrsf1nest Built Motor Discussion 5 10-29-2007 07:34 PM
best to keep stock header with stock turbo? shemoves Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-17-2005 04:49 PM
anyone else hit 12.xx on stock turbo??? IWRXIT North West Impreza Club Forum -- NWIC 10 04-12-2004 08:55 PM
Any issues with stock turbo/injectors with Walbro pump? wagon-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-27-2004 04:07 PM
Hit 20 psi on stock turbo tonite AstroScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 11-16-2002 03:21 AM
