Old 07-28-2003, 06:33 PM   #1
jackansi
Member#: 23894
'07 3.2L Audi A4
Default TPS calibration on UTEC
I did the math like whats written in the manual and my TPS max voltage should be 3.96 for 100%. the UTEC doesn't let me enter anything but to a tenth. So I'm either at 98% or 102% (3.9 vs 4.0). (I might be wrong about the numbers since its been a few hours since I looked, I got side tracked).
Which would be better to use, the one that works out to 98% or 102%?
jackansi is offline   Reply With Quote
Old 07-28-2003, 10:13 PM   #2
Mildmanneredman
Member#: 29962
It's better to be a little over 100%. I usally hit 102-103%. Of course this doesn't matter if you have the same boost values in the 90 and 100% colums.
Mildmanneredman is offline   Reply With Quote
Old 07-29-2003, 12:06 AM   #3
QA Guy
Member#: 6739
Mildmanneredman is right. You lose out on the use of the 100% column if you cannot hit at least 100% WOT according to the TPS.
QA Guy is offline   Reply With Quote
Old 07-29-2003, 12:48 AM   #4
jackansi
Member#: 23894
'07 3.2L Audi A4
Thanks for the replies. I guess I'll be changing it in the morning
Old 07-29-2003, 01:56 AM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
yeah I'm at 102% too, it's kinda like turning the volume up to 11
PaulRex is offline   Reply With Quote
Old 07-29-2003, 03:20 PM   #6
zaxrex
Member#: 9898
Water Injected Blue
Long live Spinal tap!
zaxrex is offline   Reply With Quote
Old 07-31-2003, 01:21 AM   #7
jackansi
Member#: 23894
'07 3.2L Audi A4
I actually think it made a slight difference. The manual says as close to 100% as you can get but they didn't say high or low
Old 07-31-2003, 12:39 PM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Technically it will only make a difference with the boost map, the fuel or timing map will not be affected if the tps sensor only reads 98% in the dashboard because it is not TPS based. Only the bost map is soley based off of Throttle position.
TPS calibration pschiit UTEC 2 04-19-2009 08:52 PM
free air calibration ERR1 utec/tuna SBW UTEC 6 05-30-2007 05:13 PM
TPS calibration results - WOW T-boner UTEC 12 06-30-2006 12:59 PM
TPS calibration SubyDan05 Engine Management & Tuning 0 01-29-2006 09:36 PM
TPS calibration turbosporttsi Engine Management & Tuning 7 07-20-2005 03:13 PM
