Old 07-28-2003, 07:14 PM   #1
Sebaflex
Member#: 18210
Default Forester 2.5XT Swap into 2.5RS...
is it possible, or has anyone swapped a Forester Turbo Engine into a GC8
Sebaflex is offline   Reply With Quote
Old 07-28-2003, 07:41 PM   #2
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Since it just came out, we would have to say: not likely.
I don't see how it would be much different than a wrx swap.
Kevin
Red Rocket is offline   Reply With Quote
Old 07-29-2003, 01:06 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
It will be slightly different. You have to do the pedal assembly in order to utilize the electronic throttle, and perhaps something might not be compatible with the dash boards... That and you should go with the XT ECU for sure to control the AVCS properly.
Old 07-29-2003, 01:48 AM   #4
EJ25
Member#: 10768
why would you waste your time???
EJ25 is offline   Reply With Quote
Old 07-29-2003, 02:41 AM   #5
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
xt shortblock + your old heads = don't have to deal with electronic throttle
DoctorNick is offline   Reply With Quote
Old 07-29-2003, 11:04 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
becasue xt motor+injectors+reflash+turbo=300 hp with out a sweat
the pedle question is up in the air till some one tries it .. but i don't think that it is an issue .. the brake and clutch pedel box changed with the new gen impreza but i assume the gas pedle is seperate
Old 07-29-2003, 11:10 AM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
One little thing that hadn't occured to me. The pedal box DID change in the GG/GD chassis (which is what the Forester XT is based on) and it does NOT properly bolt into the GC/GF chassis. The lower four bolts will go in ok, however, the holes for the upper mount are in a different place vertically as well as horizontally. This prevents the pedal assembly from seating down properly and also prevents the clutch master cylinder from seating down properly on the firewall.
Chances are, it is just the accelerator pedal that is going to be the problem. It mounts seperately from the brake/clutch pedal and _should_ bolt in without a problem.
-Jon
Old 07-29-2003, 11:11 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
right but the gas pedle is seperate
Old 09-24-2003, 03:28 AM   #9
DragonRM
Member#: 14365
heard that the engine itself is set up a bit differently so it sits too high or something in an rs bay... but never confirmed it... came from a semi reliable source
DragonRM is offline   Reply With Quote
Old 09-24-2003, 10:51 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no
the mounts could be diffent but they can be changed
or the cross member coudl be differnt
but a subaru block is a subaru block all the same exterior demensions
Old 09-28-2003, 08:16 PM   #11
Discjoshie
Member#: 43717
2000 2.5 RS
I would love to do this swap if it is feasible. I am not very experienced with this and I have been searching everywhere to find out what kind of problems there would be to put the 2.5XT into my 2000 RS body. What exactly would need to be done to make it fit and function assuming the forester xt ecu is used? Can this pedal assembly discrepancy be explained any more simply so I can understand it better, possibly?
Thanks
-Josh
Discjoshie is offline   Reply With Quote
wrx swap into 2.5rs?? advice please shade1569 Subaru Conversions 2 09-01-2009 09:02 PM
2.0T swap into 01 2.5 RS EJ0626 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-29-2007 12:53 PM
JDM Swap into 2.5RS = Better than sex. powerlabs Proven Power Bragging 199 12-19-2005 11:21 PM
completed EJ20 swap into 2.5RS parts left over for sale erice1984 Private 'For Sale' Classifieds 12 10-19-2005 02:04 AM
engine swap into 2.5rs Silver_Fox General Forum Archive 1 03-26-2001 07:04 PM
