Old 07-28-2003, 09:15 PM   #1
CpnNeeda
Member#: 20060
02 WRX
Midnight Black Pearl
Default UTEC Stage 4 FMIC Q's???
The only problem I am having with the base map, is that at real low rpms, with light throttle, the car will die. Almost like its being flooded. I thought that the lower rpms were decided by the stock ECU? I have a laptop, but unfortunately it needs a new battery. Any ideas? TurboXS guys can you help out?
CpnNeeda is offline   Reply With Quote
Old 07-29-2003, 10:11 AM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The entire fuel map is changed if your running a stage 4. I would check your map to make sure it's the right one. It should have a value in every cell for fueling.
mbiker97 is offline   Reply With Quote
Old 07-29-2003, 10:07 PM   #3
CpnNeeda
Member#: 20060
02 WRX
i downloaded the stage 4 fmic from TurboXS and ran that. I changed all the settings that you are warned to change. Any other ideas? Could it be that the TPS isn't set-up right? I never got a chance to change it since the laptop died on me.
Old 07-30-2003, 12:19 AM   #4
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
The entire fuel map after the TPS crossover point is changed. So the turboxs base fmic map is set to take over at 50% TPS. Below that the ecu is controlling fuel.
MAD REX is offline   Reply With Quote
Old 07-30-2003, 12:28 AM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
What map are you looking at? All stage 4 map always alter the fuel over the entire map because the stock ECU's program cannot correctly manipulate the STi injectors. Look here if you still don't believe me.
Old 07-30-2003, 01:14 AM   #6
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Ok the 0% column is the fuel for 0-50% throttle. I said that wrong.
10% - 100% = after 50% tps
Old 07-30-2003, 10:36 AM   #7
CpnNeeda
Member#: 20060
02 WRX
I see the changes you are talking about, but would that possibly cause the car to run too rich at part throttle? I tried to replicate it yesterday when it was a bit cooler here. I did it maybe once, but didn't cut off, and I couldn't get it too do it again. Could it be that the heat is throwing something off?
Old 07-30-2003, 11:41 AM   #8
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The heat would affect the way the car drives but not to a stalling point.
Did you reset your ECU recently? I know my car took a couple days to learn the new fuel trims. Other than that I'm out of ideas.
Actually you might want to check in the User constants IIRC for the fuel increase. It might be set at too low of an intake temp and is dumping fuel to fight det.
Old 07-30-2003, 03:05 PM   #9
CpnNeeda
Member#: 20060
02 WRX
Yeah a reset was done. Saturday night at about midnight. It was unplugged and out of the car for maybe an hour. Maybe the stocker is stumbling trying to learn the new stuff. I haven't been able to drive it much being at work most of the time since Sat., so maybe a couple of days dealing with it, will give it enough time to learn to fix it. I also try the other settings you wrote about. What should I consider changing that setting too? Thanks for the help.
Old 07-30-2003, 04:03 PM   #10
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Post up some logs so we can get a better idea of whats going on..
PaulRex is offline   Reply With Quote
Old 07-30-2003, 04:07 PM   #11
CpnNeeda
Member#: 20060
02 WRX
I'll do that tonight, if I can get the laptop to stay on long enough. That and if I can get the car to do it again. Like I said, it is considerably cooler here now, so it might not do it. I will see though, can't hurt to try.
UTEC stage 4 + FMIC maps needed. MJU1983 Engine Management & Tuning 42 04-20-2003 03:26 PM
utec stage 4/FMIC Casperwrx Engine Management & Tuning 5 03-29-2003 11:48 PM
utec stage 4 map and stage 4 tmi map the same? datdudedennis Engine Management & Tuning 4 03-19-2003 12:37 AM
UTEC stage 4 map with Vishnu stage 2? ChrisWRX Engine Management & Tuning 1 12-25-2002 03:26 AM
