Old 07-28-2003, 08:23 PM   #1
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Default pulling hard and loving it! check this out!
My 99 GC8 with a motor i built and tuned STOCK trans, vishnu turbo kit and vishnu tec2 kit. Well i finally took it to the drag strip with the tec tuned fairly well. the motor has about 4K miles on it. I had it spiking about 13 pounds of boost the best run i got was [email protected] 60foot time was 1.87. not bad! I am finally in the 12's i think if i can ever get this thing tuned right/or by a pro i may e able to put it in mid 12's with 16pounds of boost and a better gear ratio.(and trans) I had to put the car in fifth gear even when i was shifting at 7K RPM.
What do you think? not bad for a selffunded daily driver.
Any ideas for a good solid trans with better gear ratio that will bolt up to a EJ25?
New england guy's, yes the plate says NDBOOST
(even when you have boost you always want more)
jeff22 is offline   Reply With Quote
Old 07-28-2003, 10:05 PM   #2
jsaunders
Member#: 40059
10 CTS--V
thunder grey
How much do you have into the kit? When you say built and tuned do you mean low comp. pistons? Whould love to meet up sometime, I'm 40 mins away on 101 south in New Ipswich NH 15 mins from Milford. 12's is awsome. I'm trying to get my wife to let me put a turbo on her car- i already have one on mine- 300hp 600+ lbs torque. Joel
jsaunders is offline   Reply With Quote
Old 07-29-2003, 01:17 AM   #3
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
sweet... built engine? tuned ? i expect 11's hehehe
HOK is offline   Reply With Quote
Old 07-29-2003, 01:31 AM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
pictures! details! Congrats on the 12.9!
DoctorNick is offline   Reply With Quote
Old 07-29-2003, 02:57 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
congrats on the time, what gearset are you running?? the trap speed is rather low for an RS-T
i plan to be into the low 12's with 19psi on a 2.0 litre STi block.
Jeremy
Old 07-29-2003, 10:19 AM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Default Re: pulling hard and loving it! check this out!
STi Version 4. Has 4.44 gears.... very quick and nice overdrive (5th)...
kastle is offline   Reply With Quote
Old 07-29-2003, 10:48 AM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Sweet time man! 12's is the place to be. Makes you feel like you got something out of the car after putting all that money into it.
As far as tranny rec's, I would say the PAR Synchro set should be alright. Not really anything but good remarks from what I read about them.
You say you were shifting at 7000 RPM, do you have head work as well? I know the stock valves are good to about 7200 RPM but I am still curious. I know a guy with a built motor and what not who bent a valve from overrevving...don't know what he revved to though.
Graham
Graham is offline   Reply With Quote
Old 07-29-2003, 11:12 AM   #8
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
I'll try to get some pics of it. I am not very computer frendly.
I have a but load of head work done to it
Cobb cams, and spings. ferra valves. self ported and poilshed heads.
Kastle thanks i'll look into that.
Old 07-29-2003, 12:20 PM   #9
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
What motor are you running a built EJ25 or something else?
seven881 is offline   Reply With Quote
Old 07-29-2003, 12:42 PM   #10
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
NICE!!!
Great time and great setup you have there bro....Enjoy it...
Someday i will
How long did it take for you to do the port and polish?
latinskllz is offline   Reply With Quote
Old 07-29-2003, 12:57 PM   #11
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
port and polish took me about 2 to 3 weeks it was my first cylinder head project and i took my time. I also had a friend over looking the work for me to make sure i didn't screw it up. I have done 4 other cars and had very good luck.
Old 07-29-2003, 02:46 PM   #12
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
HMM how much did the engine work cost you? Im thinking about keeping high compression, building up the engine, and puting the eaton s/c to 10 or more psi w/fmic.
MadMax
MadMax is offline   Reply With Quote
Old 07-30-2003, 06:04 PM   #13
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Jsaunders: That would be cool to meet up sometime Do you ever go to NED i think i'll go again in a month or so.
MadMax: I figure i have about 4grand into the parts and machine work, as for labor.... Too much to count, my own time(my girlfrend hates the car) Quote:"you don't spend enough time with me" Has anyone heard this before????? ya!
Old 07-30-2003, 09:22 PM   #14
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default Ya, she tells me that all the time
Had to. Block?
milkman is offline   Reply With Quote
Old 07-31-2003, 12:47 AM   #15
markus
Member#: 438
2004 STi
White on Gold
No! Never!
Congrats on the 12.9. That's smokin'.
markus is offline   Reply With Quote
Old 07-31-2003, 10:53 AM   #16
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
no GF, so im free to spend my money and time on the car. lol
So what compression are you running? Did you get everything from cobb?
MadMax
Old 07-31-2003, 12:39 PM   #17
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
I got pistons,rods and cams from cobb. springs and retainers also they seem to be the only one i could find valve springs for it. I bought the valves through ferrea they are the same as cobb valves but $200 cheaper. The compression is 8.5-1 100mm JE's, cower rods. Jeffp
Old 07-31-2003, 05:49 PM   #18
drift king
Member#: 26493
99 Impreza RSTI
i basicly have the same setup, i ran my with 13psi on race gas and 100 shoot of nos. and i ran 11.53 good luck man
drift king is offline   Reply With Quote
Old 07-31-2003, 10:39 PM   #19
jsaunders
Member#: 40059
10 CTS--V
thunder grey
jeff22-"not enough time with me" IF we got a buck for every time we've heard that I could have stopped working long ago.
Here's the girlfriend or wife---
I do go to NED but haven't been in a while. Been thinking about going up some time in Aug. Maybe 2nd or 3rd week? Joel
Old 07-31-2003, 11:26 PM   #20
jdzumwalt
Member#: 38691
2015 sti
Dark Blue
I hate to sound like a jerk dude but you should be in the elevens with a built motor. I thin k you need to runa bigger turbo or somthing. I had a fully built 240 sx running 11's with a t3/t4 and 50lbs injectors. My goal is to have my wrx running mid twelves on stock internals with a turbo upgrade.
Gregg
jdzumwalt is offline   Reply With Quote
Bought a Honda.....and love it check it out, you'll like it JonP North West Impreza Club Forum -- NWIC 12 07-18-2007 12:03 AM
OT art and sculpure aficionado's. check this out azn2nr Off-Topic 11 08-07-2006 08:56 PM
Subaru and DMB fans check this out.... vinithing Off-Topic 14 04-09-2006 01:19 AM
Want to measure your HP/ Tourqe /1/4 mile tim and trap speed? check this out zigger Proven Power Bragging 16 11-10-2005 03:41 PM
This guy REALLY loves Kerry. Check this out. Rizzo314 Political Playground 28 11-23-2004 11:40 AM
