Old 07-28-2003, 08:47 PM   #1
03WRXMA
Member#: 35081
2012 WRX
Exclamation Can i use the rear wiper fuse as a source to tap +12 Switched for my gauges?
I have a sedan so this circuit is unused, safe to tap into the fuse to get +12 switched power for my gauges? Thanks.
03WRXMA is offline   Reply With Quote
Old 07-28-2003, 08:56 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Sure, you could probably do that. It would be overkill though since gauges don't draw very much current. Much of the current will be for illumination and that is drawn from the lighting circuit anyway. It would make more sense to use the extra circuit for higher-current devices if you have any, and just tap an existing one for the gauges.
Old 07-28-2003, 09:03 PM   #3
03WRXMA
Member#: 35081
2012 WRX
Thank you sir, I hoped you would repond, I know you know your **** with electronics.
Old 07-28-2003, 09:14 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A good circuit to use for gauges is the one that powers the compass/mirror and some other low-current stuff. It can be tapped via a yellow/red wire at the connector harness at the front of the under-dash fuse box. It's also good for a radar detector, I have my V1 powered from this circuit.
Old 07-28-2003, 09:45 PM   #5
03WRXMA
Member#: 35081
2012 WRX
Is this harness on top of the fuse box, 'horizontally' pluged in?
Old 07-28-2003, 09:46 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, look for the yellow/red wire. Should be the same on the '03 as it was on the '02.
Old 07-28-2003, 09:49 PM   #7
03WRXMA
Member#: 35081
2012 WRX
Thanks again
Old 01-14-2010, 09:42 AM   #8
loupeznik
Member#: 99310
Could you tell me what color wire you tapped? Or did you tie into it some other way. The back of the fuse panel has a bunch of pugs in it. Which one is for the wiper? I want to power a powered subwoofer from it. They are both fused at 10 amps.
loupeznik is offline   Reply With Quote
Old 01-14-2010, 11:03 AM   #9
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
An easy way to tap into a fused circuit is to use a fuse tap. You can get them at a parts store.
Stupid Question: Can you use the FWD fuse to drive the car every day? Koss Normally Aspirated Powertrain 21 12-11-2012 01:02 AM
Rear Wiper Fuse in 02 WRX Sedan, what does it do? ogboot Electrical & Lighting 7 01-14-2010 09:39 AM
can i use the stock banjo bolt for my 18g oil feed line? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-23-2006 05:59 PM
Can i use the AP if i get my ecutek flashed to stock?? SoSLOWSTi AccessPort 6 06-27-2006 07:36 PM
Can I use the front O2 sensor for my A/F on my turbo timer? Got Groceries? Electrical & Lighting 4 05-29-2004 10:06 PM
