Old 07-28-2003, 10:57 PM   #1
Solomon
Member#: 36587
2000 Legacy GT (BE)
Default car no start after CAI install? help please
My car will not start after I installed the injen CAI? It turns over but does not start? THe check engine light is on. The only thing I unpluged was the air temp sensor from the stock box then re-attached it to the injen intake?
HELP!
Solomon is offline   Reply With Quote
Old 07-29-2003, 12:03 AM   #2
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
that's weird. I bet the CEL is not real, it's just showing your ignition, but I cant imagine the hang up?! I mean it should start with just a naked intake.
Yeah, I'd Reset and hope it goes away.
By the way. Brullen quiet is prolly loud enough. It's just enough to set off the odd car alarm, but not obnoxous for long trips. You'll be happy with the deeeeeeep rumble.
Dr Ken is offline   Reply With Quote
Old 07-29-2003, 12:10 AM   #3
Solomon
Member#: 36587
2000 Legacy GT (BE)
I took off the whole intake off of the manifold to see if any air was getting in. still nothing. I disconnected and reconnected the Air sensor and even removed it a few times...I do not know if the battery was disconnected or not when making those changes. I have to go back tonight and try some more things. I am thinking that I will disconnect the battery, disconnect the sensor for about 10 min. Then reconnect the sensor, then reconnect the battery. Try to turn over the car without stepping on the gas peddle and hope. If that fails I will leave it all connected and pull the ECU fuse out, wait 5 min, then re-connect the fuse for the ECU. See any problems in this?
Old 07-29-2003, 01:57 AM   #4
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Exclamation Only a suggestion
Check your vaccum lines - maybe you forgot one?
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 07-29-2003, 03:01 AM   #5
Solomon
Member#: 36587
2000 Legacy GT (BE)
Well nothing. It is now almost 12am and I need to pass out. I went back and re checked the hoses, there are only 3 and they go to the correct ports on the intake. I let the car sit with out the neg wire to the battery for over 30 min with the air sensor connected to the intake. What I found to be odd was that the break light, CEL, oil, and Battery where all on when the key was turned almost to start. When you turn over the car, or try to it just turns over and over again, the CEL does go off, so does the oil. But the Battery light stays on.
I am also leaving the Neg connection off the battery tonight.
Old 07-29-2003, 09:21 AM   #6
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
maybe the battery is dead...
DanzBorin is offline   Reply With Quote
Old 07-29-2003, 10:22 AM   #7
Solomon
Member#: 36587
2000 Legacy GT (BE)
no. the car turns over.
Old 07-29-2003, 10:55 AM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Replace the fuel filter and fill up your tank with gas. It sounds like your out.
Seriously though it sounds like something is messed up with the fuel system. Maybe power to your fuel pump is disconnected or has a blown fuse or something.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 07-29-2003, 11:21 AM   #9
Solomon
Member#: 36587
2000 Legacy GT (BE)
to me it sounds like I am not getting a spark, the starter is just turning over.
Old 07-29-2003, 11:48 AM   #10
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
I just went out to look at my EJ25 to see if any ideas arrise, I agree with thinking about primary spark failure. I wonder if the supply to the coil has been disrupted... it's wiring traverses out from under the same area that you're working. Four wires supply the coil via a plug on the passenger side of the coil unit, it coulda been tugged, or somethingk. Don't you hate arm-chair mechanics.
Old 07-29-2003, 01:29 PM   #11
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
And Keyboard Mechanics.
Were the same ones that add horsepower like this:
Intake = 10hp
Full Exhaust = 18hp
Cam = 20hp
My car has 213hp
Old 07-30-2003, 12:10 AM   #12
Solomon
Member#: 36587
2000 Legacy GT (BE)
Ok, this is one for the books and for everyone who might EVER have the ****ing problem. I went back tonight with a friend to help look at the problem, like spark connections, blah, blah, blah.
i had spark, I have fuel, I have all the hoses on like I have been saying. Take a look below.
This little bastard was the problem. It is some sort of relay. Instead of the fuse that goes into the block, one end goes into the block, and on the other end goes the fuse?!?!?!
What the hell is this? Part number
Any way right when I removed the relay out of play and place a new fuse in its place it started! On some off chance it went bad most likley while I was changing out the intake, maybe I sparked something...doubt it. Anyway, if anyone knows what this is or go look to see if they have one that would be great!!!
Some after photos.
Old 07-30-2003, 12:31 AM   #13
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Talking
Woa! That's really cool you found that little bast4rd? Well done. I love that sort of thing. Dancing nanner time.
No Start After Rebuild, EJ251, Help? salvator_rizzo Normally Aspirated Powertrain 9 08-07-2009 02:39 AM
HELP - Car won't start after turbo install Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 06-30-2005 08:23 PM
HELP CAR WONT START after sprayer install (im retarded) er murena Electrical & Lighting 4 06-29-2003 12:20 PM
NEED HELP! car wont start after deck installation! yeng Car Audio, Video & Security 7 04-28-2003 05:53 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-11-2001 11:35 PM
