Old 07-29-2003, 01:17 PM   #1
JayGold
Member#: 7074
Default EJ25 Rebuild questions
Disassebled a '99 EJ25 motor with a possible spun bearing (knocking really bad after being oil starved 2.5 quarts), purchased a new short block, keeping the original heads.
What can I possibly use to clean the contaminants on the valves and surrounding area before reassambley (so as to not drop any debris into the new block)?
I have on order: new head gaskets, intake manifold gaskets, water pump and gasket, timing belt, ribbed belts, coolant hardline o-rings, valve cover grommets/gaskets, spark plug seals, oil pan gasket, header gaskets, pvc valve, thermostat/seal, fuel filter, plug wires, plugs and some new hardware. Anything else I may need to replace at this time with the above mileage?
When does the spark plug distributor need a rebuild or replacement?
Any other recommendations or specific reassembley precautions I should know about, please post them.
I thank you for helping me revive an abused RS.
Jay
JayGold is offline   Reply With Quote
Ej25 rebuild crazyswede New England Impreza Club Forum -- NESIC 2 01-07-2008 10:32 PM
ej25 rebuild. need part numbers for SOHC belts! opious Normally Aspirated Powertrain 3 09-17-2007 04:10 PM
Phase I EJ25 rebuild ballitch Built Motor Discussion 24 08-20-2007 09:36 PM
Ej25 rebuild is it worth it? Dodik Legacy Forum 4 01-05-2007 01:10 PM
Help on EJ25 Rebuild Loc: Maine/Portland firstHKS New England Impreza Club Forum -- NESIC 8 12-04-2005 02:43 AM
