Old 07-29-2003, 01:59 PM   #1
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
Default Borla header question
Hey people, the new generation header from Borla--is that an exact fit, or is there any cutting or welding? I spoke with a salesman 'cause the website said minimum welding needed for fitment--he said you have to cut a pipe and then re-weld it. I thought you could buy it and slap it in, any thoughts? 10-Q
bheinz57 is offline   Reply With Quote
Old 07-29-2003, 02:52 PM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
I didn't have to do anything but bolt my Borla Header set in on my 99 Legacy GT. Yours should be the same.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 07-29-2003, 04:39 PM   #3
Michael Low
Member#: 15056
1999 Impreza 2.5 RS
i dont know if you have a wrx or a 2.5 but I just installed my new gen borla header for my 2.5. No welding required at all. Straight bolt on but i dont know about the wrx motor tho? sorry, hope i helped
Michael Low is offline   Reply With Quote
Old 07-30-2003, 01:27 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The "new generation" Borla header removes that problem that the salesman mentioned.
Old 07-30-2003, 07:11 AM   #5
imprezzed
Member#: 1624
2002 OBS 5 Spd
Green
On the new gen headers, are people having any CEL's? I heard that the old ones set a converter too low temperature or something CEL. I guess a few people had luck with wrapping their headers and the CEL was less frequent. anybody?
Jason
imprezzed is offline   Reply With Quote
Old 07-30-2003, 09:36 AM   #6
Pat L.I.
Member#: 20498
2006 WRX TR
on my newest gen borla header i have had no fitment issues, and no cels. they were installed during the summer so we will see what happens in the winter.
Pat
Pat L.I. is offline   Reply With Quote
Old 07-30-2003, 10:18 AM   #7
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
Default Thanks guys
I was 90% sure that it was a direct bolt on, thanks for the info. Looks like a great mod. Thanks for the replies.
Old 07-30-2003, 10:40 AM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
The cat inefficiency light mainly comes from high flow cats not headers.
People have had issues with Missfire codes with these headers. Some people have attributed this to the way Borla designed the pulse sequencing when they hit the final collector. We think Borla designed the pipe lengths so the exhaust pulses coming from one side of the engine either take significantly more time or less time to hit the collector then the stock header section. When the front O2 sensor sees this variance it throws the Missfire code.
Brad
Old 07-31-2003, 07:01 AM   #9
imprezzed
Member#: 1624
2002 OBS 5 Spd
Green
MY99 2.5GT - interesting, I wonder if they've done anything to the new gen headers to cure this problem, I don't like CEL's
Old 08-01-2003, 02:22 PM   #10
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
Default Borla 2.5 header
I just ordered the 4th generation header. Only $264.99 shipped. That includes gaskets and bolts! From Performance Center.com I believe quality and fittment issues have been addressed with this new header. I'm not sure about CEL's, but I think it has to do with each unique set up. Thanks guys.
Old 08-01-2003, 05:10 PM   #11
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Default Re: Borla 2.5 header
I just put an order in with these guys for gen IV header as well. Borla stuff is actually 5% off this weekend, I got mine for 251.74 + 8.25 for shipping. I verified that they come with gaskets and bolts as well. I think I will be ordering a MIL eliminator as well so when I get my test pipe / intermediate pipe made up I can avoid the inedible CEL.
werd.
Compressed is online now   Reply With Quote
Old 08-01-2003, 06:37 PM   #12
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
...the gen IV comes with gaskets and bolts now?
test pipe huh
Albert is offline   Reply With Quote
Old 08-01-2003, 07:56 PM   #13
sidewayz
Member#: 5810
2001 S366 2.5RS
I haev the Gen 4 and I had to "machine" the holes a wee bit lager to fit correctly, plus I get cel's all the time
sidewayz is offline   Reply With Quote
Old 08-01-2003, 10:38 PM   #14
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
I had the cat efficiency code with my gen 3's...on and off. I picked up the Pony express MIL eliminator...no more CEL's.
I just need to get the headers back on the car...typical gen 3 weld failiure at that "brace", that I had TIG'd back up at work.
Bob
Bob O is offline   Reply With Quote
Old 08-01-2003, 10:55 PM   #15
imprezzed
Member#: 1624
2002 OBS 5 Spd
Green
pony express mil eliminator?
what exactly is that? is it a fake o2 sensor that generates a signal of .1v .9v .1v etc ?
has anyone else had to machine their header holes larger?
thanks for the input
jason
Old 08-02-2003, 12:30 AM   #16
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Bob
BoB O: the brace on the gen3 are the cause of the cracking. Remove the brace and you have a gen4
95% of the gen4 cylinder head flanges need to be reamed out to slip on easily. I just pulled on the pair of primiary tubes and it slip on.
Did you guys really get gaskets and bolts with the gen4? All I got was a lousy Borla baseball cap.
Old 08-02-2003, 07:01 AM   #17
imprezzed
Member#: 1624
2002 OBS 5 Spd
Green
borla baseball cap?!?!?!
hehe
but seriously did you guys get gaskets and bolts?
Old 08-04-2003, 11:48 AM   #18
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
test pipe huh
I called and verified with perfomancecenter.com that the header comes with gaskets and bolts, I'll find out soon and will let you guys know.
As far as the test pipe goes, we shall see. If I can get a midpipe fabbed for cheap enough I will do it just for track days. I dont really want to run a test pipe all the time, not environmentally sound and it really does make the car stink. I did find on my old civic that was NA also that I picked up some power without the cat, it was nice but probably not worth it in the scheme of things.
Old 08-04-2003, 01:22 PM   #19
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
FWIW, I've done the test pipe route already and had to take it off because I was going deaf. It made the car hella loud (borla headers+modified random tech cat pipe+rallispec N1 catback w/o resonator). However I should note that the headers cracked during this time period so I'm sure that didn't help the noise. Not really sure about gains from it (tired clutch). I still have the pipe so I may try it out again if it doesn't get sold once the headers go back on.
Bob
Old 08-04-2003, 01:27 PM   #20
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I didn't get gaskets or bolts when I ordered my header set about a year ago from www.performancecenter.com
Brad
Old 08-04-2003, 03:48 PM   #21
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Bob
lol, cats definitely quiet the exhaust system down quite a bit. I've found that having a resonator added will quiet the exhaust but it will still be louder than with a cat in place, although it will be a deeper tone.
Old 08-05-2003, 07:04 AM   #22
imprezzed
Member#: 1624
2002 OBS 5 Spd
Green
so I checked out the pony express web page, and they say that you only need their product for a gutted or high flow cat, so this wouldn't help out a CEL with a borla header would it?
jason
Old 08-05-2003, 08:28 AM   #23
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
What exact CEL are you getting with Borla Headers?
Old 08-05-2003, 06:53 PM   #24
imprezzed
Member#: 1624
2002 OBS 5 Spd
Green
I don't have Borla headers yet, I was just investigating before I buy them
Old 08-05-2003, 08:03 PM   #25
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
I would get the header first, then if you get a CEL order an eliminator. It seems not everyone with the gen4's are getting CELs. I 've NEVER had a CEL because of any mods I've done...you might be one of the fortunate.
...so, are gaskets and bolts really included with gen4 package???
Borla Header Question wRxbeater11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-04-2004 12:40 PM
Borla Header question piker28 Normally Aspirated Powertrain 15 04-06-2004 09:55 PM
Borla Headers question wrxlvr Outback Forum 3 07-20-2003 11:47 PM
Borla Headers question wrxlvr Legacy Forum 19 06-27-2003 01:49 AM
Borla Header Question subachad Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-02-2001 01:33 PM
