Old 05-23-2001, 09:47 PM   #1
SilverSubie
Member#: 4375
Exclamation WOT rich condition....
Does anybody else seem to notice there 'rx running rich at WOT. mine does, not terrible or anything but slighty noticeable. it's more at 3-4,000 when i'm just cruising then i stomp it. i have to let off gas and ease it a little then get on it. i promise it's rich condition hesitation just alittle and it's not all the time. again not terrible or anthing...i've never had a turbo car before though so maybe i'm not use to having to let it spool up or somethin. just wondering.
-grant
SilverSubie is offline   Reply With Quote
Old 05-23-2001, 09:50 PM   #2
TerribleOne
Member#: 6857
aspen white
Post
i dont see how you can tell if your running rich without a egt. hesitation doesnt always mean rich mixture. it could just be the turbo lag.
peace
TerribleOne is offline   Reply With Quote
Old 05-23-2001, 10:12 PM   #3
TurboXS
Member#: 4143
2002 WRX Wagon
WR Blue
Post
The WRX is very rich at WOT. The stock ECU gives the WRX an A/F ratio of less than 10:1 at WOT from 4500 rpm to redline. This was done with a $3k wide-band 02 sensor during dyno runs on my WRX and confirmed with another wide band O2 sensor. The second O2 sensor could not read any lower than 11:1, but was pegged at 11:1 from just over 4000rpm until redline.
TurboXS is offline   Reply With Quote
Old 05-23-2001, 10:19 PM   #4
SilverSubie
Member#: 4375
Post
i knew it...i guess i'll have to wait till my aftermarket ecu to correct that. or just up the boost enough till it maxes the injectors...haha-
-grant
Old 05-23-2001, 10:20 PM   #5
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
Post
Apparently all Subaru tunes all rex's rich. I suppose its safer; the benefit to us is assurance of a more adequate fuel supply come mod time and less likelihood of lean conditions when we push it with some power tweaks.
SLR-
SuicidalLabRat is offline   Reply With Quote
lean/rich condition jbizzle Engine Management & Tuning 6 02-23-2005 03:38 AM
Carbon Build Up-Rich Condition? bcl55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2002 10:22 AM
Rich Condition... WRXGuyInUSA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-09-2002 02:36 PM
Could rich condition cause CEL (UTEC)? ScoobieSnaX Engine Management & Tuning 3 10-09-2002 11:09 AM
Correction of MBC Rich Condition wigglesxjr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-08-2001 04:07 PM
