Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 07-16-2003, 11:25 AM   #1
bat1161
Member#: 11878
2006 3.0 H6 Wagon
Default Swaybar question
I am considering upgrading the swaybars on my 00 wagon. Does anyone have any suggestions on what type, and where to get them? I am trying to tighten up the body roll as I take corners and turns.
Mark
bat1161 is offline   Reply With Quote
Old 07-18-2003, 10:13 AM   #2
bat1161
Member#: 11878
2006 3.0 H6 Wagon
Anybody?
Old 07-19-2003, 05:58 PM   #3
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
Take a look here:
Teagues Auto
I know Dale and he's a great guy. He and his dad have been working on Subarus since the FF-1 and early Leones back in the 1970s.
I don't know what size the stock bar is on a Legacy, but I'd say something between 18 and 20mm should be sufficient. Also look into getting a set of endlinks for the new swaybar. That way you can toss the crap factory links and get the most out of your new equipment.
Matt is offline   Reply With Quote
Old 07-21-2003, 11:56 AM   #4
bat1161
Member#: 11878
2006 3.0 H6 Wagon
Thanks for the info Matt. I'll check them out.
Mark
Old 07-25-2003, 03:16 AM   #5
sovereignmk1
Member#: 11858
1998 Silver Legacy
Brief Info - Outback's traditionally have larger swaybar's than the other models(legacy). With the previous generation of Legacies, L's were @ 13mm, GT @ 16mm, and OB's @ 18mm. So the OB swaybar was a good upgrade for the L and GT's.
You'll have to go to 20mm or bigger for an upgrade on your OB, and Whiteline makes a great inexpensive swaybar.
//M
sovereignmk1 is offline   Reply With Quote
Old 07-25-2003, 10:21 AM   #6
bat1161
Member#: 11878
2006 3.0 H6 Wagon
Thanks sovereignmk1. I've been looking into the Whiteline adjustable sway bar- I believe it goes up to 22mm. I also think I will go with Matt's suggestion of changing the end links at the same time. I just have to figure out when I can do this. Hopefully soon, probably before the end of the summer.
Mark
Old 07-28-2003, 06:25 PM   #7
kleinkid
Member#: 27091
2010 STi SE
I have an '00 OB wagon and put the Whiteline adjustable rear sway bar on. It is 20, 22, 24. I set on the first hole(20mm). Pretty easy to install, the hard part was getting the stock one out. You have to kind of snake it out past interferences. That setting is good, may try 22 sometime to see how it feels.
kleinkid is offline   Reply With Quote
Old 07-29-2003, 04:55 PM   #8
AZP Installs
Member#: 40160
Mark,
AZP can always do your sway bar when you get it
-mike
AZP Installs is offline   Reply With Quote
Old 07-30-2003, 10:55 AM   #9
bat1161
Member#: 11878
2006 3.0 H6 Wagon
Don't worry Mike, I plan on contacting you folks. Always good to have someone around who knows what they are doing
Mark
Im back to the family and I have a Tokico D-Spec Question and Swaybar Question last lemming alive Brakes, Steering & Suspension 1 09-20-2009 11:01 PM
Swaybar questions for WRX FUBAR Brakes, Steering & Suspension 12 08-09-2001 12:29 PM
Whiteline swaybar question ChimChim General Forum Archive 10 09-23-2000 09:03 PM
Swaybar question... JC Technical Forum Archive 5 09-17-2000 04:33 PM
Another FRONT Swaybar Question... SCOOBER Technical Forum Archive 3 08-03-2000 01:48 AM
