Old 03-27-2001, 09:55 PM   #1
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Post HKS super sequential BOV compatible with MAF systems?
I heard that the HKS super sequential bov will work with MAF systems venting to atmosphere and pose no problems to the fuel readings since it uses a pull type diaphragm instead of the tradition push type diaphragm like most others.
Is this true and has anyone with a turbo with MAF run this before without running rich conditions?
I really like the HKS SS bov the best.
blkwag is offline   Reply With Quote
Old 03-28-2001, 09:39 AM   #2
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post
That's the BOV I am getting installed tomorrow to my MY98 RS Turbo along with a HKS Super AFR these two products, are both supposed to be great for Blowing off into atmosphere. PM me on Saturday or Sunday and I will tell you my thoughts after a day of driving.
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 03-28-2001, 08:07 PM   #3
blkwag
Member#: 4838
2002 WRX Wagon
Post
Thanks, I will do that.
Can you also do me a favor and drive your RS with the AFR set flat or bypass mode?
The reason is that with the AFR, you can partially tune out the rich condition that you get when the bov vents to atmosphere.
I just want to know if it runs good without using a fuel controller like the S-AFC or AFR.
thanks.
Old 03-28-2001, 08:49 PM   #4
GDA
Member#: 4324
02 GDA
Platinum
Post
Worst comes to worse, couldnt you just reroute it back into the system with any aftermarket BOV?
EJ20WRX
GDA is offline   Reply With Quote
Old 03-29-2001, 09:55 AM   #5
blkwag
Member#: 4838
2002 WRX Wagon
Post
yeah, but then you lose the cool sound of the HKS, which is the primary reason why a lot of people get it.
Heck, most people probably get an aftermarket boost gauge for the sound or when running increased boost that the stock bov can't handle.
Old 03-29-2001, 05:06 PM   #6
kaos200
Member#: 2692
Post
don't you mean bov not gauge?
"Heck, most people probably get an aftermarket boost gauge for the sound or when running increased boost"
[This message has been edited by kaos200 (edited March 29, 2001).]
kaos200 is offline   Reply With Quote
Old 03-29-2001, 09:04 PM   #7
blkwag
Member#: 4838
2002 WRX Wagon
Post
Duh,
That's what I meant. Thanks for the clarification.
Old 03-29-2001, 11:13 PM   #8
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Post
Anyone know if a Greddy Type-S bov would work on the WRX when vented to atmosphere??
Orbiter is offline   Reply With Quote
Old 03-30-2001, 07:22 AM   #9
Blugin
Member#: 5270
2008 EvoX MR
Red
Question
How about this...
Has anyone just taken the recirculate tube off of the factory BOV?? The sound would be there. The only issue is that it would run rich for a second between shifts. I bet it is not even noticeable. Would this trigger a CEL? I am pretty sure the ECU can tolerate a temporary rich situation, my civic ran rich most of the time and it only threw a CEL when I added injectors and it wasn't tuned. Am I missing anything? Would disconnecting the recirc. hose have any adverse effects??
[This message has been edited by Blugin (edited March 30, 2001).]
Blugin is offline   Reply With Quote
Old 03-30-2001, 07:37 AM   #10
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
if you remove the reticulation tube you'll end up with two things, 1)a vacuum leak 2) the engine will run rich on shifts as stated, but it IS enough to cause the engine to bog down and not run properly.
Strepto is offline   Reply With Quote
Old 03-30-2001, 07:45 AM   #11
Blugin
Member#: 5270
2008 EvoX MR
Red
Post
Well you would of course plug the hose. I thought that could go unstated...
Old 03-30-2001, 08:00 AM   #12
blkwag
Member#: 4838
2002 WRX Wagon
Post
Get rid of all three cats, put on a straight thru muffler, vent to atmosphere and enjoy the fireworks out back.
I was thinking of doing this but since my car is a daily driver....
ebay turbo inlet with samco maf hose, hks super sequential bov anthonyrb98 Engine/Power/Exhaust 18 04-26-2007 03:54 PM
FS or Trade - HKS Super Sequential BOV Impreza94L Southern California Impreza Club Forum -- SCIC 7 01-22-2003 01:41 AM
HKS Super Sequential BOV rubbing against hood delo- Texas Impreza Club Forum -- TXIC 10 01-05-2003 05:07 PM
HKS Super Sequential BOV rubbing against hood delo- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-04-2003 07:07 PM
HKS Super Sequential BOV for WRX? karazyman Southern California Impreza Club Forum -- SCIC 13 12-23-2001 12:41 PM
