Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 07-29-2003, 10:20 PM   #1
Art Hazebrook
Member#: 32825
99 Impreza
white
Question PO325 Knock sensor circuit malfunction
Hi all, I'm a newbie w/ a 99 Impreza, 60k on the clock and a recurrent CEL=PO325.
1. Initially, the CEL would come on only under increased engine load (steep grades).
2. Changed plugs with OE NGK's. Discovered that the plugs hadn't been changed @ 30k.
3. Now the CEL (same code) comes on just driving down the street.
Are there any known problems w/ the knock sensor???
Thanks in advance
Art Hazebrook is offline   Reply With Quote
Old 08-20-2007, 12:34 AM   #2
newshoes99
Member#: 148454
2005 Legacy GT
Default cel knock engine for me
Altho I can't pinpoint exactly what I'm doing when it comes on I've got the same code.
newshoes99 is offline   Reply With Quote
Old 08-20-2007, 12:50 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....known issue for the older NA's....bad knock sensors...replace them and be
Old 08-20-2007, 01:15 AM   #4
newshoes99
Member#: 148454
2005 Legacy GT
If I replace it and it's not an issue anymore I'll be
Old 08-20-2007, 09:46 AM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
make sure you when you do replace it you torque it to the proper spec are you can cause damage to the sensor and have the same problem all over again.
Old 08-20-2007, 12:51 PM   #6
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
+1, I just replaced the knock sensor on my wife's Forester about 4000 miles ago. I lightly sanded the corrosion from the block with fine grit. I did not use a torque wrench, but the specs are like 12lbs., so I used a small socket wrench and tightened very little (snugly) after contact. No problems yet, CEL (also PO325) never returned. I figure to check it next oil change to see if it's loose.
surowrxa is offline   Reply With Quote
Old 08-20-2007, 05:27 PM   #7
newshoes99
Member#: 148454
2005 Legacy GT
Default Why
Is there something wrong with the car that causes the sensor to go bad or is the sensor just not well made?
Knock Sensor Circuit Malfunction and Lean Bank 1 . . . SubaruLover Normally Aspirated Powertrain 7 12-19-2007 05:10 PM
96 Legacy LSI po325 knock sensor location pistoljeff Service & Maintenance 3 08-15-2006 07:07 AM
pulled CEL PO325 knock sensor burnera Normally Aspirated Powertrain 9 12-17-2005 05:33 AM
P0325 - Knock Sensor Circuit Malfunction joltdudeuc Normally Aspirated Powertrain 4 05-31-2004 08:29 PM
P0325 - Knock Sensor Circuit Malfunction goobie Normally Aspirated Powertrain 3 09-04-2003 09:09 AM
