Old 07-30-2003, 03:55 AM   #1
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
Default cruise control light stopped working
I moved my cruise control switch from the cutout closest to the one closest to the door and now the little light doesn't work anymore. Anyone had a similar problem? It's not a big problem, it's just a thing to annoy me.
kami333 is offline   Reply With Quote
Old 07-30-2003, 11:42 AM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
have u check the led bulb to make sure it's still good? if so, did you pull a wire loose during the move?
vile is offline   Reply With Quote
Old 07-30-2003, 08:50 PM   #3
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
They arent LED's...they are tiny incandescent bulbs....they SHOULD be LED tho.
If you find a replacement, let me know, because one of mine is burned out
DDMan is offline   Reply With Quote
Old 07-31-2003, 11:49 PM   #4
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
If the cruise control system is still working, then the problem is the bulb or the Blue/red wire and it's contacts. A voltmeter ought to find the problem in a few minutes - or just measure the resistance across the cruise bulb pins - pins 1 & 6 of the connector to the switch.
Alan is offline   Reply With Quote
Old 08-01-2003, 05:28 AM   #5
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
Thanks, I will once I get it back from the dealer (failed safety inspection because the check engine light isn't coming on, bulb is still good).
Which ones are the 1 & 6?
Old 08-01-2003, 12:56 PM   #6
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
See the below wiring diagram - the connector pins are at the bottom. It's connector B161.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 04:42 PM
Check engine, traction control, cruise control lights tantric rex Service & Maintenance 0 07-08-2009 09:33 PM
Question about cruise control light and indicator light (2002) Xymox Newbies & FAQs 6 08-08-2005 01:52 AM
Question about cruise control light and indicator light (2002) Xymox Interior & Exterior Modification 2 08-07-2005 01:51 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 03:04 PM
