Old 07-30-2003, 02:56 AM   #1
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Default how to get wrx injectors to seal in EJ25 fuel rail?
to anyone who is using the injector adapters how did you get them to seal into the fuel rail? i replaced the wrx top o-ring with my factory legacy one and it still doesnt seal, i got 3 of the 4 i think but its still kinda sketchy for me, if anyone has any tips i would greatly appreciate it.
basically from the added height of the wrx injectors+adapters the fuel rail wont come straight down onto the injector, but even if i just push it straight in it doesnt seal, which i dont get cause the 0-ring is the same one that was just in there, but maybe the injector necks are diff sizes.
another thing to those running the rc440's, i know people have said they fit loosely but do they seal into the rail? once again it is probably different for my legacy but just wondering.
thanks
Ben
Old 07-30-2003, 09:39 AM   #2
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
I'm not sure if this will help you, but I have a used set of WRX fuel rails I will sell you. Let me know if you're interested.
lotusTT is offline   Reply With Quote
Old 07-30-2003, 10:42 AM   #3
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
I have the same question!!! can somebody answer this!!
Elliot
Elliot is offline   Reply With Quote
Old 07-30-2003, 12:25 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
IIRC, I was able to buy o-rings at a local hardware store that worked for me. It's been a while since I've seated WRX injectors in RS rails...
Old 07-30-2003, 02:09 PM   #5
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
I was able to use the stock o-rings of the RS injectors and use o-rings from OSH (Hardware Store). I had to lube to o-rings with a little grease so they went in without folding. I have the stock RS rings on one side of the rail and they're fine and no leakage. The other side on the other rail I used two o-rings per injector from the hardware store and I'm getting leakage under high boost. I tried one ring and the same issue was happening. I just said screw it and I'm getting a monifold off of a 99' since I had issue with my adapters.
seven881 is offline   Reply With Quote
Old 07-31-2003, 12:50 AM   #6
markus
Member#: 438
2004 STi
White on Gold
What adapters are you folks using? Rev-Lab? I hear hit-and-miss comments on these adapters and was wondering if they're worth it.
markus is offline   Reply With Quote
Old 07-31-2003, 01:31 AM   #7
inpreza kid
Member#: 3334
when buying injector o-rings, make sure you are getting fuel grade ones.
inpreza kid is offline   Reply With Quote
Old 07-31-2003, 01:58 AM   #8
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default fuel?
I've been told that they are all the same but if your not sure put some in a jar of gas for a few days.
milkman is offline   Reply With Quote
Old 07-31-2003, 02:29 AM   #9
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
it is tricky.. i know if you push really hard it just pops back out... but since you 3 out of 4 sealed it works... what i do it simply stick the injector into both inlets and bolt the fuel rail down very very loosely... then i wiggle the injectors into place as i would like them to seal and start bolting it down as you bolt the fuel rail down make sure that the o-rings are not kinked or are sealing in difference places... keep on bolting it down. once secure i turn the injectors slightly left and right and the orings should straighten out... the RC seal very well this way.. same with the WRX ones... or it could be your risers are too high...
HOK is offline   Reply With Quote
Old 07-31-2003, 11:13 AM   #10
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Mine were machined about 3MM out of spec and I had to bore out my intake manifold to make them fit. They also are never around which makes things more difficult. You're better off getting a 99' manifold since there about $150 using CarParts.com and they have no air assist valves too.
Old 08-01-2003, 12:41 AM   #11
PHATsuby
Member#: 13617
2001 Legacy GT back
thanks for the help guys, i guess i will just have to keep at it. and see what happens, so what is the best to use to lubricate to get them in so they dont kink or roll over?
maybe i will try and take the fuel rail off and put them in that way.
thanks again.
Ben
Injectors in Perrin fuel rails tight fit e-zee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-21-2009 06:25 PM
Do I need a WRX Fuel rail to run WRX injectors in an RS-T? Tattoo Collector Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-14-2006 09:06 AM
ok so i searched, wrx injectors in my00 fuel rail? need adapter? GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-12-2005 04:29 AM
stock injectors in perrin fuel rails??????? jared nelson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-13-2005 09:39 PM
getting wrx injectors to work in my 99rs rails?! White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 15 04-21-2004 07:21 AM
