Old 07-30-2003, 09:04 AM   #1
mechboy
Member#: 24692
1998 Legacy GT
Default engine knock...hydrolic tensoner or piston slap?
is there any tests i can do to determan which one it could be?or are there any other possable causes?
thanks
mechboy is offline   Reply With Quote
Old 07-30-2003, 01:23 PM   #2
Ken
Member#: 34
2005 WRX STi
World Rally Blue
On a MY98? My guess is that your timing belt tensioner is leaking and causing the knocking. My MY99 just had it replaced and it is way smoother sounding!
Ken is offline   Reply With Quote
Old 07-30-2003, 06:45 PM   #3
mechboy
Member#: 24692
1998 Legacy GT
ya the sube guy said like 30% chance its the hydro tightner 70% chance of piston slap....i can only notice the knock at startup when its cold
Old 07-30-2003, 11:19 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You can test the tensioners. Have you changed your oil lately?
Old 07-31-2003, 09:05 AM   #5
mechboy
Member#: 24692
1998 Legacy GT
how do u test the tensioner? what sort of load does it have and can u visably see it leaking if i remove timing cover?
Old 07-31-2003, 01:11 PM   #6
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default tensioner
I'd say it's most likely the tensioner. It needs to be removed in order to be tested.
You can possibly use a stethoscope to determine the source of the noise.
vvk is offline   Reply With Quote
Old 07-31-2003, 01:58 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Have you been changing your oil often? Thats the most common reason for the HLA to fail.
Some knocking...rod knock or piston slap? mtcs Built Motor Discussion 41 12-03-2012 05:47 AM
rod knock? bearings? timing belt? piston slap? Buggn' Out Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 01-12-2011 09:25 PM
possible piston slap or knock at cold start?? Flyin_Hayn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-31-2009 04:57 PM
06 sti engine knocking? piston slap? valves ticking? bboyjohn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-15-2008 11:40 AM
piston slap rod knock...engine overhaul baby_rs Bay Area Impreza Club Forum -- BAIC 3 12-25-2003 12:16 AM
