Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 07-30-2003, 09:44 AM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default clutch, before or after?
I know the general advice is to install the new clutch before the turbo install, but I'm just wondering how driveable the car will be without the new clutch. I have a modified JC Sports kit, running 4-5psi. My stock clutch has 50k miles on it. Will I be OK doing the break in of the kit (no hard driving) for a week or two? What's the worst that would happen from using the stock clutch? I imagine it will just put a lot of wear on it, and it will slip quite a bit, but it should still be driveable, correct?
lotusTT is offline   Reply With Quote
Old 07-30-2003, 12:39 PM   #2
Puckaveli
Member#: 1518
00 2.5RS
It depends on how bad your current clutch is now. If it doesn't slip now you be alright. It might start to slip once you get high into the revs or if you try and launch it hard. I don't think you will hurt anything if you just don't try and rape the car until you do the clutch.
Puckaveli is offline   Reply With Quote
downshift before or after a residential area turn? kenchan Transmission (AT/MT) & Driveline 5 03-24-2002 08:43 AM
Tap for boost gauge before or after IC Neil Wallerstein Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-29-2001 02:15 PM
Exhaust, before or after turbo? RS-LOVER General Forum Archive 1 03-05-2001 07:52 PM
Recall O2 sensor before or after MRT exhaust? Julian Normally Aspirated Powertrain 5 02-22-2001 07:09 PM
spats: Paint before or after on car? Darwin Interior & Exterior Modification 5 02-15-2001 09:19 PM
