Old 07-30-2003, 01:34 PM   #1
redhat778
Member#: 34184
02 WRX
Now with STI VII Swap
Default Absolute Pressure VS. Boost Pressure
Little bit confused guys.....tried search but I couldn't come up with anything. How do absolute pressure (MAP) and boost pressure relate. Bottom line here is what I'm trying to do. I just finished my water injection and I was trying to have it come on with spare soleniod w/UTEC and i'm trying to get it to come on when RPM's >3k TPS>70% and boost is greater then 12 psi. Thanks
Michael
redhat778 is offline   Reply With Quote
Old 07-30-2003, 01:47 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
Default Re: Absolute Pressure VS. Boost Pressure
UTEC user's manual - Parameter Constants
MAP Display allows you to select whether you wish to display the absolute pressure relative to 1 atmosphere or gauge pressure. IMPORTANT: This ONLY applies to the logger and dashboard map readings. Load points are always in absolute pressure.
Gauge pressure shows the difference in pressure between the tap point and the local atmospheric pressure. This shows the differential between the two, with the atmospheric pressure variable.
Absolute pressure is the pressure differential between the tap point and 14.7 (14.696) psi or 1ATM. This is a true measurement because you are going against a set standard while the relative pressure flopps around depending on the environment.
zaxrex is offline   Reply With Quote
Old 07-30-2003, 03:01 PM   #3
SysRq
Member#: 31347
() support your
/\ sysadmins
This is the TurboXS definition of absolute pressure which is not technically correct.
Absolute pressure is, well, absolute. Absolute pressure = gauge pressure + ambient pressure. When you run 1 bar of boost under normal atmospheric conditions, your absolute manifold pressure will be close to 30 psi.
What UTEC displays as absolute pressure is really absolute pressure - 14.7psi. What UTEC displays as gauge pressure, is really absolute pressure - ambient pressure (probably obtained from MAP reading with engine off, since UTEC lacks its own pressure sensor).
SysRq is offline   Reply With Quote
Negative boost pressure vs. Fuel Mileage Michael_Lobodzinski Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-18-2009 01:57 PM
Compression ratio vs. boost pressure? scubaracer Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-21-2002 04:28 AM
oil pressure vs boost presure thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-27-2002 03:23 PM
Safe Boost Pressure / Boost Controller and Chip SleeperWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-09-2001 03:27 PM
Theory: Compression Ratio vs. Boost Pressure 8Complex Normally Aspirated Powertrain 12 11-29-2000 05:30 PM
