Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 07-30-2003, 04:25 PM   #1
vividracing
Vendor Sales Rating: (0)
Member#: 6270
Only At
www.vividracing.com
Default 10 UTECS Instock With Switch
Vivid Racing has 10 UTECS instock for your 02-04 WRX. We are including map switches discounted on each purchase of a UTEC. Call and ask about our discounted EXPRESS shipping methods!
Normal price is $999+$89+$12 (shipping) - $1100
You Pay - $999 SHIPPED
More on the UTEC -
Plug-&-Play installation with OEM connectors
No cutting, splicing or additional sensors required
20 minute, do-it-yourself installation
End-user programmable via PC or PDA with HyperTerminal and serial cable
Fine tune the maps for your exact setup
Pre-programmed base maps get you started quickly and safely
Base maps for our Staged upgrade packages, dyno proven and road tested from the leader in WRX tuning
Don’t waste hours tuning just to get your car to idle and cruise decently
Maps can be e-mailed or simply downloaded then uploaded
Four (4) maps plus “stock mode” selectable with a flick of the switch
Create custom maps for street gas, race gas, nitrous, or whatever
No need to lug around a laptop just to switch between your programs
Fuel, ignition timing, and boost are programmable in 250rpm increments up to 9000rpm over 10 load sites
Complete ignition timing control
No need to worry about the factory ECU pulling timing anymore
Be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map
Fuel control
Controlled via MAF sensor signal offset
Tune stock and larger than stock injectors
Load reference
MAP (manifold pressure)
Closed loop boost control programmable via Throttle Position and RPM
No more re-adjusting the boost controller due to changes in temperature or altitude
Keeps boost low while in closed loop fuel mode for reliability
Knock control
Automatically retards timing when the knock is detected safeguarding against engine damage
Adjustable knock threshold, timing correction, and duration
On board data logging
Provides valuable information to assist you in tuning
Free software upgrades
Vivid Racing is a authorized TurboXS dealer and can warranty any problems you may incur with your products. ONLY buy from Authorized Dealers!
www.vividracing.com
[email protected]
480-966-3040
vividracing is offline
TurboXS Universal UTEC Remote Map Switch UTEC-SWITCH monSTIer Engine/Power/Exhaust 9 09-01-2008 01:39 PM
NJ: 04 STi UTEC 350$ with switch WrxWonderWagon Engine/Power/Exhaust 7 10-12-2007 09:14 PM
F1DYNO Huge UTEC Sale With MAP Switch Install And Tuning ! F1DYNO New England Impreza Club Forum -- NESIC 14 08-22-2005 10:06 AM
2003 UTEC with switch for sale dmastropwrx Private 'For Sale' Classifieds 8 03-07-2005 10:37 PM
problem with utec remote map switch bluespeed Engine Management & Tuning 4 03-24-2003 05:02 PM
