Old 07-31-2003, 12:22 AM   #1
Trizzle
Member#: 38039
1984 VW Westfalia
with EJ25 Power
Default Quick Survey - EJ22T guys, how much boost are you running?
Right now i'm around 7-10psi... just wondering what everyone else is running.
Also, I'm interested in fuel management/delivery setups.
Trizzle is offline   Reply With Quote
Old 07-31-2003, 12:11 PM   #2
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
I'm runing 7-10 PSI on a TDO4L only because I'm having issue with blowing out the spark on my coils. If that problem wasn't there I'd be running 15-16PSI on the TDO4L. I using the WRX fuel injectors with the parallel fuel rail mod and the Link+ to manage it.
seven881 is offline   Reply With Quote
Old 07-31-2003, 12:39 PM   #3
agent007kimball
Member#: 14215
I dont mean to hijack this thread, but do you mind my asking how much power you are making with the 2.2 block at 7-10 psi and what it would be making if it were turned up to 16 psi? Is this with EJ25 heads? Thanks!
agent007kimball is offline   Reply With Quote
Old 07-31-2003, 12:58 PM   #4
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
[Hijack]
I'm not sure what the power is yet since I'm not Dynoing it until the boost issue gets fixed. I'm running the EJ25 SOHC heads. The only reference I have is when Bill from I-speed mention that the car was pretty quick with only 7PSI and had more bottom end than a WRX even with the 7.7:1 compression. Go figure, I should have a dyno plot by the end August. 16PSI makes a big difference versus 7PSI and the boost hits really fast with the little TDO4L. I can't wait until the 18G or 20G goes on
[/hijack]
Old 08-01-2003, 07:26 AM   #5
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
I just got my turbo setup running today, I'm at 4psi right now. Stock injectors, Walbro 255 pump, S-AFC. Haven't hardly touched the AFC settings, but its definately a huge improvement! I need to finish up alot of things, and eventually install the Legacy Turbo injectors and I plan on running 10-12psi.
-Brad Weingartner
ChicksDigWagons is offline   Reply With Quote
Old 08-04-2003, 11:08 PM   #6
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
18 daily... more at the track...
HOK is offline   Reply With Quote
Old 08-05-2003, 08:13 AM   #7
ChicksDigWagons
Member#: 20508
1998 Red Wagon
Originally posted by ChicksDigWagons
I just got my turbo setup running today, I'm at 4psi right now. Stock injectors, Walbro 255 pump, S-AFC. Haven't hardly touched the AFC settings, but its definately a huge improvement! I need to finish up alot of things, and eventually install the Legacy Turbo injectors and I plan on running 10-12psi. Of course, this is an NA EJ22... Brad is blind.
-Brad Weingartner
Old 08-05-2003, 12:00 PM   #8
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
stock '93 turbo & motor w/Greddy FMIC
5-7psi around town
up to 13psi racing.....turbo can't push any more
Scoobyslack1 is offline   Reply With Quote
Old 08-05-2003, 12:19 PM   #9
Trizzle
Member#: 38039
1984 VW Westfalia
with EJ25 Power
5-7? i thought they ran more than that from the factory?
Old 08-05-2003, 12:30 PM   #10
Scoobyslack1
Member#: 2780
junk yards rule!
with my MBC and the loss of a little pressure through the FMIC in 1st & 2nd it will run 5psi at the lowest setting
Old 08-05-2003, 02:17 PM   #11
QfactorRS
Member#: 30495
Running 5 psi. Since yesterday thru a front mount IC, what a difference!! i love it.
I am waiting on the sbc-id to bump it up to 8-9psi depending on how well i can setup my fuel. then maybe even 10psi once i get the svx fpr (quoted $150 from NAPA) and an adjustable RRFPR.
I think the Nitrous intercooler spray may allow me to run a few more pounds without touching fuel.
I want a Link+ ECU for free/cheap
Q
QfactorRS is offline   Reply With Quote
Old 08-05-2003, 02:23 PM   #12
Scoobyslack1
Member#: 2780
junk yards rule!
Question
QfactorRS- RS block or EJ22T block?
Old 08-05-2003, 02:45 PM   #13
QfactorRS
Member#: 30495
EJ22T block with EJ25 SOHC heads and gaskets.
Oh Oh, i also want some cobb cams
Old 08-05-2003, 02:51 PM   #14
Scoobyslack1
Member#: 2780
junk yards rule!
why such low boost?.....I ran 10psi on my 1.8L ecu non-intercooled
Old 08-05-2003, 03:10 PM   #15
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
what would the cobb cams do for this setup... would a Port and polish be equivalent? How much are the cams... i'm always iffy about putting cams in the subie...
Old 08-05-2003, 08:42 PM   #16
TR
Member#: 28
1997 M3 Sedan
Check this post out
http://forums.nasioc.com/forums/show...hreadid=257174
currently running 9-10 lbs on EJ22T with DOHC heads...
TR is offline   Reply With Quote
Old 08-06-2003, 02:11 PM   #17
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
The turbo Legacy motor makes 8psi stock. Can we assume all the guys telling us they are running less then 10psi are using the not turbo high compression 2.2 short block?
It would have been really nice if everyone that posted would have listed just what engine setup they have since there are so many hybrids:
EJ22 Turbo Legacy Shortblock
EJ25 2000 RS SOHC Heads
Ludespeed Stage 50 turbo kit
80 psi
800hp to the wheels
738lb ft to the wheels
Brad
MY99 2.5GT is offline   Reply With Quote
Old 09-17-2003, 10:06 PM   #18
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
More fuel and fuel management I would definitely recommend. The stock WRX injectors are what? approx. 440cc? The stock (WRX) setup can handle 16 psi easy. There are plenty of WRX owners out there ditching their injectors for the pink STi injectors and whatever else. I don't know if they would actually be a direct fit or not for some of the people posting here. More gas = cooler temps
TyranosaurusWRX is offline   Reply With Quote
Old 09-18-2003, 10:46 AM   #19
Scoobyslack1
Member#: 2780
junk yards rule!
Brad
no, as I posted...stock '93 Legacy turbo motor & no need to run much psi around Chicago with the gas prices as they are now
Old 09-18-2003, 07:12 PM   #20
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
EJ22T shortblock
MY00 EJ25 SOHC heads
Garrett T3/T4
15 psi...
Fitz
www.Flat4racing.com
Fitz is offline   Reply With Quote
Old 09-18-2003, 10:19 PM   #21
Unsung Boxer
Member#: 37196
I kinda count for this poll. I am only at 4psi w/ stock fuel system, other than SAFC. I am running an EJ22na w/ EJ22t internals. We will see how long the block holds up, I have faith that it will.
-I will be running 10 PSI as soon as i get my Injectors.
-After this, i am looking into timing control, so i can hit about 12-14 psi.
-Jake
Unsung Boxer is offline   Reply With Quote
how much boost are you running? Chino Bling Texas Impreza Club Forum -- TXIC 52 10-22-2008 05:38 PM
how much boost are you running in all gears WRXBOOST10 Engine Management & Tuning 56 02-06-2007 07:51 AM
How much boost are you running? 2003 sedan Texas Impreza Club Forum -- TXIC 16 09-24-2002 12:29 PM
How much boost can you run on a stock WRX? Blue_2K2_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-09-2002 11:33 PM
How much boost are you guys running? HomerJay Normally Aspirated with bolt-on Forced Induction Powertrain 40 08-30-2001 02:38 PM
