Old 07-30-2003, 11:33 PM   #1
hys420
Member#: 18315
2008 STI ON ORDER
DGM - STILL WAITING!!
Default Is it bad for the springs/struts to leave car on stands too long?
Just wondering.. I'm kind of an amateur mechanic wannabe (did my resonator mod, shifter bushings, and new axle-back myself, planning on several more things ), I notice how much the wheels sag when I jack up the car -- if I were to attempt a more difficult mod that required me to leave the car jacked up for an extended period of time, maybe even overnight, is that bad for the springs/struts?
thanks,
hys
hys420 is offline   Reply With Quote
Old 07-31-2003, 12:50 AM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Overnight, no. If you were to pull your calipers and let them hang by the brake line, that would be bad. But leaving it on stands will not harm it.
Tim Sanderson is offline   Reply With Quote
Old 07-31-2003, 11:56 PM   #3
hys420
Member#: 18315
2008 STI ON ORDER
cool, thanks. just wanted to make sure.
Old 08-04-2003, 03:07 AM   #4
kidatari
Member#: 10441
Is it bad to do this for an extended period of time? Because i was thinking of leaving my car up on jackstands when I go deployed for 3 months, to keep the tires from flatspotting. Anyone?
-Josh
kidatari is offline   Reply With Quote
Old 08-04-2003, 12:17 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Put the jackstands under the control arms or hub. Springs are compressed and tires are off the ground.
BOV: Is it bad for my car? MADFASTI Off-Topic 19 07-08-2006 12:31 AM
is it normal for the rear end to be squirly? blackie Brakes, Steering & Suspension 18 04-16-2004 08:04 PM
Is it normal for the steering wheel to vibrate while braking? Hazdaz Brakes, Steering & Suspension 34 02-07-2003 11:30 PM
Good Morning.. Is it normal for the clutch pedal to have morning stiffy? PaulRex Tri-State Area Forum 6 12-04-2002 12:41 PM
How long does it take for the CE light to come on? 2yLiTe Normally Aspirated Powertrain 0 06-29-2001 05:28 PM
