Old 07-30-2003, 11:46 PM   #1
WRXBob
Member#: 12455
02 WRX
Default Stock radiator leaking
I noticed today that there is some discoloration/coolant deposit on one side of the radiator (where the plastic and aluminum fingers meet) I am sure that it is leaking but in very small amount. Any one car has this condition.
WRXBob is offline   Reply With Quote
Old 07-31-2003, 01:21 AM   #2
Ken
Member#: 34
2005 WRX STi
World Rally Blue
How is your coolant level after driving? Is it high to the brim - at least on my MY99, there is a tiny breather hole at the top of the overflow-tank where it could be leaking from. Otherwise a tiny crack somewhere on the radiator? A pressure test shouldn't cost that, then again, I had mine pressure tested 3 times and they still couldn't find anything.
Ken is offline   Reply With Quote
Old 07-31-2003, 02:46 AM   #3
WRXBob
Member#: 12455
02 WRX
The coolant level is way down at the "Hot" mark. This happen just recently, and I have lost some coolant. It is still under warranty, but I hope the dealer will not give me the run around. I do not want them to pressure test the whole engine. Chances are they might over pressure test and damage some thing else.
Old 07-31-2003, 04:55 PM   #4
no_rex_yet
Member#: 7351
04 330cic
This is a very common problem on 02 wrx's. The dealer should fix it without question.
no_rex_yet is offline   Reply With Quote
Old 08-02-2003, 04:08 AM   #5
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
I had a leak see arrow in picture. 02 WRX with 8000 miles
I wanted to get to the track so I pulled it out took it to a good radiator shop and the guy tightened up the crimps and tested it and it has been fine since
good luck
-Scott
cky211 is offline   Reply With Quote
stock t-stat + larger radiator OR lower t-stat + stock radiator? modaddict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 08-30-2006 03:19 PM
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
Radiator leak WRXterminate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-24-2003 12:11 AM
WRX Radiator Leaking WRX4FUN South East Region Forum 25 12-31-2002 04:30 PM
First it's radiator leaking, then clutch master cylinder resorvoir leaking, and then. davidm_sh Warranty Issues & SOA Problems 1 03-24-2002 01:43 AM
