Old 07-30-2003, 11:48 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Looking for Fuel setting using Silva injectors on a 2.5
Pretty much what the title says. I am installing my purple top 370cc injectors tomorrw and I would like some ball park settings to hlep me tune. Also what psi those settings are for.
Joshua
yebokmj is offline   Reply With Quote
Old 07-31-2003, 02:32 AM   #2
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
settings? on the link or S-AFC? i would say -30 on hte SAFC
HOK is offline   Reply With Quote
Old 07-31-2003, 09:11 AM   #3
yebokmj
Member#: 2213
Brilliant Red
Default Tuning with
Im using a HKS S-AFR. The percentages should be the same as that of the S-AFC though. And when you say -30 is that across the board or at a certain RPM?
Joshua
Old 07-31-2003, 11:38 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
might be difficult to find credible settings as i don't know of many ppl using a 97 2.2 ecu on a turboed 2.5
do you have an a/f gage?
Old 07-31-2003, 02:16 PM   #5
yebokmj
Member#: 2213
Brilliant Red
Default 2.5 ECU
I am using a 2.5 ECU. My swap was 100% plug and play. The 2.5 ECU just plugs right in to the harness. And the engine harness just plugs directly into the firewall harness.
Joshua
Old 07-31-2003, 06:38 PM   #6
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Like all things you should just take it as an estimate... -30 is about where i would think it would be at. your low rpm setting will be different. probably -20 or something. but you have to take this with a grain of salt because the ECU still controls itself about 20% +-. Also it totally depends on what setting you start at... some days after a reset i start at -20 and have to lean to -35 and others i start at -30 and lean to -45.
COBB!!! give me reflash!
Looking for a set of hubcaps for a 2003 2.5 TS 15" teedot23 MAIC Private Classifieds 0 05-04-2010 05:01 PM
Anyone ever maxed out fuel injectors on stage 2 freetors Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-29-2009 07:36 PM
2.0 Perrin Fuel Rails on a 2.5 Boxer112 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 11-09-2005 07:14 AM
Looking for parts and advice (utec/injectors/fuel pump + more) F3nrir Mid Atlantic Impreza Club -- MAIC 9 09-23-2005 11:19 PM
Newbie looking for info on Legacy 2.5 GT sedan... Eriksport Legacy Forum 21 04-17-2001 11:28 PM
