Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-31-2003, 01:40 AM   #1
atmosphere
Member#: 37641
98 Impreza 2.5 RS
Default Bad cooling system?
For some reason my radiator will never stay full. Before starting my car i have to remove the rad. cap and blow on the reserve tank to bring the coolant level up to where it should be. Now i know it is normal for the coolant to expand when it gets to temperature and fill into the reserve tank and be sucked back into the radiator once it cools and contracts. In my case its not being sucked back into the radiator after it has completely cooled down leaving the radiator low on coolant. I speculate that somewhere in the system air is being sucked in rather than maintaining a vacuum on the coolant. Anyone had or know of this problem?
atmosphere is offline   Reply With Quote
Old 07-31-2003, 01:07 PM   #2
fredj
Member#: 13735
2002 Outback Sport
Sedona Red
On my last car, a Toyota Tercel, I had a similar problem when the car got about five years old. The solution turned out to be a little bit of radiator stop-leak. I used a couple of large tablets I bought six on a card at the Chevy dealer, but anything from the auto store should do.
Since it is a small leak you dont need to load up the car with a whole package or can of stuff.
Fred
fredj is offline   Reply With Quote
Old 07-31-2003, 02:03 PM   #3
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Lightbulb radiator cap
You need to replace your radiator cap.
vvk is offline   Reply With Quote
Old 07-31-2003, 06:49 PM   #4
atmosphere
Member#: 37641
98 Impreza 2.5 RS
I did just replace my radiator cap, i starting having this problem so i purchased a new one put it one and it still somehow manages to ingest air. Is there anything else that can be causing this problem?
Old 08-01-2003, 12:51 PM   #5
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Dude, same crap happened to me...read my post on your overheating problem....
latinskllz is offline   Reply With Quote
Old 08-01-2003, 07:54 PM   #6
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
98 DOHC...it's likely not a leaky radiator or a bad cap.
I strongly recommend you have a very very very very very very knowledgable Subaru mechanic check out your engine ASAP
Albert is offline   Reply With Quote
bad bad bad apv2 stage problems and my car Louie AccessPort 28 04-17-2007 03:43 AM
Would a bad 02 sensor (P0037) make my car run bad? skimmilk68 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-04-2004 01:33 PM
Ack! How bad did I eff up my car? RaceCarRiot Normally Aspirated Powertrain 7 05-27-2003 11:55 AM
Audio fool- can hook up my home entertainment system subwoofer to my car? desiwrx02 Car Audio, Video & Security 5 09-22-2002 10:13 PM
Important: HOW BAD would this be for my car? adamsrs Brakes, Steering & Suspension 9 02-12-2002 02:12 PM
