Old 07-31-2003, 10:11 AM   #1
Puckaveli
Member#: 1518
00 2.5RS
Default Which wires to splice from the GC harness for a swap
This thread is started with the intention to determine which wires need to be spliced from the recipient bulkhead wiring harness. Hopefully with our combined knowledge, experience, and failures we can come up with something. Here are the pinouts for a 2000 2.5RS.
Links to the previously posted pdf files
Puckaveli is offline   Reply With Quote
Old 07-31-2003, 10:20 AM   #2
Puckaveli
Member#: 1518
00 2.5RS
I hope the few fine install shops on the board don't feel threatened by this thread. I don't want to take business from you and hope you can contribute to this thread, but not everyone has deep pockets to get their swaps done professionally.
Moderators: If you are worried about pages from the service manual being posted in here. Please let me know and we can take them down.
Obviously there are 100's of variables that will make every swap different, so before we start adding info we need to clarify the variables involved such as, which ecu, if all the sensors in the engine bay are being swapped, are the dash plus remaining, things like that.
I'm going to sit on the crapper now and write down some things.
Old 07-31-2003, 11:31 AM   #3
spiralsmurf
Member#: 16085
2005 STi
Awesome, now we just need to figure out which wires from the RS harness need to be spliced into the wrx one and what things the RS harness does not have that you manually have to wire, like the boost solenoid and fuel pump controller. and lastly, which wires from the WRX bulkhead harness need to be removed or not wired in.
spiralsmurf is offline   Reply With Quote
Old 08-07-2003, 10:08 AM   #4
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
BUMP - I want this thread on my email list.
How about 99 rs diagrams also.
Anthony C
Bobalouy is offline   Reply With Quote
Old 08-07-2003, 02:06 PM   #5
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Well, I will flap my gums and give my 2cents, since it has been ridiculed before
Generally, this method is what I use once you have separated the engine wiring from the swap dash harness (JDM/Wrx) . Most of what you need to separated does not have to be cut, that is from the ecu to the engine. Some stuff you may have to cut to separate from the dash harness such as the O2 sensor , speed sensor, rad fans, main relay power, ecu back up power , ignition switch, start switch, tacho, cel , water temp gauge, oil pressure gauge...to name a few. What you will find once you do all this, is that you basically have a stand alone engine harness. And most of the wires you have cut , can be spliced into your stock RS harness at the ecu connectors, such as tacho, ecu main power/back-up power, fans , cel , main relay control...etc. Some power wires you will have to tap off the stock main relay. As well you will have to tap into the stock engine connectors for the water temp/ oil pressure and cluster ground.
If you do it this way, you do not have to rip out the stock harness nor take out the dash. If the car ever had to be converted back, all the stock RS connectors are still there to use.
Ver.III is offline   Reply With Quote
Old 08-07-2003, 05:12 PM   #6
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
That would probably be the easiest way to do it... And after that, if you wanted to clean it up abit you could remove the wiring little by little.
HeMan1320 is offline   Reply With Quote
Old 08-09-2003, 08:03 PM   #7
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
yes i am going to start doing this swap in a few days once the motor gets here.
If we can try and get this finished before i have to start wiring that would be great.
I will also try to help as much as i possibly can with this.
THanks
Billyqua
rally driven.............
RS22b is offline   Reply With Quote
Old 08-13-2003, 06:09 AM   #8
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
I can help with your 2.5rs 99 wiring needs. I can help you guys if you want to pm me I can give you what wires need to be spliced and where and so on. Just did all my wiring on my 2.5rs to JDM WRX about a month ago still remember it all. I used JDM ECM so I know how everything works US and JDM. I have JDM diagrams as well and manuels. Just let me know what you need or what info and I can help you! Also version 3 you have to remember differences between years of JDM cause you can not use 2.5rs cluster to run speedo and odometer and speed signal to ECM. This is mechanical and you will need a mechanical speedo to send the signal to the ECM or car will go in limp mode and shut off at 4300RPM's. This is on years 95 and below and random years and models from then on. Very good info though version 3.
AWJunkies is offline   Reply With Quote
Old 08-13-2003, 07:00 AM   #9
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
I will be able to help with the MY00/01 stuff....working on the schematic as we speak...
Bill
Old 08-14-2003, 10:44 PM   #10
Liquid02rs
Member#: 33038
do you guys plan on usuing factory ECU's?
I'm working on something that will be relativly painless for guys with P&P ECU's like link.... it involves a little bit of machining.. but too painful.
Liquid02rs is offline   Reply With Quote
Old 08-14-2003, 10:45 PM   #11
spiralsmurf
Member#: 16085
2005 STi
yeah just factory usdm ecus that way the swaps are legal.
Old 08-17-2003, 05:05 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
All bright yellow wires are abs wires, right?
-Jon
Old 08-17-2003, 10:28 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hey puck could you change the images above to links instead.. this thread is way too important to load this slow
-jared
yellowflexloom? or yellow wire
Old 08-18-2003, 01:03 AM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Yellow flex loom, sorry.
I would tend to agree with Jaxx. It is kind of annoying loading all those images every time.
-Jon
Old 08-18-2003, 09:58 AM   #15
Puckaveli
Member#: 1518
00 2.5RS
Man you guys are picky. I put a link above to our local forum where they are hosted.
Old 08-18-2003, 10:48 AM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
your kidding right...
be sure to
A plug the battery in
B have some one you don't like sit in the drivers seat
when playing with yellow flex loom (air bag)
or perhaps it is the other way around
Old 08-18-2003, 02:05 PM   #17
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Who is playing with the airbags? I'm talking abs lines here. Yellow flex loom, to my understanding, are the abs wires and would therefor be unneeded for my car since it doesn't have abs in the first place.
-Jon
Old 08-18-2003, 02:24 PM   #18
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
-Jon
all YELLOW lines are indeed Airbag specific....
Bill
Old 08-18-2003, 03:06 PM   #19
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Ok, thank you for clearing that up.
-Jon
Old 08-19-2003, 11:25 AM   #20
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I've spent some of the morning pouring over the wiring diagrams and I am noting some issues.
Some connectors are explicitly listed on pages giving some, if not all, of the pins and their associated wires. To find the associated wires, one must just look at the wiring diagram in the immediate area. However, there are others that indicate a given connector but make no mention of the pin orientation or wires passing through. For these connections, one must hunt through ALL of the wire diagram pages searching for either of the connector IDs.
How about a specific example? Connectors i10, i11, and i12 all have almost every pin explicitly defined in the associated combination meter wiring diagrams. Some pins must be sought by looking at the ground diagrams; but, it is largely complete. Pin i59 has everything defined right in the clock wiring diagrams. However, connectors i1 and i2 don't have more than 1 pin defined in any portion of the diagrams. You must search through all diagrams and find all references to i1 and i2 (or the corresponding b36 and b37) to decrypt the wires in use.
Am I overlooking something or is that just how the manuals are laid out?
-Jon
Old 08-19-2003, 01:09 PM   #21
spiralsmurf
Member#: 16085
2005 STi
why are you wiring in the clock? don't you just need to find all the engine related wires and separate them?
Old 08-19-2003, 01:19 PM   #22
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
*This is for a MY03 wiring harness
If you look at the WRX wiring diagrams, you will note that connectors i10, i11, and i12 pertain to the gauge cluster (relevant to my swap), i59 goes to the in-dash clock (used just as an example), and i1 and i2 go to the bulkhead wiring harness (which is relevant for all).
-Jon
Old 08-19-2003, 02:19 PM   #23
Puckaveli
Member#: 1518
00 2.5RS
Will the 03 instrument harness plug into the 00 bulkhead harness? I doubt it but........If the plugs match you would just need to rearrange some pinouts on the 00 harness.
I don't have 03 diagrams so I'm in the dark what the layout is, but the 00 instrument panel harness has two plugs for the cluster, two for the bulkhead harness and a plug for the hazards and rear defrost. So your question is what are the pinouts for plugs i1 &i2 which go to the bulkhead harness on the 03 harness? You should just be able to follow the wires from the other end of the instrument panel harness plugs to find out what they are, the colors shouldn't change.
Old 08-19-2003, 02:39 PM   #24
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
People are misinterpreting my post.
I am not asking how to wire up the clock, I can figure that out on my own as that is the most straightforward of all the diagrams I have looked at thus far. I am not asking if I can just bolt in my MY03 cluster harness into my car because I don't have a MY00 anything (I have a MY96) and because I know it won't match up since I am converting from a mechanical gauge cluster to a digital one.
The purpose of my post was to get an understanding of the organization of the wiring diagrams, not for specific help on specific wires. In looking at some of the diagrams, regardless of WHAT we are trying to wire up, some of the pin outs are not included in the initial diagram, but elsewhere in other diagrams. This is what I am trying to verify. Also, I would like to know if there is some logical procedure for finding the pinouts for a certain plug aside from doing a search for all references of a plug name; ie: i1 or b36 or any others for that matter.
For the record, I AM putting the WRX clock in my car because mine doesn't have one in the dash like the newer Imprezas. I apologize for the confusion in the thread but I'm asking for help in only understanding all the documentation I have. Please try to disregard the specific information in my examples and read it as help in understanding the wiring. There is a very high probability that I may be the only one in a specific situation and so I am trying to avoid asking specific questions that nobody could really answer.
Just a little FYI, the MY03 cluster harness has 7 plugs total, 3 green ones going to the cluster itself, one white one going to the clock in the dash, one white one going to the hazard light switch, one white one going to part of the bulkhead wiring harness, and one brown one going to part of the bulkhead wiring harness. So, no, it won't plug into the MY00 bulkhead wiring harness.
I can post links to a couple shots of diagrams showing my dilemma if anybody would like.
-Jon
Old 08-19-2003, 03:05 PM   #25
Puckaveli
Member#: 1518
00 2.5RS
I'm sorry I missed the detail of your question. Let me follow something in the my00 diagram and see if it helps.
If you follow the ignition coil back from the the coil itself. E12 is the plug that plugs into the coil, then if you follow the 4 wires back to E3 which is the plug from the engine harness that plugs into the bulkhead harness, plug B22, it has the pinouts for B22 - 4,5,6,&14, then from there one wire goes to the previous page, follow E, the other three wires go to the ECU. It gives the plug numbers and pinouts there; plug B134 pinot25,27, & 26.
They don't give the pinouts for E3 because the colors don't change so you just need to follow the wires.
If you already know everything I just explained then I'm sorry I couldn't help. I don't know your level of knowledge so I'm trying to keep it simple as possible so please don't take it as I'm to label you as a simpleton.
wtb full 02 wrx wiring harness for 99lgt swap supernick77 Private 'Wanted' Classifieds 4 04-09-2009 03:10 PM
Which wire to the ECU id the MAP wire? renhoek Pre-2002 Factory Turbo Powertrain 2 12-08-2008 01:10 AM
Which wire to use for the amp turn on lead? '04 WRX Phylomatic Car Audio, Video & Security 27 04-21-2008 03:43 AM
Argh! Which wire to use for remote turn on lead? shawndoggy Car Audio, Video & Security 4 01-07-2002 12:30 PM
