Old 08-19-2003, 04:20 PM   #26
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
That is the sort of thing I was looking for.
So they don't necessarily give pins for non-terminating plugs? Is that how I am understanding that?
For instance, if we want to find out what pin 1 is on connector E12 (assuming we don't know anything about E12), then we follow the blue wire (L = blue) up to pin 5 on connector B22, then follow the yellow wire (YL = yellow) up to pin 25 on connector B134 (I think, it's hard to read that pic). On B134, if I am not mistaken, we are then told all the pinouts. Yup, pin 25 on B134 is "Ignition control", #1, #2 as per the pinouts for the ECU plugs. Now with that information, we know that pin 1 for E12 goes to the ECU which, in turn, fires the coil. If we had a pin layout of connector E3, then we would also know that the corresponding pin for it would be the one that matches up to pin 1 on E12 and pin 5 on B22. Then we could say that pin xx for E3 is the "Ignition control".
More or less, we have to reverse engineer the wire harnesses rather than have the pinouts for ever single connector listed.
Thanks,
-Jon
Old 08-19-2003, 05:31 PM   #27
spiralsmurf
Member#: 16085
2005 STi
i don't mean to sound dumb....but can't you just take the ecu pinouts and mark off the wires you need and then do the same on the car and find out which ones need to be spliced. then whatever your MY96 doesn't have you just add.
spiralsmurf is offline   Reply With Quote
Old 08-19-2003, 10:09 PM   #28
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Depending on what model Subaru, most of the cluster wiring is in jiberish whether it is done purposely or not. I found that some of the labelling of the cluster on diagrams do not necessary correspond to the actual plug pin-out. Aside from that, the engine diagrams are straight forward.
Ver.III is offline   Reply With Quote
Old 08-23-2003, 06:28 AM   #29
scoobynation
Member#: 40487
my question is...if you had for ex:ralli spec do all your wiring harness needs,will it pretty much be like a plug and play ordeal or will there have to be more splicing...oh and i plan to go with the ej20T.
scoobynation is offline   Reply With Quote
Old 08-23-2003, 01:35 PM   #30
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I have heard no mention that Rallispec, or anybody for that matter, will build a completely plug and play wiring solution for factory engine management. There are some that will provide solutions for aftermarket engine management, though. Rallispec typically wires the car while it is in their posession.
-Jon
Old 08-23-2003, 03:59 PM   #31
spiralsmurf
Member#: 16085
2005 STi
i'm sure you can send them a wrx wiring harness, they'll take out the unnecessary wires, add the ones the RS doesn't have and tell you which wires to splice into the RS harness. this really isn't that difficult of a task in concept, but i think unless you've done it before it is a rather tedious task.
Old 08-24-2003, 08:28 PM   #32
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
What are people doing about the fuse and relay boxes? I'm trying to decide if I want to use the WRX boxes or use my L boxes. I think that switching the boxes is a serious headache waiting to happen.
-Jon
Old 08-24-2003, 09:25 PM   #33
spiralsmurf
Member#: 16085
2005 STi
Rich (Ver. III) is not around, but i'll answer that question because i already asked him; there's no need to switch fuse boxes.
Old 08-25-2003, 01:11 AM   #34
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I haven't compared the fuseboxes to know what one has and the other doesn't, but hypothetically, if we come across a wire that goes to the fusebox, but doesn't have a spot in the existing box, I would assume we try to locate a blank spot? Splice into an existing fuse? I don't have experience with this yet, I'm just throwing stuff around.
-Jon
Old 08-25-2003, 01:52 AM   #35
spiralsmurf
Member#: 16085
2005 STi
i really think that would be easier than switching fuseboxes like I-Speed does, thats why their swaps take so long.
Old 08-26-2003, 04:10 PM   #36
Ver.III
Member#: 1185
I flap my gums
For powering the ecu / engine , you just use the existing main relay and fuel pump relay. So there is no need to swap fuse boxes.
Old 08-26-2003, 04:28 PM   #37
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
That saves a lot of hassle in doing that. I would gladly eliminate all that extra stuff in there and use what I have.
-Jon
Old 08-26-2003, 08:53 PM   #38
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
So the word is about 30 wires to splice from the RS harness into the WRX engine harness to get the car running. Correct?
HeMan1320 is offline   Reply With Quote
Old 08-26-2003, 10:24 PM   #39
spiralsmurf
Member#: 16085
2005 STi
like 20, plus some you need to add soem things the RS doesn't have.
Old 08-27-2003, 01:10 AM   #40
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
does anyone know the exact wires that need splicing? I'm not looking for the exact pin-out just the fucntion of the wire itself. It might be easier that way with all the different harnesses out there.
Old 08-27-2003, 01:31 AM   #41
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
wtb full 02 wrx wiring harness for 99lgt swap supernick77 Private 'Wanted' Classifieds 4 04-09-2009 04:10 PM
Which wire to the ECU id the MAP wire? renhoek Pre-2002 Factory Turbo Powertrain 2 12-08-2008 02:10 AM
Which wire to use for the amp turn on lead? '04 WRX Phylomatic Car Audio, Video & Security 27 04-21-2008 04:43 AM
Argh! Which wire to use for remote turn on lead? shawndoggy Car Audio, Video & Security 4 01-07-2002 01:30 PM
