Old 07-31-2003, 11:46 AM   #1
WorldTour
Member#: 35770
1996 Legacy L RHD
Ugly Green
Question AT OIL TEMP Light flashes
ok, every time I start my car the AT OIL TEMP Light flashes 16 times. Before I go spend money to have it diagnosed I was wondering if anyone has info on what the root cause is.
Oh yeah, the car is a 96 Legacy L, ATX, AWD, RHD.
any helps is appreciated!
-Mark
WorldTour is offline   Reply With Quote
Old 07-31-2003, 12:55 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
That "AT Oil Temp" light flashes because there is a problem with one of the sensors in the transmission. The TCU has stored this code, and is waiting for someone to pull it, verify the problem, and fix it. Once the problem is fixed, "AT Oil Temp" light will go away.
Legacy777 is offline   Reply With Quote
Old 07-31-2003, 12:59 PM   #3
WorldTour
Member#: 35770
1996 Legacy L RHD
Ugly Green
Well, I have figured that much out, but it flashes 16 times, usually when a specific amount or pattern flashes it symbolises what code the TCU/PCM has stored. Thats my question, what is the 16 representing.
-Mark
Old 07-31-2003, 03:16 PM   #4
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Check your ATF Fluid level.
Put the parking brake on, and shift it to neutral.
Start the engine and go under the hood to see what the fuid level is.
Chances are it's low.
JoeT is offline   Reply With Quote
Old 07-31-2003, 04:54 PM   #5
Legacy777
Member#: 4800
-Mark
16 doesn't represent anything. It is the default number of blinks when there is a problem. The first gen OBD 1 computers are the same.
On the older cars when you could diagnose the problem with the blinking light, you would have a long blink followed by a short blink. Long blinks indicated ten's place, short blinks indicated one's place
Old 07-31-2003, 04:57 PM   #6
WorldTour
Member#: 35770
1996 Legacy L RHD
Ugly Green
OK
AT oil temp light flashing chuckles Transmission (AT/MT) & Driveline 53 08-04-2014 11:29 PM
Flashing AT oil temp light thejunkman55 Normally Aspirated Powertrain 3 10-19-2009 11:34 PM
Flashing AT OIL TEMP light - need help jeep_kevin Forester Forum 4 10-05-2004 04:59 PM
Flashing AT Oil Temp light? Hit Man X Transmission (AT/MT) & Driveline 10 08-15-2003 10:01 PM
AT OIL TEMP light flashes at startup... BoardRider Legacy Forum 3 04-21-2003 10:31 PM
