Old 07-31-2003, 12:23 PM   #1
pdlindor
Member#: 7446
2002 Impreza RS
2009 Forester Limited
Question Effect of wider wheel? (same diameter and weight)
I'm looking at getting the ASA LW5 wheels in 16x7.5. The weight on these is 16.3 lbs vs. 16.5 (I've heard) for the stockers.
My question is: will the wider rim increase rotational inertia the same way that a taller (i.e 17/18") wheel would? I'd like to avoid too much resistance if at all possible seeing as how my car came without one of those turbo-thingies.
Thank you!
~Paul
pdlindor is offline   Reply With Quote
Old 07-31-2003, 10:25 PM   #2
mch
Member#: 30039
2002 wrx wagon
dirt slvr
no
mch is offline   Reply With Quote
Old 08-01-2003, 12:01 AM   #3
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
You're oversimplifying it. Two wheels of the same weight can have that weight located in different places. It's perfectly conceivable that two wheels that are the exact same width, diameter, and weight, could have drastically different rotating inertia because of where the weight is located. There's really no way of knowing unless you're talking about multi-piece wheels and you can weigh the seperate pieces. However, I think you can assume that for a "normal" wheel the difference will be very, very small by adding an inch of width.
Macabre is offline   Reply With Quote
Old 08-01-2003, 11:03 AM   #4
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
there will be very little if any changes in the rotational interia of the 2 wheels in question .... now, if you were Mario Andretti in one of those F1 type cars you might feel some sort of difference or might not ... I wouldn't worry about it ....... pull the trigger and enjoy your better looking bhetter performing new wheels and get a set of 225/50-16's to go with them
wheel linky
want to know effect of wider trackwidth with steelies eraser_rx Brakes, Steering & Suspension 3 06-16-2009 10:46 PM
new wheels same diameter, do i need alignment? NorCalSubie07 Brakes, Steering & Suspension 12 06-12-2008 03:17 PM
Calculating the effects of larger wheels and tires, and loss in performance Yoo Shin General Community 25 10-10-2007 10:51 AM
effects of varying intake pipe diameter? (pre and post turbo) happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 02-17-2006 08:24 PM
Effect of different wheel/tire sizes on roller dyno's mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-23-2002 12:49 AM
