Old 07-31-2003, 03:23 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default swapping crossmembers
ok, i go under my car to look around at the crossmember for when i take it off and i notice the steering rack. do i need to take it off to remove the crossmember? what do i do?
Brent
scoobyimprza is offline   Reply With Quote
Old 07-31-2003, 03:29 PM   #2
Puckaveli
Member#: 1518
00 2.5RS
you just need to undo the lines into the rack, unbolt it from the crossmember and slide it out of the universal joint it should drop down far enough to move the crossmember out. Before you remove the universal joint make alignment marks on the input shaft and the universal joint so when you put it back in the steering wheel will still be straight. It's also a good time to upgrade those steering bushings too. There might be something I'm forgetting. I'll look at my manuals and see.
Puckaveli is offline   Reply With Quote
Old 06-22-2004, 03:46 AM   #3
D Spec Dc2
Member#: 37604
95 Sti
Just Secret Gold
do i need a cherry picker to swap the crossmember?
D Spec Dc2 is offline   Reply With Quote
Old 06-22-2004, 08:54 AM   #4
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
2002 Dragon slayer :)
I dropped my steering rack, unbolted the "A" arm anti-roll bushing and the screw point in front of it because the x-member would not come off. I slid the xmember out the passenger side wheel well. The steering rack you have to drop down completely to make it easier on yourself to install the xmember. Make sure you don't bent/puncture the CV boot.
Cheers!
~Anthony.
WRX 555 STi is offline   Reply With Quote
Old 06-22-2004, 09:26 AM   #5
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default This might sound like a silly question, but...
If you're going to swap X-members, would'nt that mean you're swapping engines & the crossmember is to allow the headers to clear? That would suggest that you already have a cherry picker to move the motor. (Unless you're really strong) Or the motor is already out.
tbd is offline   Reply With Quote
Old 06-22-2004, 10:25 AM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, you need something to hold the engine. An engine hoist works, or what I did was just jacked the engine up from infront of the oil pan. Get it up so the studs clear the crossmember and you should be okay.
Brent
Old 06-22-2004, 11:57 AM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Wow, I just noticed this was my thread from last July. I did this the first day I started the turbo. Good luck with the swaps!
Old 06-22-2004, 02:33 PM   #8
D Spec Dc2
Member#: 37604
95 Sti
Just Secret Gold
i'm not doing an engine swap but just changing out the crossmember. i already dropped the steerring rack but i'm havent taken out the crossmember yet. i just wanted to check to see if i needed an engine lift. so a jack would work right in front of the oil pan? or on the oil pan with wood?
Old 06-22-2004, 02:53 PM   #9
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
are u pulling the motor or what? I took my RS engine out and put the sti in. I pulled engine, un did the universal gold steering connector, then undid the tie rods and control arms and took the whole thing out. Set it on the grass, took the steering out, installed it in the turbo legacy crossmember, bolted it back up. Installed the whole unit back into the car. Then dropped sti in
ImprezaRSfan! is offline   Reply With Quote
Old 06-22-2004, 03:09 PM   #10
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Yes i would get an engine hoist. I don't particularly like the idea of my motor teetering on a jack by the oil pan.
Soon2Bgreat is offline   Reply With Quote
Old 06-22-2004, 03:21 PM   #11
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Don't jack it on the oil pan. You'll see in front of the oil pan, on the engine itself, a great place to jack it up.
Brent
Old 06-23-2004, 04:29 AM   #12
D Spec Dc2
Member#: 37604
95 Sti
Just Secret Gold
in front of the oil pan is the header
Old 06-23-2004, 04:50 AM   #13
tbd
Member#: 15322
1995 gf wagon
you mean you're running turbo headers?
are you replacing a turbo cross member w/ another turbo crossmember?
or an NA X-member w/ a turbo crossmember?
How did you run the turbo headers on the NA style crossmember?
Old 06-23-2004, 11:21 AM   #14
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Take the headers off then. If you don't want to, then you can use a engine hoist.
Tranny swap- which crossmember? xcntrk75 Transmission (AT/MT) & Driveline 3 12-15-2004 03:23 PM
Crossmember swap I_smoke_hondas Transmission (AT/MT) & Driveline 11 02-08-2004 03:34 AM
what crossmembers do I use for turbo swap? scobaru Subaru Conversions 2 09-22-2003 05:08 PM
Turbo crossmember swap ?'s serious Legacy Forum 4 01-08-2003 02:10 AM
Engine Crossmember Swap (NA->Turbo) stimpy Normally Aspirated Powertrain 3 02-07-2001 06:46 PM
