Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Old 04-02-2001, 01:08 AM   #1
Member#: 423
2002 WRX wagon
Post G-tech Pro Result on 92 Legacy Turbo!!
Hi Guys(Gals), just tested my car with G-tech Pro this afternoon.
It shows that my car have 150hp in lower boost and 170hp in higher boost.
I input 3333lb for my car with half tank of gas, few stuffs in my trunk, one 150lb driver and without spair tire.
The car is 210987km now with WRX intercooler,Apex-i AVC-R turbo boost controler and set to lower boost at .85kg/mm and the highest boost at 1.15kg/mm(never reach to this limit) and the car has few boost cut occure at the lower boost setting!
My car with 205-55-15 Dunlop Sport SP W-10 and redline from 1st gear to 3rd gear. I have no exhaust mods just run with stock exhaust.
I run each setting in the same road condition 3 times(6 times total 3 lower boost and 3 high boost), also the road has little bit uphill. In the low boost result, it has 148hp, 157hp and 151hp. At the high boost, it shows 174hp, 168hp and 177hp.
Guys Its so great that I has 150hp-170hp on wheele, and its little more then what I expect.
Ben is offline   Reply With Quote
Old 04-02-2001, 09:10 AM   #2
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
You gotta remember that the G-Tech thinks your car only has two drive wheels, not 4.
Sunrise City Rider is offline   Reply With Quote
Old 04-02-2001, 09:31 AM   #3
Member#: 2348
2006 WRX TR
Steel Grey Metallic
The G-tech reads HP based on accleration, it doesnt car if you have 2, 4 or 6 wheels driving, so its saying you have 177max to the wheels! Nice. Those are great numbers, must be a fun little car.
STiShawn is offline   Reply With Quote
G-Tech Pro results on turbo RS blaster88 Normally Aspirated with bolt-on Forced Induction Powertrain 13 06-23-2001 11:02 PM
0-60MPH time on 92 Legacy turbo!! Ben Legacy Forum 1 04-02-2001 07:20 PM
0-60mph time on 92 Legacy turbo!!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2001 05:55 PM
G-Tech Pro Result on my Legacy Turbo!! Ben Legacy Forum 1 04-02-2001 09:56 AM
G-Tech Pro result on 92 Legacy turbo!! Ben General Forum Archive 1 04-02-2001 04:29 AM
