Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 07-31-2003, 03:28 PM   #1
8Complex
Member#: 922
04 FXT
Red
Default Very confused... vehicle changes vs. tuning issues...
So a week or so ago I had to replace my clutch fork (cracked one of the prongs nearly off it!) and I got convinced by a friend to install my street spec cams that I've had laying around. There is less overlap and the lift is higher, so I figured I'd be lean.
I was out tuning all last night and for the life of me I can't figure out why I'm so damned rich all over the place. It was so bad that after I got off the gas, I'd POUR smoke from the tailpipe burning excess fuel. I used my near-WB meter to bring it off 10:1 (obviously innaccurate, probably was richer) to around 12:1 and got pinging all across the map! Previously I had run the car around 12.7:1 across the map until around 6k where I richened it up to about 12:1 or so -- and I had no pinging.
So the jist of it is, I add cams, run far richer AND have to pull timing... what gives??
Old 07-31-2003, 03:47 PM   #2
Paul H
Member#: 21842
2004 WRX Wagon
Black with Dents
I may be way off base but did you check the trigger positions after the new cams were installed?
Paul H
Paul H is offline   Reply With Quote
Old 07-31-2003, 04:43 PM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
that's what I was thinking... a timing issue.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-31-2003, 05:45 PM   #4
8Complex
Member#: 922
04 FXT
Red
Trigger positions? I run the stock triggers, and I'm quite sure that the stock timing belt went on correctly (as I've done it many many times). I know it's quite impossible to put it on backwards as well since the teeth/marks would be off.
Old 07-31-2003, 06:40 PM   #5
Paul H
Member#: 21842
2004 WRX Wagon
Black with Dents
Is there not a cam position sensor? Again I may be way off but could you have put the new cams in but not orientated the way the stock ones were. I am a bit out of my depths here but I remember reading at the Haltech yahoo support site of a guy having similair problems.
Double check you setup in the haltech as I have heard of the settings mysteriously change after modifications have been done.
Paul H
Old 07-31-2003, 07:42 PM   #6
8Complex
Member#: 922
04 FXT
Red
Not really... the cams have notches in the end to assure the cam pulley is on only a single direction, the cam sensor only fits in one way and can't move in it's bore more then 1/32" if that, and the belt is on right.
The car had already needed a valve lash adjustment before I put in the cams, and got it after that from our resident Subaru genius.
Perhaps with less overlap it is scavenging much less exhaust gasses, and that was helping in deter detonation? I'm quite guilty of tuning my car one step back from detonation, so I suppose if that was the case, it'd be likely... I still don't understand the fueling issue, though.
Old 07-31-2003, 08:05 PM   #7
Paul H
Member#: 21842
2004 WRX Wagon
Black with Dents
I think that you should try over at yahoo. Check your settings for your trigger first though. It is a long shot but you never know.
Good luck!
Paul H
Old 08-01-2003, 02:01 AM   #8
8Complex
Member#: 922
04 FXT
Red
Well, I think I may have figured a thing or two out, but I haven't done the math as to how they're related.
When I reinstalled the kit, I was fairly sure I was going to have an uppipe leak (yes, aftermarket RS-T kits can have those!). I am thinking that is possibly skewing my results at the A/F gauge, and also probably has some effect on intake airflow.
I managed to get off a run tonite through 4th gear that showed my A/F's right where they should be for my tune... but DAMN was the car pulling like a banshee.
I also put a .109" restrictor in the oil feed, but I will be putting an even smaller one in there after talking to someone about the size of the hole in the banjo bolts of a WRX feed. I will try .063" and see how that works. Note that the stock diameter of the -4AN line is .175" so it's pretty significant of a drop. (in case you're wondering about all the oiling talk --> link)
Old 08-01-2003, 02:41 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
glad to see you are satisfied with the results
Old 08-01-2003, 04:35 AM   #10
8Complex
Member#: 922
04 FXT
Red
Yeah, and after pulling timing. *shrug*
Man do I hate this car. It makes every little thing difficult.
Old 08-01-2003, 10:20 AM   #11
digitaltekniq
Member#: 18029
If it was easy it wouldn't be worth the effort - you know you love it
digitaltekniq is offline   Reply With Quote
Old 08-01-2003, 11:10 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
that's what i keep telling him
nick remember now with the cams your cylinder loads are higher which means you can't run as much timing, but it takes less timing to make the same if not more power due to the higher pressure in the combustion chamber. i told ya you'd need to retune it. just think of how quiet your motor is now though
jeremy
Old 08-01-2003, 11:53 AM   #13
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I was amazed at the difference my cams made on my natty RS. I purchased the cams with the idea that I was going to boost with them; although it never happened. It is good to hear from somebody else who got it going. I know Jon Bogart said it made a big difference on his car.
Cams are cool. 'Nuff said.
Unfortunately, it doesn't look like Trey recommends doing anything with the WRX cams unless you convert to a shim under bucket design ($$). Maybe I'll just have to source some STi heads in a year.
-Jon
Old 08-01-2003, 01:16 PM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
-Jon
or you use the one piece shim/bucket
Very Confused about 225 45 r 17 horf Tire & Wheel 1 05-30-2005 03:10 AM
What changes in tuning for 92 vs. 100 octane? scooby24 Engine Management & Tuning 11 03-23-2005 05:09 PM
Very confused about speakers... x Neo x STi Forum Archive 16 07-08-2003 09:26 PM
very confused RS_2002 Brakes, Steering & Suspension 2 02-01-2002 09:31 AM
('93-'01) I need advice... please read... I am very confused.... (kinda long) SubaTubaru Impreza Forum 26 07-25-2001 06:36 AM
