Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 07-31-2003, 03:48 PM   #1
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Default Link PLus users need your advice
My02 RS w/ Link Plus ECU
Total hybrid i won't go into details
Problem: vehicle cranks but will not fire, no spark, no RPM reading on Link Plus. ALl the sensors are hooked up and working. it has a good map loaded into the LInk Plus. It has fuel, just no ignition, all fuses check okay. I did not have my logic tester with me today so i was unable to check to see if the ECU was supplying power to the coil and also switching the ignitor grounds on and off. I will check tommorrow but in the mean time has anyone had these issues.
also for those with connection problems, do NOT use a serial cable with a male/male gender changer, i could not get my laptop to communicate with the link plus for approx 2 hours. While beating my head against the wall i dismantled the Serial link box and plugged it into my serial port and the Link Plus instantly connected.
Thanks for your suggestions in advance.
jeremy
Old 07-31-2003, 09:38 PM   #2
Hondaslayer
Purified Dick
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Jeremy,
I know its kind of a dumb question (and probably been checked) but.
Cam/crank sensors,plugged in?
Coilpack, plugged in?
Old 08-01-2003, 12:38 AM   #3
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default ^My first thought^
Also, what is the link coil settings?
I had my Link switch from wasted spark to single coil on it's own ( a bug in the old software) Not a good thing. All most over heated the coil.
milkman is offline   Reply With Quote
Old 08-01-2003, 12:41 AM   #4
sideways slut
Member#: 21085
2.5 rs-t
hey jeremy, when i first tried to start my car, i had the same problem. i went to the dealership and got the wiring diagram for the ecu and checked every wire( my link wire loom was pre set). i found out that they put the crank and cam sensor wires in the wrong spot( one off, but it made a huge difference). if i were you, id check the wires before you waste too much time and go through too much frustation.
jay
sideways slut is offline   Reply With Quote
Old 08-01-2003, 02:20 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
jay
already did not to mention i ended up breaking the damn pins because they are SOO DAMN FRAGILE
i already checked the wiring for the entire plug and play harness.
Ben: all the sensors are plugged in and connected....any idea if the WRX uses different cam/crank sensors as i have NO clue what the person who put them in used.
Milkman: i will definitely check that tommorrow, thanks for the suggestion. I just ran out of time today before work.
God i want this car to run
Jeremy
Old 08-01-2003, 10:12 AM   #6
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Whats your row settings set to? Is it MAP+TPS? Set everything to MAP including enrichment and do a re-load. Then manually enter the numbers for your timing and fuel. You will need to open two Link sessions and only go online with one. Very tidious but effective in my opinion.
I know your probably like huh but that may solve the problem if everything else is fine.
As far as what milkman said about the coil setup..it should still fire but run like crap..engine very shaky and sounds like a lawnmower
WRC 555 is offline   Reply With Quote
Old 08-01-2003, 10:45 AM   #7
milkman
Member#: 8066
Y2K RSt
Default you must of done that ^
Yes, that's right but not if you fry the coil out.
What's the set up as you know the WRX uses the direct fire coils?
Old 08-01-2003, 11:08 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Default Re: you must of done that ^
it is still using the RS ingition, just WRX heads.
WRC555: everything is set to MAP only.
Time to shower and figure this out.
jeremy
Old 08-01-2003, 11:17 AM   #9
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Did you wire it in yourself or did you get the PnP harness?
Old 08-01-2003, 11:25 AM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
just to let you know the wrx does use different crank and cam sensors than the RS(at least the older RS's and i am assuming new as well), i should know because my legacy does too and thats why i couldnt use the Link plus like the RS-T guys.
Ben
Old 08-01-2003, 11:32 AM   #11
DoctorNick
Member#: 7022
2013 BRZ Limited
Ben
sensor or trigger wheel?(reluctor wheel?)
DoctorNick is online now   Reply With Quote
Old 08-01-2003, 12:52 PM   #12
PHATsuby
Member#: 13617
2001 Legacy GT back
apparently the legacy uses a 2 postion cam sensor, and a high resolution crank sensor which is supposed to be similar to the wrx if not identical. the older 2.5RS uses a 9 position cam sensor and a 6 position crank sensor. i also know that my car uses inductive sensors instead of the halls effect sensor that is the in the RS i believe.
with the autronic ecu i had to get a reluctor interface to change it from a wave to square to mimic the halls effect i believe
Ben
Old 08-01-2003, 12:56 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Ben
your legacy is identical to the RS(at least as far as i know).
It's a 6 tooth crank wheel with 2 teeth offset, the cam sensor has 4 sets of teeth(i can't remember the exact amount of teeth).
so here's the deal
No coil control out of the link, does anyone know if the Link sense RPM based on ignition or based on crankshaft revolution??
what a nightmare.
Jeremy
Old 08-01-2003, 01:01 PM   #14
PHATsuby
Member#: 13617
2001 Legacy GT back
its not identical otherwise i would be using a link plus right now and so would JoeT(he is the first to turbo his 2000 legacy) so he told me all this that he discovered the hard way. but i could very well be wrong on the details but all i know is that it is different.
jeremy since you are a tech i have a question, the subaru engines fire 1,3,4,2 correct? and if so how is the wasted spark separated? on my factory one it is 1+2 together and 3+4 together but someone was trying to tell me that is incorrect even though thats how subaru did it.
thanks
Ben
Old 08-01-2003, 01:14 PM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
1-3-2-4 not the standard 1-3-4-2 that's what gives these cars the offbeat rumble is firing same banks at a time. well that's an interesting tid bit about the legacy, i was under the impression that all of the EJ25 phase 2's had the same ECU's. the JDM legacy's however share the same ignition as the WRX. Did you actually phsyically check to see if it was different?? sorry i am just curious and i can't imagine SOA changing something like that since the 02 has the same ECU and engine harness.
Jeremy
Old 08-01-2003, 02:32 PM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
i have not actually checked it, Joe has graciously given me all this info on it because he had the trouble. he would be the best person to talk to about it. i should note that i am currently trying to get my car started too, but i am confident it will start, a few things must be wired wrong but when i check them it seems like they are correct.
Ben
Old 08-01-2003, 02:46 PM   #17
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
ben i am glad i am not the only one
Jeremy
Old 08-01-2003, 02:54 PM   #18
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I have the pinouts for the stock ecu with the correct diagram to connect to the correct pins on the link plus if you think it would be helpful.
I can scan them this evening i think.
Adam
Drac9 is offline   Reply With Quote
Old 08-01-2003, 02:56 PM   #19
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
so here's the deal
what a nightmare.
Jeremy
Hi Jeremy,
Yeah, I found out the hard way that the Legacy is different from the 2.5RS.
We use the same crank trigger as the WRX and the same cam trigger as the WRX as well. It was a long and arduous process, but my car has been Turbo'd since February of this year and I'm loving it.
Just got my dyno chart in from a Dynapac AWD Dyno vs STI... Muahahahahaha!!! Same day, same dyno, interesting results. (brag)...
Wooohoo!
Good luck in your project, I wish you lots of happiness and success.
JoeT is offline   Reply With Quote
Old 08-01-2003, 04:09 PM   #20
PHATsuby
Member#: 13617
2001 Legacy GT back
hey i didnt hear about these new numbers! sounds awesome!
jeremy, good luck in getting it started, i think i have found my problems after speaking with Joe, wrong crank sensor wiring and we were using different coolant sensors, so i am going to hook up the one like he has and hopefully that will get me going.
keep us updated!
Ben
Old 08-03-2003, 06:31 PM   #21
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Update: Vehicle still won't start, plugged int he stock ecu to verify that i had the wiring correct and the coil fires, plug the link back in and i get nothing.
Any suggestions??
jeremy
Old 08-03-2003, 07:08 PM   #22
DoctorNick
Member#: 7022
2013 BRZ Limited
Any suggestions??
jeremy
tell the moron to buy a wrx
Old 08-03-2003, 09:48 PM   #23
milkman
Member#: 8066
Y2K RSt
Default Ok, then I would say it's the Link jk
It's configured correctly right?
All the pins in the harness are making contact and your sure it wired correctly.
Check the BLUE and BLUE/Black wires off the link too see if they are sending signals to the coil if there not then maybe the Link it's self is fried.
Old 08-03-2003, 10:13 PM   #24
Hondaslayer
Purified Dick
Member#: 4562
1995 Legacy LSi
Jeremy,
Who else is running a Link down there?Maybe try swapping the Link itself?
Old 08-03-2003, 10:21 PM   #25
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Originally posted by hondaslayer
Jeremy,
just did earlier, put the link into a frankensubaru Ej22t swapped L brighton, loaded his map and the car started fine. went and plugged it into the other car and still no spark. wiring is all correct because the ECU even thru the correct error codes when the crank/cam sensors were unplugged during cranking. no erratic signal or weak signal codes and definitely a hot spark.
only thing left is either a bad harness or there are too many teeth on the WRX cam gear
Link 44S Owners need your help! djruslan New England Impreza Club Forum -- NESIC 2 01-15-2007 05:44 AM
LINK / LINK PLUS users quig Engine Management & Tuning 16 10-11-2005 09:20 AM
Link Plus installed , need help omarudy Normally Aspirated with bolt-on Forced Induction Powertrain 8 11-11-2003 08:32 AM
AT&T Wireless users need your input? wrxman555 Off-Topic 16 10-20-2003 11:25 AM
Link Plus users.... EvasionOfTruth Mid Atlantic Impreza Club -- MAIC 7 04-27-2003 06:40 AM
