Closed Thread
Old 07-31-2003, 05:14 PM   #1
Chrisman
Member#: 25706
2005 Legacy
Default Hole in AC condenser
I took my WRX in to the dealer because the AC stopped working. They said it is due to a hole in the condenser. They said that it must have been hit by a rock or something so it is not covered under waranty. Can somebody explain to me where the condenser is so I can take a look at the damage. Does it sound feasable that a rock may have hit the condenser? Can anything else cause it to rupture?
Thanks,
Chris
Chrisman is offline
Old 07-31-2003, 06:21 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The condensor is the thing that looks like a radiator in front of your radiator . It is very likely that it could have been hit by a rock.
Brian
North Ursalia is offline
Old 07-25-2008, 01:31 PM   #3
SP Ambassador
Member#: 180108
2003 WRX Wagon
an a/c condenser is not a huge job either.. im sure it only pays an hour flat and if you are feeling very adventerous you can even take a crack at it yourself!!! I had the exact same problem (big nasty rock found its way in there) some people have had to fix this multiple times and have even resorted to covering their condenser with self-fabbed plastic shields....
gooooood luck
SP Ambassador is offline
Old 07-25-2008, 01:55 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Thanks,
Chris
I hate to tell you but you will end up paying for it. It looks very similar to a radiator but smaller and sits in front of it in direct path of any rocks from the roadways. I have seen rocks damage these before and puncture them.
blackfang is offline
Old 07-25-2008, 02:23 PM   #5
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
gooooood luck
This thread is almost 5 years old.......
Hondaslayer is offline
Old 07-25-2008, 02:58 PM   #6
blackfang
Member#: 131347
2007 Legacy 2.5i SE
I didn't even see the date.
Old 07-28-2008, 04:06 PM   #7
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Also, replacing a condenser is NOT a DIY job unless you have AC training, the equipment to pull a vacuum on the system, and so forth.
armand1 is offline
Old 08-19-2008, 10:43 PM   #8
SP Ambassador
Member#: 180108
2003 WRX Wagon
if he has a hole in his condenser....the system is already empty in most cases...and replacing the condenser yourself would cut down gooberish labor costs....OBVIOUSLY the full job can't be done without an A/C machine to vac and recharge the system...but if this guy takes his car to subaru to get it done (or did 5 years ago when he posted lol) im sure that it would cost a considerable amount more than a simple a/c recharge at joes garage
Old 08-20-2008, 05:02 AM   #9
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
SP - I posted because it's not obvious to many; they may think they can just slap in a condenser and hook up a bottle of refrigerant, or not realize that the receiver/drier needs to be replaced, too, or whatever. As you note, there are certainly many shops that can handle (or complete) the job at cheaper prices than the dealership.
armand1 is offline
Old 08-20-2008, 08:36 AM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Ooooooooooooooooooold
munkis is offline
Closed Thread
fix hole in A/C condenser? gsgleason Pre-2002 Factory Turbo Powertrain 1 06-14-2008 11:32 AM
Stripped thread hole in a/c condenser.. ugh jefersun Texas Impreza Club Forum -- TXIC 6 07-01-2007 12:53 PM
hole in ac line from upgraded intercooler warpspeedwrx Service & Maintenance 7 03-12-2007 09:31 PM
Hole in AC line, Subaru charging too much TheShadowWRX Service & Maintenance 13 04-22-2004 04:25 AM
Hole in AC Line TheShadowWRX Service & Maintenance 3 02-23-2004 01:15 PM
