Old 07-31-2003, 06:14 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default squeaky squeaky
hey
my rs has agx adjustables and eibach pro lowerings springs
when i turn corners it goes squeak squeak
ive heard the wheel bearings are **** in subaru
what do u peeoples think
Old 07-31-2003, 08:29 PM   #2
RawCode
Member#: 3115
2002 Impreza 2.5RS
Maybe CV joints? But they go clunk clunk
Maybe bearings but they generally growl at speed.
Only on corners? Never when hitting bumps at all?
RawCode
RawCode is offline   Reply With Quote
Old 07-31-2003, 09:15 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah going over bumps it does it too sometimes
Old 07-31-2003, 09:23 PM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Maybe the coils in the springs are rubbing each other?
Keiho is offline   Reply With Quote
Old 07-31-2003, 09:46 PM   #5
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
Default Always squeaks
My car ALWAYS squeaks... But I can never pinpoint it, other than it originating from the front of the car. It even does it @ idle.
Can't tell if its the pillow mounts, or something more sinister... I've quite worrying about it though. It will probably freak me out when it stops squeaking!.... Kinda like something that's an recurring odd occurrence, and when it doesn't reciprocate itself, something major is wrong... Or something to that affect.
In the mean time... Just going to enjoy driving the piss out of it.
Chris.
SITTING
RUNNING
The View
HeyChris is offline   Reply With Quote
Old 08-01-2003, 03:11 AM   #6
dRu888
Member#: 8305
2001 2.5RS
Gunmetal
my car used to squeek when going over bumps or when i turned, when I checked out my car turned out one of the endlinks connected to my swaybar was loose
dRu888 is offline   Reply With Quote
Old 08-01-2003, 09:26 AM   #7
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Does it only happen at speed or is it happening while sitting still too? I just installed my Prodrive setup and am getting squeaks when I turn at low speed... I couldn't track it down so I had a friend listen while I turned the wheel parked. We finally figured out that the spring is turning slightly on the spring seat part of the strut! I haven't figured out what I am going to do to fix this, but it might be something helpful to do yourself.
bigdweeb is offline   Reply With Quote
Old 08-01-2003, 05:06 PM   #8
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
hey, my car goes clunk clunk. It's most noticeable when going on a very bumpy road or when I apply the brakes. Could this be my CV joints? If so, what can I do to fix them?
mprezuhguy is offline   Reply With Quote
Old 08-01-2003, 06:07 PM   #9
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
I'm betting its your sway bar endlinks, either front or rear. when the suspension moves the sway bar moves with it and the endlinks are a pivot point. If they are dry or loose (as mentioned) they will squeak. Get some silicon grease and try lubing up the bushings on these peices and see what happens.
Compressed is offline   Reply With Quote
Old 08-03-2003, 12:55 PM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
thanks much gents
Old 08-04-2003, 04:30 AM   #11
squeeks
Member#: 22899
01 GM6 i think
BRP
its me. sorry
squeeks is offline   Reply With Quote
Old 08-04-2003, 01:47 PM   #12
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Stock front struts come with a rubber donut that goes in between the spring and the spring seat on the strut. If you don't transfer this donut when you uprgrade to aftermarket struts and springs they will pop every time you go around a corner or hit a bump.
For the guy who is squeeking at idle: Replace you serpentine belt and see if that helps.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 08-04-2003, 08:42 PM   #13
HeyChris
Member#: 2234
2013 F-XT
Originally posted by MY99 2.5GT
...For the guy who is squeeking at idle: Replace you serpentine belt and see if that helps.
Brad
The odd part about the squeaks, is the rate of the 'squeaking' does not increase with rpm of the engine, or speed of the car.
I have a feeling something was hit very hard, suspension wise, and when the car landed it may have separated some body parts just enough to make them squeak. (There's a road called Kileen Trail off Ortega Hwy, not the best to take a car with tarmac suspension... ]
Probably something I'm just going to have to live with until the car dies.... Or I go deaf.
Old 08-05-2003, 08:39 AM   #14
danci1973
Member#: 19018
1995 Legacy Wagon
My car squeaks too. At idle, standing still and while driving. It only stops when I step on the clutch pedal...
With some help of this forum, I've managed to pinpoint the source of the squeak: the CLUTCH. More precisely, the throw out bearing. I haven't replaced it yet, it doesn't feel that urgent.
D.
danci1973 is offline   Reply With Quote
Squeaky Squeaky Squeaky Squeaky...... upnygimp Off-Topic 20 01-30-2009 01:28 AM
squeaky clutch still squeaky shippy Transmission (AT/MT) & Driveline 1 02-22-2002 01:07 AM
('93-'01) Squeaky Creakies in the right front. enuttage Impreza Forum 2 06-02-2001 12:41 AM
squeaky clutch bados Vancouver Impreza Club Forum -- VIC 2 05-24-2001 12:14 AM
Anyone have a squeaky rear window? It's driving me crazy! ChosenWon General Forum Archive 17 12-29-2000 04:38 PM
