Old 07-31-2003, 06:19 PM   #1
TonyD
Member#: 40980
1996 Impreza
Dark Green
Default Ej18-ej20
I am planning on pulling out the EJ18 in my 96 impreza and dropping in an EJ20T. What all would I need to make this work? Any help would be greatly appreciated. If this would help, I plan on purchasing the block from nippon-motors.com
TonyD is offline   Reply With Quote
Old 07-31-2003, 10:21 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Search around on this forum and read the FAQ. If you still have questions, feel free to ask.
-Jon
Old 08-01-2003, 12:04 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'm currently doing the swap into my 94 Impreza and should have it running by tuesday. I'll be glad to give you some tips once I'm done. First tip is to get all the wiring diagrams. I'm dropping an 02 US WRX engine just to clarify.
Take it easy, Micah
Old 08-01-2003, 12:30 PM   #4
TonyD
Member#: 40980
1996 Impreza
Dark Green
Awesome! Thanks. I was also considering adding an upgrade kit from vishnutuning.com. Anything you can tell me would be a big big big help
Old 08-01-2003, 01:05 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
wellll.....
this is the swap i did
first double your budget
2nd think about engine managment
the engine nippon is selling is an older version of the ej20 the only thing that will work form vishnu is the turbo back exaust
i am currently at about 12k including the car
for the 650+shipping you will get a long block, turbo, manafold, and air to water intercooler.. it leaves a lot to buy..
also a warning noah in salt lake (same engine) had to have his block decked as his engine was not in great shape when he got it
mine is in ok shape but i will probblay rebuild it next year
Old 08-01-2003, 05:32 PM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
where are you guy's getting these ej20's I'm looking to do the same swap in my 94 with a jdm ej20 obd 1 engine I've read a lot of things but a few things I need cleared up about swaps. I'll need a turbo cross memeber? and turbo trannys are a pull type and N/A trannys are a pull time ((or the other way around I dont remember)) soo how would I go about converting that?
scobaru is offline   Reply With Quote
Old 08-01-2003, 06:52 PM   #7
scoobynation
Member#: 40487
well the trannys havent really changed much in the past few years,i dont know if thats a good or bad thing but the thing is you "can" use your tranny you have now cuz most if not all will bolt up to any ej series motor in ex: ej20t motor with ej18 tranny will work.i assume you will be getting a aftermarket clutch to handle some of the extra power...as for the crossmembers,etc......you''ll have to get some wrx parts.
scoobynation is offline   Reply With Quote
Old 08-03-2003, 06:11 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
I'm using an 02 WRX front crossmember and have to use washer for the controll arm mounts but the turbo legacy's sold here have a turbo crossmember that is supposedely a direct swap. I'm trying to use my old tranny and will let you know how it goes. WARNING: Depending on the age of your tranny use the appropriate caution so that your new found doubled power doesn't shread it to pieces!! I'm already looking into getting an STi or MRT gear set.
Take it easy, Micah
Old 08-03-2003, 09:54 PM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I want to use a Sti tranny tho soo thast why I wanna know how to go about converting to a different style clutch
Old 08-03-2003, 11:46 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
You will need the pull-type tranny (turbo transmission), pull-type flywheel and clutch, and the pull-type slave cylinder.
-Jon
Old 08-04-2003, 01:21 PM   #11
TonyD
Member#: 40980
1996 Impreza
Dark Green
Thanks for the help, guys. I really appreciated.
Old 08-20-2003, 02:08 AM   #12
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default clip
u want a WHOLE front clip.
you'll save yourself MAD mony in parts, etc. time too. and u might be able to reuse much of the wiring fromt eh clip. if u have a crazy bodyman friend, or can weld, u could simply do the mechanical and do the RWD swap off the clip, and keep the wiring all JDM
h
supermoose is offline   Reply With Quote
RE:USDM EJ18 swap to EJ22 JDM or JDM EJ18 cbrkp Subaru Conversions 2 12-06-2006 03:07 PM
In which direction is the throttle body on EJ18? tonytiger Normally Aspirated Powertrain 1 03-23-2002 02:57 PM
Will any EJ18 ancillaries fit on a EJ22T? AndrewT Normally Aspirated with bolt-on Forced Induction Powertrain 0 02-19-2002 06:56 PM
ej25 into ej18 L wagon, need help STiShawn Normally Aspirated Powertrain 0 09-10-2001 10:43 AM
Why Swapping an EJ25 with an EJ18 is bad...Comments? SubieKidTK Normally Aspirated Powertrain 20 06-13-2001 06:53 AM
