Old 07-31-2003, 06:39 PM   #1
marioej18
Member#: 31115
2004 saab 9-3 aero
black
Default DOHC vs. SOHC
i was wondering if there are any performance differences between the DOHC ej25 and the SOHC ej25.....
which one is the better engine?
which one is more reliable?
which one is better for more performance, as in, which one is the better engine for getting the most power out of things like headers, ,intakes, cams, exhausts, pulleys, etc....?
marioej18 is offline   Reply With Quote
Old 07-31-2003, 06:43 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
better, the sohc, subaru messed up making the dohc head gasket and/or head assembly, they are notorious for blowing head gaskets
dont know the answer to number 2, but im thinking the sohc, less rebuild time and such
Old 07-31-2003, 07:02 PM   #3
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Lots of what I have heard depends on the mods. I think the DOHC was a lower compression engine which is why it takes to a turbo better then the newer SOHC engines. Aside from that Im not really sure.
JewPac42 is offline   Reply With Quote
Old 07-31-2003, 07:08 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
Power ratings are the same for both motors. Most everyone agrees the later SOHC motors have a better 'area under the curve'.
Julian is offline   Reply With Quote
Old 07-31-2003, 07:28 PM   #5
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Actually, the Phase-2 SOHC engine makes a tiny bit more power - 165hp and 167ft-lbs of torque. If memory serves me correct, the DOHC made 162ft-lbs of torque.
Whatever - the DOHC had a slightly higher rev-limit too!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 08-01-2003, 08:10 AM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Phase I (DOHC) Motor = Notorious for blowing head gaskets due to a miss positioning of the crank mains which allowed the crank to teater slightly, and I mean very slightly. This weakened the gaskets over time. Subaru also recocgnised a problem with the manufacturing of their head gaskets. Simply put they put crappy gaskets in the pre 2000 motors. The DOHC heads are still deemed more tunable by the likes of COBB and old school tuner Mike Shields. 6500rpm redline
Phase II (SOHC) Motor = Made slightly more power and favored by most subaru owners because the fact is its twice as expensive to buy performance cams for the DOHC. 6250 redline
Both of these heads are capable of about 8000 rpm before you really risk float.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 08-01-2003, 09:52 AM   #7
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
unless I'm mistaken, the reason they went to SOHC instead of revising their DOHC design was for performance. in most DOHC 4 cylinder engines, you have 2 camshafts. in the boxer engine, you have 4. they aren't quite half the length of an inline camshaft so you end up with much more rotating mass. on the NA engine, that's not good. with the turbo engine, it's not so much an issue. dial in .01 PSI more boost, and you've overcome the issue. an NA engine is built on maximizing power loss from every place you can.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-01-2003, 11:29 AM   #8
Jademonkey
Member#: 9213
2000 RS
Red
Brad
Unless you have luck like me....
Jademonkey is offline   Reply With Quote
Old 08-01-2003, 11:33 AM   #9
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
I've heard that the EJ25 is good till around 7000 RPMs bone stock. any truth to that?
-IggDawg
Old 08-01-2003, 02:05 PM   #10
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
It seems as though the DOHC is more prone to headgasket failure... but I don't think the cause has been nailed down - I, for one, believe that it was mostly the gasket design/vendor that caused the trouble.
SOHC's have blown HG's too - just not as many/unit sold (I have to concrete data on either...)
I can say this though - the SOHC has ~15ftlbs more torque below 5000rpm than the DOHC. The DOHC has ~10ftlbs more 5200-5700 and ~15ftlbs more from there to redline. I have a dyno from Pat O. but I dopn't know how to post it... and, as stated, the DOHC has a 6450rpm redline
so, "on the boil" the DOHC should edge out the SOHC, but a set of cams on the SOHC will change that. and cams for the dually are 2X the cost of the singles. The SOHC has much better part throttle power/response due to the geometry of the rocker arms vs. shim over bucket of the DOHC.
I have the DOHC in me GT but I think a camed SOHC would be beter (unless I could get cam gears for mine and have it tuned.... that would be cool )
later
chad
Farfrumwork is offline   Reply With Quote
EJ25 DOHC vs SOHC short block questions mattvct Normally Aspirated Powertrain 6 02-17-2009 01:41 PM
dohc vs sohc vs phase I vs phase II spdracr00 Normally Aspirated Powertrain 3 01-23-2006 02:53 PM
RS DOHC vs SOHC heads Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 31 09-12-2005 03:49 PM
Iridium spark plug DOHC vs SOHC Theory yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 9 05-09-2003 07:56 AM
Let's start the DOHC vs SOHC ALL over again ;) jetfreak Normally Aspirated Powertrain 8 03-17-2001 10:31 AM
