Old 07-31-2003, 08:17 PM   #1
Tats
Member#: 5692
WTF? YES! I am
better than you!
Default Plug gap...
What gap should i run with NGK BKR7EVX-11's for an RS-T. I'm running 6psi.
Tats.
Tats is offline   Reply With Quote
Old 07-31-2003, 09:48 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
IIRC, like 32 or 35...
kastle is offline   Reply With Quote
Old 07-31-2003, 10:06 PM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
which wires?
I'm running a .032"
rhdude is offline   Reply With Quote
Old 07-31-2003, 10:08 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
I just bought a set of these for my soon to be RS-T. They come with a .044 gap, that isn't optimal?
lotusTT is offline   Reply With Quote
Old 08-01-2003, 12:09 AM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
.44 is way too much.... needs to be down like .35 - .32. Staying that high will cause blow out of the spark.. the car will sputter
Old 08-01-2003, 11:29 AM   #6
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
The plugs for the EJ25 in an RS are very easy to remove/replace unlike the EJ20 in the WRX, what a PITA! That said, I would suggest you try a few different gaps, not going over .040. You want as big of a gap as you can get w/o blowing out the spark. I am running .040 gap in my RS-T (9 psi) and it is fine about 98% of the time. Once in awhile I would get a misfire during high boost so I may have to reduce the gap a little. The high powered TEC-2 coils may be the reason I can run that big of a gap though....you may find that you'll end up somewhere between .035 -.030 like what has been suggested but you'll never know how big you can go unless you try it out. Good luck!
Boostup! is offline   Reply With Quote
Old 08-03-2003, 06:54 PM   #7
Tats
Member#: 5692
WTF? YES! I am
better than you!
Thanks for the info guys!
BTW....stock wires.
Tats.
Old 08-03-2003, 10:09 PM   #8
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Did you guys actually get sputtering under boost?
I'm curious because I've experimented with all sorts of gaps and plugs and haven't had any spark problems under boost, either at 9.7:1 or 8.5:1 CR. All this on a stock OEM coil pack and stock wires to boot. I've tried platinum plugs, standard copper plugs, and even non-resistor plugs, and have now stuck with standard copper Denso plugs for economy.
-WaC
Wayne
wac is offline   Reply With Quote
Old 08-03-2003, 11:07 PM   #9
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I did @ 13psi on NGK's gapped @ .42 w/ the TEC-II.
Old 08-04-2003, 05:03 PM   #10
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Kastle, too broad a statement . With stock coils and wires then yes, low-mid 30's work best but for upgraded coils (TEC) or with low resistance wires you must increase the gap or you'll jump it too early and miss off boost. My MSD wires (custom built) require a low-mid 40's gap to run well under most conditions. I will try dropping into the upper 30's this fall when temps start to drop and humidity goes up but in 100 deg heat I'm getting away with the larger gap. Oh, and at 13 psi most of us would go boom... YMMV
Old 08-04-2003, 06:56 PM   #11
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Good points there Boy...
Old 08-05-2003, 10:00 AM   #12
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
thank you, sir. Trust me, when I built these wires (a couple of months before the turbo) it took us a week to track down why the car was misfiring at ~3k RPMs/WOT... very frustrating.
Plug Gapping with copper plugs Amazake Engine Management & Tuning 54 01-31-2007 08:45 PM
spark plug gap NGK Iridium plugs? SeaRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-12-2004 10:49 PM
Spark Plug Gap Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-27-2001 01:10 AM
Spark Plug Gap??? Ben Legacy Forum 0 01-28-2001 11:49 AM
Spark Plug Gap SubeDonC General Forum Archive 3 09-08-2000 07:06 PM
