Old 08-01-2003, 08:53 AM   #1
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default "Brake" Light
I noticed last night driving home my "brake" light came on. The "brake" light is normally a signal that the emergency brakes are engaged however I was switching between 1st and 2nd at redline; the light only flashed? However this morning driving to work in 2nd leaving an intersection I noticed the brake like came on by itself and stayed on for a few seconds then went back off? What's so I check because the brake like should not come on unless I have the emergency brakes engaged.
chuglobal is offline   Reply With Quote
Old 08-01-2003, 09:00 AM   #2
TheMadScientist
Member#: 23717
2005 Big red
The brake light will also come on when the brake fluid is low.
I would check that. If the fluid is low most of the time that means that the brake pads are almost shot. Check the fluid if it is low then check the brake pads. If the pads are fine then you probably have a leak some where.
Mark
TheMadScientist is offline   Reply With Quote
Old 08-01-2003, 10:21 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This belongs in the brakes and suspension forum but anyway-
If you do find your fluid is low don't just add more to fill it up. If in fact your pads are worn and you fill the reservoir before installing new pads, it will then overflow when you do change them because of the pistons being pushed back in the calipers.
Old 08-01-2003, 01:48 PM   #4
tekan
Member#: 21079
02 wrx
wrbp
It is also possible that the wire to the ebrake sensor is coming loose. Disconnected=light-on. If you have a turbo timer hooked into the ebrake you may want to double check that.
Just a thought. Hope you get things figured out.
Evan
tekan is offline   Reply With Quote
Old 08-01-2003, 07:18 PM   #5
chuglobal
Member#: 10041
ISM
Default Yo
I never thought low brake fluid would set off the EBrake light. Well I have 50K+ miles on these pads as they are still the factory ones; I think it's time to change them anyways. I was thinking off a loose connection or some short w/ the UTEC or something electronic thus the reason I posted in this forum. I guess it's all a learning experience.
Changed Pads "BRAKE" Light on busygettingthere Brakes, Steering & Suspension 2 07-25-2008 11:15 AM
"brake" light comes on and off at random OneArmedScissor Brakes, Steering & Suspension 5 08-13-2003 10:09 PM
"Brake" light stayed on today WRX-ECE Tri-State Area Forum 8 01-20-2003 06:38 PM
Why is my "BRAKE" light always on!?! The Real Oaf Legacy Forum 5 04-20-2002 01:07 AM
red "Brake" Light on? Imppy Brakes, Steering & Suspension 10 11-29-2001 12:44 AM
