Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 08-01-2003, 11:10 AM   #1
speedmonkee
Vendor
Vendor Sales Rating: (11)
Member#: 35402
03 WRX Vishnu Stg2
01 BMW M5/ 94 Miata FMII
Default New Vendor: SpeedMonkee Performance - SMP
Hello NASIOC members.
Just like to introduce ourselves as the new kid on the block for new alternative Subaru/WRX parts. We offer the same big name vendors too: IHI Turbo, Cobb, & Perrin - to name a few. But we also offer our own innovative products as well:
For starters, we'd like to present our new SMP WRX heatshield for 02-04 MY.
Made of thick 16 ga Stainless Steel. Each part is laser cut and formed to precision so that you will have a flawless - clang free installation in your car. Bolts in with matching supplied stainless hardware for that extra bling factor. These heatshields will protect your engine and IC intake from turbo heat! Our tests have shown at 15-35% drop in temps because of the shielding - which means better protection and performance for your car.
PROTECT your Top Mount intercooler from turbo heat!
$75 in stock and ready to ship.
Also, we'd like to introduce our newest edition to the NASIOC community: SMP Race Radiators. Professionally designed and engineered as a drop in replacement to the stock radiator. Reuses original stock fans. 8.9lbs all aluminum construction made of the best cores the industry has to offer. All welds are hand done and inspected to perfection. Thick single row 38.1mm core will increase cooling efficiency by 40% over the stock version (per manufacturer). Production runs are done in house and take 2 weeks. Next batch is due next week. Contact me for availability as we are in the process of building stock. Please bear with us while we try to catch up with demand!
$475
See our site - check us out. Speedmonkee
Monkeying with Speed!
www.speedmonkee.com
speedmonkee is offline
Old 08-01-2003, 11:16 AM   #2
Safir
Member Sales Rating: (1)
Member#: 3873
. Paradise is
like Disney with hookers
what are the chances of making a radiator to fit the 98-01 RS?
Safir is offline
Old 08-01-2003, 11:22 AM   #3
mizar
Member#: 20293
03 wrx
1820 makes my area tingle
Does your heatshield work on top of the regular stock heatshield as well? or do you have to choose one or the other?
Thanks
looks like a nice piece..
welcome to the board
mizar is offline
Old 08-01-2003, 12:02 PM   #4
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default replies
Safir, you have a PM
Mizar: Thanks for the compliment. The stock shield is removed. The market for our shield is mostly for people who have replaced their downpipes and installed an aftermarket monster down there. This shield will cover almost any DP you could squeeze down there - that doesn't deviate from the initial stock position.
thanks,
Jeremy
Old 08-01-2003, 12:24 PM   #5
516_WRX_V2
Member#: 39016
great products..i'm wondering if i'll benefit from getting the heat shield if i have a FMIC?
516_WRX_V2 is offline
Old 08-01-2003, 12:31 PM   #6
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default Heat Shield
You should still see benefit from a heatshield if you still have a FMIC. Turbo heat will rise and fill your engine compartment. It will reduce stress/heat on your electrical and cooling hoses - and possibly reduce the heat wear on those hoses from prematurely cracking over time.
One thing about a high performance engine. Heat in unwanted places is NOT a GOOD THING! (insert Martha Stewart jokes here)
ok. My .02.
thanks,
jeremy
Old 08-01-2003, 01:17 PM   #7
tekan
Member#: 21079
02 wrx
wrbp
It looks like that heat shield covers the compressor side in the same compartment as the exhaust section. Is this bad, in the sense that it raises temp exposure to the compressor portion?
Is the shield only a plate blocking the side (IC) and top or does it extend around and make more of a closed-in box for the turbo?
Thanks,
Evan
EDIT: I took a look at the pic on the web page and it appears that the compressor portion is left outside the heat shield. This seems good to me!
Other question: does the mounting bolt/washer go through the extra hole (relative to stock) on the IC mounting bracket above the turbo?
tekan is offline
Old 08-01-2003, 01:35 PM   #8
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default Shield
Makes somewhat of a box - but not completely. Covers top and 2 sides. Boxing it in fully doesn't allow for full air flow from the stock/aftermarket hood to circulate & cool shield/components.
Thanks,
Evan
Yes it does mount to a stock location. uses a 6mm Allen bolt with washer - both stainless of course and included.
Jeremy
Old 08-01-2003, 02:18 PM   #9
mizar
Member#: 20293
03 wrx
Im gonna paypal you now for a heatshield..
is the 75$ shipped?
if not let me know what the charges are and I will pay you
Thanks
46410 is you need the zip
mizar is offline
Old 08-01-2003, 03:29 PM   #10
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default Mizar
You have a PM.
thanks for your business!
Jeremy
Old 08-01-2003, 04:10 PM   #11
wrxplode
Member#: 19383
2002 WRX WAG
Would this heat shield get in the way of a bigger after market TMIC? It seems to bolt on to the second hole, which I think some TMIC bolts on to...
wrxplode is offline
Old 08-01-2003, 04:29 PM   #12
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default mount
It bolts into the second hole. It has been fitted onto a car with the TXS Hyperflow TMIC. You just need to supply your own bolt to make it fit (needs to be longer than what we can provide with our kit)
Note on the pic. he dropped his IC so he bent the IC mount tab - why it doesn't fit exactly flush. Its not the heatshield! Just wanted to clarify.
Jeremy
Old 08-01-2003, 07:15 PM   #13
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
The $75 heatshield is all good and well, but I want the CHIMNEY VERSION!!!
PLEASE PLEASE PLEASE let me know when you're coming out with that one. I will buy it from you in a heartbeat.
-Bob
dookiebob is offline
Old 08-01-2003, 08:20 PM   #14
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default Chimney shields
Dookiebob - you stole my thunder.
Just kidding. Yes folks the long awaited chimney version is being finalized this Sunday (we hope!). He is committing to get it done for me and we will shortly have the prototype with pics in my car.
If everything is ok and ( of course we get positive feedback from you guys), we'll go into production.
We will let you know. Sorry for the delays. I know, bad excuse, but these guys are tearing apart a race car that had issues this week - and time is at a premium.
THanks,
Jeremy
Old 08-27-2003, 03:10 PM   #15
03WRXMA
Member Sales Rating: (7)
Member#: 35081
2012 WRX
Any of these left? How much shipped to 01028?
03WRXMA is offline
Old 08-27-2003, 05:00 PM   #16
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default Heat Shield
03WRXMA
These are in stock and ready to ship. Total shipped in $82.50.
Paypal me and it will go out today.
thanks,
Jeremy
Paypal may be addressed to the following:
Credit/debit card: Jeremywo@hotmail.com
Cash/bank acct: Jeremyw@speedmonkee.com
Old 08-27-2003, 05:09 PM   #17
03WRXMA
Member#: 35081
2012 WRX
Thanks Jeremy,
Ill paypal you on friday when I get paid again =)
03WRXMA is offline
Old 08-27-2003, 06:27 PM   #18
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default 03WRXMA
Sounds good. I will be on the look out.
jeremy
Old 08-28-2003, 01:07 PM   #19
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default GC8 rad is in the works
Hey guys,
Good news for RS guys. The GC8 race radiator is in the works. We need 15 to 20 people to get this off the ground for the first production run.
Also, anyone willing to volunteer a radiator for a week, drop me a line. We will need one for fitting and modeling.
As usual, the new GC8 version will be made of Ron Davis Racing tanks and cores - they are second to none! T6-6061 all aluminum construction and hand made in the USA.
Pricing will be about $475 to $500
Old 08-28-2003, 02:01 PM   #20
wrx what
Member#: 19697
2008 WRX STi
I had to remove my stock heatshield with my TurboXS tback... have you tried putting the heatshield on an STi? Does it bolt the same way as a WRX?
wrx what is offline
Old 08-28-2003, 02:19 PM   #21
speedmonkee
Vendor
Member#: 35402
03 WRX Vishnu Stg2
Default STI
We haven't had a customer with an STI to bolt it on. However, as long as the STI uses the same stock bracket, it should fit.
The Hyperflow TXS IC is bigger than the STI iC, so, I don't see any fitment issues otherwise.
jeremy
New Vendor: JoTech Performance is here! Shop info and location... JoTech Performance Vendor Announcements 4 03-08-2010 04:19 PM
Speedmonkee Performance Chimney Heat Shield InfamousDX Car Part Reviews 48 09-09-2004 07:51 PM
Speedmonkee Performance Chimney Heat shield Group Buy speedmonkee Vendor 'Group Buy' Classifieds 67 05-05-2004 12:43 PM
New Vendor: Daddy's Sport Compact Performance Daddy's SCP Vendor 'For Sale' Classifieds 48 08-12-2003 10:00 AM
