08-01-2003, 12:17 PM | #1 |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
kartboy brackets for piaa's on a '02 wagon?
do they fit? do they work? any pics I can see of what they look like?
Jorge (RiftsWRX) www.ProjectWRX.com
08-01-2003, 08:58 PM | #2 |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
well considering the opening in the bumper is the same for the GC8, GDA, and GDB i would not see any reason they wouldnt fit...
08-01-2003, 09:09 PM | #3 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
If you use the same foglights as a sedan it will fit. It's basically a triangle, reuse the 3 factory mounting holes, and then a big hole along the edge for the PIAA/Hella light. All of the install pictures I've seen look different than mine, my hole is on the side edge and others look like they're on the bottom edge. They're also fairly thick, my lights don't shake all over the place even over gravel roads or potholes. I'll try to get a picture up on my yahoo site for you and if you need measurements I can get those for you sometime tomorrow.
08-02-2003, 09:06 PM | #4 |
Member#: 6124
08-03-2003, 12:25 AM | #5 |
Member#: 13634
NESIC
Just uploaded some to my yahoo page, but they're not very big. If you want higher-res photos, send me your email address. Oh yeah, forgot to mention that the brackets are a giant 1/4" thick, pretty sure they're 6061 aluminum. The lights I had there were Hella 500s driving. Definately put some anti-seize on all of the bolts, I've had my lights on since last fall and all of the bolts came out with little effort.
08-04-2003, 10:38 AM | #6 |
Member#: 16495
South East
Vehicle:2017 Impreza Sport Blue |
Jorge,
They work GREAT on my 02 wagon with Hella 500 fogs. The mounting bolt for the 500's is a little bigger than the hole on the KB's. A good drill and bit solved the problem. I used the Hella relay and the factory fog light "on" signal to turn the relay on. The 500's put out much better light, and the PIAA ion H3's have a amber tint that really cuts the fog. Shaun |
08-04-2003, 11:40 AM | #7 | |
Member#: 6124
Jorge (RiftsWRX) www.ProjectWRX.com |
08-04-2003, 12:01 PM | #8 |
Member#: 13634
NESIC
I didn't have my T-square so all I was able to do was eyeball it with my tape measure. But the mounting holes aren't exactly square, anyways I sent you pictures of my bumper cover with the brackets on and off. Let me know if you want more pics, I still have it sort of disassembled.
08-05-2003, 09:47 AM | #9 | |
Member#: 6124
Will these rub on my '02 WAGON? | WRXislander | Tire & Wheel | 7 | 08-26-2007 04:24 PM |
Kartboy brackets for rear 2 pot install | Psychopat | Brakes, Steering & Suspension | 79 | 05-21-2007 09:09 PM |
Install: Brembo Ft Calipers On An '02 Wagon?? | stewgod | Brakes, Steering & Suspension | 3 | 03-25-2007 04:01 AM |
So I bent my control arm on my '02 wagon | kenny08 | Brakes, Steering & Suspension | 12 | 03-17-2005 12:14 PM |
'00 RS parts, fit on a '02 wagon? | Opie | Brakes, Steering & Suspension | 0 | 09-23-2001 10:27 AM |
