Old 04-03-2001, 05:54 AM   #1
efoo
Member#: 80
Post Dyno charts from 2.5L turbos
Well, as promised, here are the dyno charts. Clicking on the picture will yield a high res original scan of the image.
The original scans are blue, and the reduced ones are red. I changed the color of the lines so I could reduce the size and not have the lines dissapear on me.
NOTE: All scans are property of the car owner, so ask permission before copying them.
Edwin's Car, aka efoo
1999 Subaru Impreza 2.5RS
Redline Engineering turbo kit, heavily re-engineered by <a href=http://www.rallispec.com>Rallispec</a>
7 psi of boost
2.5" downpipe and exhaust, one hi-flo cat
Vishnu Performance TEC-II engine management system
Converted to RWD
<a href=http://hesed.mit.edu/~efoo/pix/car/dynocharts/dyno-efoo.jpg>
<img src=http://hesed.mit.edu/~efoo/pix/car/dynocharts/dyno-efoo-red-small.jpg>
</a>
Matt's Car, aka MattC
Minnam Stage II turbo kit
7 psi of boost
3.0" downpipe and exhaust by <a href=http://www.rallispec.com>Rallispec</a>
Converted to FWD
<a href=http://hesed.mit.edu/~efoo/pix/car/dynocharts/dyno-mattc.jpg>
<img src=http://hesed.mit.edu/~efoo/pix/car/dynocharts/dyno-mattc-red-small.jpg>
</a>
Joe's Car, aka himself
2000 Subaru Impreza 2.5RS
10 psi of boost
Built engine (pistons, rods, valves, etc. - ask Joe for details)
Automatic transmission
Converted to FWD
<a href=http://hesed.mit.edu/~efoo/pix/car/dynocharts/dyno-jhogan.jpg>
<img src=http://hesed.mit.edu/~efoo/pix/car/dynocharts/dyno-jhogan-red-small.jpg>
</a>
Enjoy...
-Edwin
efoo is offline   Reply With Quote
Old 04-03-2001, 06:25 AM   #2
Nick
The Godfather
Member#: 2
2015 STI Launch Ed.
Rally Blue Pearl
Post
Thanks Edwin...
Question... what's in the Redline kit exactly? (turbo size mostly)
-Nick
Nick is offline   Reply With Quote
Old 04-03-2001, 06:26 AM   #3
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
Post
Crikey! I've got some work to do on my WRX!
Ginseng is offline   Reply With Quote
Old 04-03-2001, 07:08 AM   #4
efoo
Member#: 80
Post
Hi Nick,
The turbo in my car is a T3/T4 hybrid, just like the Minnam kits. But after driving both cars and looking at the dyno plots, we've come to the conclusion that my turbo must have a slightly smaller compressor wheel, making for less lag. My turbo spools up faster than the Minnam kits, that's for sure. It also holds that boost all the way to redline @ 7psi, so it is likely perfectly sized for 7-8psi. My car feels very balanced at its current boost level and can probably handle another 1-2psi increase before the turbo starts losing efficiency. But it's plenty fast enough for me now, so I'm leaving it where it is and enjoying the car.
The Minnam turbos, on the other hand, do appear to be a bit bigger in terms of compressor wheel sizing. Shiv, MattC, and I feel that those turbos really wake up at 9psi. A couple of unintentional (ahem, Matt!) test runs at 9psi seem to confirm that. Matt's car pulls hard at 9psi. Almost as hard as Joe's 10psi built motor monstrosity, I'd say. Not like my car doesn't pull hard either - a stock WRX has 217 ft/lb peak torque compared to my 244 ft/lbs that come on earlier in the rev range than the WRX. Shiv and I had tons of fun rocketing out of toll booths on my trip home last week.
This just goes to show that saying you have a T3/T4 really means squat unless you take apart the turbo and measure the sizes of the turbine wheels and A/R ratios.
-Edwin
Old 04-03-2001, 07:52 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Edwin, I do believe Shiv confirmed what we had already suspected... you have a Super 60 compressor wheel and everyone else has a T04E.
I'd like to see the spool times for ball-bearing GT series.
ColinL is offline   Reply With Quote
Old 04-03-2001, 09:49 AM   #6
efoo
Member#: 80
Post
Yup, I probably do have a Super 60 wheel in there. I like it this way too so I'm not complaining. All those people claiming that T3/T4s will be too laggy simply have not actually tried it themselves. Even the Minnam turbos are not laggy, at least by looking at the dyno plots.
Colin, I'll be more than happy to try out a GT-25 turbo if you can find me one. Heck, I'll even go through the RWD conversion again if you give it to me. It's too bad that those nice turbochargers are so darn expensive. I personally would like to use a GT-30, I think.
-Edwin
Old 04-03-2001, 11:08 AM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
That wasn't exactly what I had in mind-- but I do know that some members bb Turbonetics units, and a few have Garrett GTs.
They're just not limelight lovers like yourself.
Old 04-03-2001, 11:23 AM   #8
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Question
I have a redline Eng kit too and i have a question myself... what do you mean by heavily re-engineered by rallispec?
when do you see boost efoo? i see boost around 2.8k rpms. is the minnam kit laggier than this? or do u see boost even quicker than 2.8 efoo?
NickSTi is offline   Reply With Quote
Old 04-03-2001, 01:12 PM   #9
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Post
I really appreciate the dyno plot numbers. This gives everyone else here something to go by. I noticed the last dyno run was in mph and not rpms. Why was that? Also, what do stock WRX's have hp wise to the wheels?
It's also interesting to see where the power peek is, even with 7psi of boost. It's right at 5650-5800rpms. Really interesting. No need to raise the rev limiter or shift beyond 6000rpms at all.
This is some great info. Thanks guys!
BTW: I noticed the big hp numbers coming from the autotranny. Way to go!
[This message has been edited by Kevin Thomas (edited April 03, 2001).]
Kevin Thomas is offline   Reply With Quote
Old 04-03-2001, 01:22 PM   #10
Kevin Thomas
Member#: 110
1989 1989 XT6
Lightbulb
Instead of editing my last post, I wanted to make a suggestion to the moderators (If you don't mind Efoo).
Could you make a section at the I-club for dynocharts? This would be a very informative tools for us in the future if we can compare dyno charts. This could be the start of something huge. Of course Efoo, this would have to be with your blessings. Just a suggestion!
Old 04-03-2001, 01:50 PM   #11
Nick
The Godfather
Member#: 2
2015 STI Launch Ed.
Rally Blue Pearl
Post
I think that's a great idea... only one small problem... not that many people actually have dyno plots of their cars... especially considering it's AWD.
Maybe a proof forum though... like for scanned in timeslips/dynoplots/videographed/photographed results.
IE. A picture of the car at the end of the quartermile with the timing light in shot. Same, but video'd.
I am all for a forum with nothing but hard core facts about how the car's perform, my only beef is people tend to exagerate to much without such proof, and it gets sort of annoying sometimes.
-Nick
Old 04-03-2001, 02:05 PM   #12
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Post
Alooooooha
Excellent Numbers..thats just about what I am looking for......How much will the numbers go down with the AWD hooked back up...I know it pretty significant..just wondering about what % to expect...and how much does the Tec add to these figures..
EFOO...what are you doing for gears now...along with MattC...Clutch and so forth...thanks..or Mahalo..
Scooby South
Old 04-03-2001, 02:12 PM   #13
efoo
Member#: 80
Post
well, only one of the charts is mine. you will have to ask MattC and Joe Hogan for permission to use theirs. As for myself, I can talk about it with Alex and Nick offline and see. Contact me via PMs or email.
Joe's chart is in mph because the automatic shifted and kind of messed up the dyno. The rpm chart looked really funny so we ended up using mph instead. He's also got a beefed up motor and is running 10 psi, hence the huge amounts of power.
No one has put a WRX on the dyno yet and posted the plots, so there's no real hard proof. But the published crank hp/torque specs are 227/217 respectively. That's all I have to offer, unless someone volunteers to let me convert their WRX to 2WD and pays for dyno time.
-Edwin
ps: Yup, the power peaks are right at 5600-5800rpm. It follows the stock cams pretty well. You definitely do not need to hit the rev limiter to drive these cars fast.
Old 04-03-2001, 02:17 PM   #14
efoo
Member#: 80
Post
scoobysouth,
I don't think the numbers will go down all that much with the AWD hooked up, at least in my case.. I was in RWD and still spun the rear driveshaft and rear diff, so I had more than 80% of the mobile hardware still active in the car. Only thing I was missing was the front diff and front axles. But then again, there's no hard numbers to back up that assertion, so take it with a grain of salt.
Sorry, there's no "no TEC" and "with TEC" numbers either. I have no desire to hook up piggyback controllers to my car in addition to a TEC-II just to obtain those numbers either. I don't think MattC got a dyno run in while he had piggybacks either.
I'm using a transmission from a JDM Legacy twin-turbo (GTB), and STi clutch/pressure plate. MattC is on a stock trans (his second) and ACT clutch I believe. My transmission is strong, but not unbreakable. I have no desire to find out how much it can take either, so don't ask me.
-Edwin
Old 04-03-2001, 03:06 PM   #15
Kevin Thomas
Member#: 110
1989 1989 XT6
Question
One more question: What is your theory/fact as to why the torque reaches it's peak, falls a bit and climbs again between 3800rpm and 4800rpm?
Old 04-03-2001, 03:16 PM   #16
efoo
Member#: 80
Post
Kevin, that's most likely a small case of overboost, as the boost builds pretty fast. I usually overboost to 8psi for a split second before the wastegate catches up. It's very brief though. The dip you see is magnified by the inertia of the engine and drivetrain.
-Edwin
Old 04-03-2001, 08:58 PM   #17
Blindeye_03
Member#: 4418
2016 Focus ST
Post
I want to turbo my ride SOOOOO BAD...but I am afraid that my heavy driving will ruin the turbo and my motor...I drive alot in heavy traffic (to work) atleast 10miles a day (medium traffic)...
Would someone recommend turboing or staying N/A...
This post belongs here b/c I am getting inspired to turbo mine seeing all the gains you guys are getting! hehe...
Blindeye_03 is offline   Reply With Quote
Old 04-04-2001, 12:18 AM   #18
efoo
Member#: 80
Post
Yup, I know some of those other members with GT turbos. It'd be nice to hear about their experiences too. I for one don't plan to be around much longer either.
NickSTi, the kit was heavily modified by Rallispec in the course of their installation. The turbo has been re-located, the downpipe was completely redone from scratch, the intercooler has braces on it holding it securely to the engine block, the oil drain line was thrown away and a new stainless line with AN fittings substituted, all turbo->intercooler piping redone, and the wastegate mounting location was rotated 90 degrees and plumbed back into the exhaust. there's probably a few other things that I've forgotten about.
I start seeing boost pretty early, like 2600 rpms. the downpipe has a lot to do with it. MattC's experiences between a 2.5" and 3" downpipe confirm that.
-Edwin
Old 04-04-2001, 11:08 AM   #19
Kevin Thomas
Member#: 110
1989 1989 XT6
Question
Sorry for all the questions Efoo.
How did Joe convert his autotranny from AWD to FWD? Did he simply remove the fuse that is in the engine bay, on the passenger side along the firewall? If so, I should've dyno'd this car a long time ago.
Someone else here told me they did this I believe. *Scratching head*
[This message has been edited by Kevin Thomas (edited April 04, 2001).]
Old 04-04-2001, 11:24 AM   #20
RS'ted
Member#: 3234
Post
Blindeye_03,
I drive 70 miles per day in heavy traffic with my turbo'd/TEC-II'd RS. No problems whatsoever with that. It drives stock-like, only faster, _way_ faster
Ken M
RS'ted is offline   Reply With Quote
Old 04-04-2001, 02:37 PM   #21
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Post
Thanks for posting the dyno charts Edwin. I just got back from Virginia International Raceway. I was attending an Audi drivers school. My car performed flawlessly for two days of really hard driveing on VIR's crazy 3.27 mile road course.
Kevin,
Thats all Joe Hogan had to do. He was also fiddling around with some other switch. He was trying to keep the car in low gear, or something
MattC
MattC is offline   Reply With Quote
Old 04-05-2001, 06:04 AM   #22
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
Kevin,
you actually add a 15 amp fuse to that connector on the firewall to convert to FWD. Had to do it last week when I got a flat
Roger
subarurabbit is offline   Reply With Quote
Subaru 2.5L Turbo Wins 2008 International Engine of the Year in 2.0L - 2.5L Category Jon [in CT] News & Rumors 19 05-08-2008 03:52 PM
Road dyno chart from tonight: My 06 WRX cucamelsmd15 Proven Power Bragging 21 12-10-2007 01:52 PM
Dyno charts from today, post 'em up! pleiades South East Region Forum 28 02-14-2005 07:36 AM
Is a 3rd gear dyno chart from an STI useless? Davenow Proven Power Bragging 197 10-23-2004 09:53 PM
dyno charts from 2.5L turbos available efoo Normally Aspirated Powertrain 0 04-03-2001 05:57 AM
