Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 08-01-2003, 06:10 PM   #1
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
Default Spark Plugs
Hey, anyone have any suggestions on spark plugs? What kind should I get, where I should get them. Right now I have Bosch plugs and I guess you're not supposed to use them, so I want to get something better for my car. Any ideas?
mprezuhguy is offline   Reply With Quote
Old 08-01-2003, 06:11 PM   #2
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
For performance the best bet will be some good NGK copper plugs. Not sure of the part # , I will be ordering some soon for my 60K maintenance.
Compressed is offline   Reply With Quote
Old 08-01-2003, 06:24 PM   #3
Yotsuya
Member#: 935
Jack Soo Fan Club
NGK BKR6E-11
You should be able to get them in most auto parts stores; a little under $2.00 each.
Yotsuya is offline   Reply With Quote
Old 08-04-2003, 05:37 AM   #4
squeeks
Member#: 22899
01 GM6 i think
BRP
only advice i have is dont be fooled by all of that platinum and iridium crap. the only benefit you really get from those metals is longer life of the plug, but they typically don't fire as well as copper will.
I use NGK V-power copper plugs. I believe the same ones as Compressed and Yotsuya. So, I third that motion, go with the NGKs
good luck!
-greg
squeeks is offline   Reply With Quote
Old 08-04-2003, 02:32 PM   #5
C17LOAD
Member#: 25488
2005 Impreza WRX STi
"Petter Solberg Edition"
Well, as much as other members seem to think that the Iridiums do nothing, my Denso Iridiums made a noticeable difference in my 2.2. Then again, most people here aren't running 2.2s so maybe thats the difference.
My advice is go for the Denso Iridium Power spark plugs. Check out what the high power cars are using, you'll see alot of them using the Densos.
C17LOAD is offline   Reply With Quote
Old 08-04-2003, 02:49 PM   #6
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
well I ended up with some NGK coppers. Put em in yesterday, they work fine. No noticable difference in anything, which is a good thing. Thanks for your help.
Old 08-04-2003, 07:33 PM   #7
obyone
Member#: 16523
this anymore???
The NGK V-power plugs last pretty long too. I bought my car used with 30K miles and didn't do my first tune up till 2 years later at 60K. When I pulled out the old plugs, they were NGK V-powers not the stock plugs. They were in good shape too.
That means that they were in there for at least 30k miles, and I don't know how much more since the previous owner never told me when he did a tune up.
obyone is offline   Reply With Quote
Old 08-04-2003, 07:39 PM   #8
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
Well I asked the guys in the "Forced Induction" forum about the gap. I should have just asked here. What should I have gapped them at? They came to me pre-gapped at .043, is this right? Or is there some other gar which will increase performance?
Old 08-05-2003, 11:50 AM   #9
lazybastard
Member#: 39387
2002 Impreza 2.5RS
I am doing my forced induction on my RS and was wondering which spark plugs people would reccomend. I know this kinda borders between this thread and Forced Induction threads
lazybastard is offline   Reply With Quote
Old 08-05-2003, 12:16 PM   #10
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
mprez, .043" is fine for stock wires
lazy, coppers are fine for FI... you'll just go through them a little faster. You'll also need to lower your gap to .032-.035.
Old 08-05-2003, 02:41 PM   #11
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
Thanks BOY. What do I change them to if I get bigger wires? If I change them at all.
Old 08-05-2003, 03:00 PM   #12
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
That depends (come on, you didn't think it'd be easy did you ). If you get a high resistance wire (OE replacement, Magnecore, etc) you'll keep the gap the same. If you get a low resistance wire like my custom built MSDs you will need to increase the gap pretty dramatically. IIRC I was running almost .060" before the turbo!!
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 702 02-09-2016 12:08 PM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 04:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 04:05 AM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 12:23 PM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 05:17 AM
