Old 08-01-2003, 05:35 PM   #1
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Default went from vf22 to 18g
So I switched from a VF22 running a max of 20 psi to a 18G running a max of 22.5 psi in 4th gear.
Before the switch I had no knock. Now with the added boost I'm getting some knock and I'm wondering if I should just add fuel and leave the timing map alone?
This turbo can run much more efficient at higher boost levels vs the VF22 so most can run leaner or advance more timing.
But I'm getting knock when I do
*sigh*
I need a wideband
MAD REX is offline   Reply With Quote
Old 08-01-2003, 06:52 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Default Re: went from vf22 to 18g
I think you mean to say:
This turbo can run much more efficient at the SAME boost levels vs the VF22.
You can run better timing at the same boost or the same timing at a little higher boost. 2.5 psi is not a small change, it's totally concevable you have to lower timing.
Where are you getting knock? Are you running out of fuel at high RPM? What are your IDCs? Do you at least have an EGT?
Concillian is offline   Reply With Quote
Old 08-01-2003, 06:57 PM   #3
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Default Re: Re: went from vf22 to 18g
Yes that is what I meant to say
I'm getting knock in the 'knock prone' areas
How would I know if I'm running out of fuel?
IDC's are never above 80 which is pretty normal up here I think
VDO egt probe has fried, need to get a replacement.
Old 08-01-2003, 09:21 PM   #4
JustDSM
Member#: 17502
In the little time I've spent tuning a FP1805H on STi injectors up here, at 22psi your IDC's are much lower than I'm seeing. I put my money on it that your lean. If your timing map was good to go on your VF22 and your running similar boost levels you should be ok. Make sure you rescale your map for 23psi..
JustDSM is offline   Reply With Quote
Old 08-01-2003, 09:57 PM   #5
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Yeah I have already rescaled my utec for the 23.5 psi.
I'm going to just put in .2 of fuel everytime I get knock for now.
Old 08-01-2003, 10:49 PM   #6
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
That's what they claim......
How much more boost are you running? What kind of fuel?
Kevin
Red Rocket is offline   Reply With Quote
Old 08-02-2003, 01:12 AM   #7
JustDSM
Member#: 17502
Kevin
The 18g IS more efficient at higher PR's than the VF22.
Old 08-03-2003, 12:43 AM   #8
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
22-23 psi 93.5 octane
Old 08-04-2003, 07:39 AM   #9
Imprezd
Member#: 3357
Instead of adding fuel in those knock prone areas. I'd take a .5 to 1 degree of timing to see what happens. Some places it's better to run less timing to prevent det. Especially in knock prone areas.
Imprezd~
Imprezd is offline   Reply With Quote
Old 08-04-2003, 05:18 PM   #10
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
Imprezd~
hey imprezd, check your pm's Can you send me the 160 bucks back if your not gonna send the coilovers. Thx
el~sharko is offline   Reply With Quote
Old 08-05-2003, 08:06 AM   #11
Imprezd
Member#: 3357
dude email me...
Old 08-05-2003, 08:33 AM   #12
Austin
Member#: 7089
2016 STi
If you're going to run 23psi on the street, you really should run more than 93 octane.
Austin is offline   Reply With Quote
Old 08-05-2003, 08:46 AM   #13
Z1 Performance
Member#: 9327
Assumng your IPW is in its sweet spot range, Id start lwoeign timing first. You won't be giving up much by dropping timing a degree or two
Z1 Performance is offline   Reply With Quote
Old 08-05-2003, 10:36 AM   #14
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
I'm in denver so the 23 psi is more like 19.5 psi. So not too stressful on the engine.
Old 08-05-2003, 10:55 AM   #15
Imprezd
Member#: 3357
something must be stressing the engine since you are getting detonation.
Old 08-05-2003, 02:57 PM   #16
john banks
Member#: 11669
Evo IX 345 WHP
How about the effect of charge density on dynamic compression ratio and therefore detonation threshold? This may be confounding your expected ability to add spark advance which you expect from lower temperature and lower exhaust manifold pressure/end charge pollution etc.
Some consider that requiring less spark advance is a good thing.
Give the engine the timing it needs and worry about torque not about advance figures.
john banks is offline   Reply With Quote
Old 08-05-2003, 04:10 PM   #17
pace
Member#: 11606
2004 Pilot
1995 Miata
Louis,
Your IDCs are a tad on the low side IMHO. With the 20G pushing 23psig (about 19psia), my IDCs are right around a peak of 90 with the STi injectors. When I moved from the TMIC/VF22 to FMIC/20G, I had to add in up to 4% fuel as well as rescale my timing map.
You will be flowing significantly more air through your motor now (what are your before and after MAF readings?), so expecting to be able to run the same peak timing seems a little unrealistic (in my experience at least).
Also bear in mind that the 18G is well outside of it's sweet spot at 23psig up here (a PR of ~3.2). In his book 'Forced Induction Performance Tuning', Graham Bell notes that when approaching the limits of your available octane, more power is almost always available by backing off on boost and running more aggressive timing, versus the other way 'round.
-Pace
pace is offline   Reply With Quote
Old 08-05-2003, 06:03 PM   #18
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Pace, thanks for the great info.
What are your richest fuel points in the 4500 - 5250 rpm area?
Old 08-05-2003, 08:25 PM   #19
AzSubie
Member#: 19285
2003 Cobra
Pace, how you liking that new combo so far? What FMIC did you end up going with?
AzSubie is offline   Reply With Quote
Old 08-06-2003, 12:11 AM   #20
pace
Member#: 11606
2004 Pilot
1995 Miata
I went the cheap route..
-Pace
Old 08-09-2003, 04:49 AM   #21
GrocMax
Member#: 38292
Gawd I hate the term 'efficiency'. Its the most abused term out there.
Consider this- does compressor 'efficiency' (i.e., 10 or 20 degrees F outlet temp difference) mean diddy-squat with the avg. oversized IC we use?
On paper, yes. In the real world, no.
50F and up, well.............
GrocMax is offline   Reply With Quote
Old 08-09-2003, 02:00 PM   #22
bobsterswrx
Member#: 31555
When I went from vf30 to 18G There was little or no change in my fuel map as verified on the A/F on the dyno. I could actally run 1-2 more psi everything else being equal. But I run a minimum of 50/50 race fuel (95 oct) when I run above 17 psi at 1200 ft elevation. I only run 101 race fuel above 20 psi, better safe than sorry. On race fuel at 22 psi my IDC's are 92 with sti injectors.
Bob
bobsterswrx is offline   Reply With Quote
Guys that Went from APv1 to APv2, did you have to get a retune? TopEndPull AccessPort 3 10-17-2007 03:08 PM
vf22 to 18g tuning question rb22b AccessPort 3 05-19-2007 08:10 PM
Who went from VF34 to 18G? Question... wrxrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-04-2006 08:31 AM
utec tuning - went from vf22 + tmic, to vf22 + fmic + intake LatentWagen Engine Management & Tuning 3 04-11-2005 10:26 PM
ok Gonna do it. Going from vf22 to 18G What to expect? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 12-10-2004 10:03 PM
