Old 08-01-2003, 07:29 PM   #1
quickscooby
Member#: 39415
STI [email protected]
479/492 @ 30psi GT30R .82
Default Advance Ignition Multiplier (0-16)
I was told that i can see this value live with delta dash. Where is it? Cause i can't see it. And which number is the best for performance? And if it isn't at that number what does that mean?
Thanks.
quickscooby is offline   Reply With Quote
Old 08-01-2003, 09:21 PM   #2
JustDSM
Member#: 17502
Not all ECU's support the Advance Mulitiplier.
JustDSM is offline   Reply With Quote
Old 08-01-2003, 09:24 PM   #3
quickscooby
Member#: 39415
How do i get mine to do it?
or how do i tell if mine has it?
Old 08-02-2003, 12:34 AM   #4
quickscooby
Member#: 39415
Anybody?
Old 08-02-2003, 01:14 AM   #5
JustDSM
Member#: 17502
You need to find out what version your ECU is and that will be enough information to find out if you'll be able to have DeltaDash display that data set.
Old 08-02-2003, 09:37 AM   #6
scrat
Member#: 31325
You also need the latest version of Delta Dash. It is the very last variable in the list on the version I downloaded a few weeks ago.
Hope this helps.
Mark
scrat is offline   Reply With Quote
Old 08-02-2003, 09:40 AM   #7
quickscooby
Member#: 39415
My Delta Dash version is 1.36 according to the about feature. As far as my ecu i don't know. All i know is that Vishnu reflashed it and it's dual map capable. Other than that i don't know.
Old 08-02-2003, 11:13 AM   #8
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
The advance multiplier is now available for most 2001/2002 turbo ECUs. Simply download DeltaDash 1.37 Beta 2 or later from the web site.
http://forum.ecutek.com/topic.asp?TOPIC_ID=31
You people with EcuTek products really need to visit the EcuTek forums once a week... I've said this so many times now, I feel like a broken record.
jblaine is offline   Reply With Quote
Old 08-02-2003, 11:16 AM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Oh, and 16 is ideal.
Old 08-02-2003, 10:06 PM   #10
quickscooby
Member#: 39415
I just downloaded the 1.37 update from ecutek. I can now see the advance multiplier and the com ports are visable like usb, modem and such. I was having a connection problem but this seems to have fixed it for now. We'll see.
PowerFC CoPilot 3.0.16 supports EJ20K scooby5 Other Engine Management 7 01-11-2013 10:36 PM
pull/advance ignition timing T20C Open Source Reflashes 2 03-13-2009 03:49 PM
Which is worse? Pats at 18-1 or Lions at 0-16? Snoopy Off-Topic 176 01-23-2009 08:40 AM
Stage 2, wastegate 80% under WOT still 16psi, multiplier 15-16, feels weak treicoaie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 02-13-2006 05:56 PM
Ignition Advance Multiplier question gpatmac Engine Management & Tuning 50 02-28-2004 11:00 AM
