Old 08-01-2003, 07:49 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default drilling valve cover for oil return
i hadnt heard of anyone doing this for their turbo, but my dad suggested it so we wouldnt have to remove the oil pan. he said it would work, but is it safe? what are my options?
Brent
scoobyimprza is offline   Reply With Quote
Old 08-01-2003, 09:06 PM   #2
Avenger
Member#: 1234
You can do that only if the turbo sits higher than the valve cover, but most kits out there the turbo sits about the same level as the valve cover so the oil will not return properly.
Avenger is offline   Reply With Quote
Old 08-01-2003, 11:23 PM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
I had this setup on my car for two years, but the return oil pressurized the valve cover even though the turbo sat higher than the valve cover.
It was not an issue for daily driving, but the return oil pressure and volume sent excessive amounts of oil out of the valve cover breather vent and into the turbo and intercooler during long high-g turns on the track. The oil caused detonation and high oil consumption within a few fast laps on the track.
I recently got the valve cover return port blocked off and the oil return now goes into the oil pan.
-WaC
Wayne
wac is offline   Reply With Quote
Old 08-01-2003, 11:54 PM   #4
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
could that be avoided with a catch can?
Old 08-02-2003, 10:20 PM   #5
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
The hardest part about removing the oil pan is getting to the bolts under the cross-member. Since you're doing a crossmember swap, thank you lucky stars and just stick with the oil pan!
An easy way to get the return to work is to use a bulkhead fitting. I used a 45* -6AN for mine, works great. A few things to note: Pay attention to the pan bolts when selecting a location for the drain. I didn't and the bolt underneath is a bit of a pain to get in. Make sure it clears the engine mount, mine does, but its a little closer than I would have liked...
Just drill a hole and bolt it on. See my location below, I would have liked to mount it another half-inch towards the front of the car (top of picture).
Good luck with the project!
-Brad Weingartner
ChicksDigWagons is offline   Reply With Quote
Old 08-02-2003, 10:23 PM   #6
ChicksDigWagons
Member#: 20508
1998 Red Wagon
Sure, but your catch can would fill up with oil, and oil in a catch can isn't a good as oil in your oil pan.
-Brad Weingartner
Old 08-03-2003, 03:09 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, the point was ade to me about the catch can that if you hook the catch can up with a line to the intake (pre-turbo) you can actually create a vacuum in the crankcase. It may not sound advantagous, but if your oil is backing up in the return line to the pan (like I believe mine is), then it will help out a lot. I am also working my way down through restrictor size for the oil feed to lower the flow some. I am down from the -4AN original diameter of .175" to .110" and I will soon be going down to a .063" restrictor as the .110" doesn't seem to be quite enough. I may try .093" first, but I really don't think that it'll be that big of a difference.
valve cover leaking oil Keif Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-11-2007 10:27 PM
FS MA: SOHC valve cover tapped for oil return, $50 OBO ! IllNastyImpreza 1993 - 2001 Impreza Specific Parts 4 07-11-2007 01:15 PM
SOHC valve cover tapped for oil return $50 OBO IllNastyImpreza Engine/Power/Exhaust 8 07-10-2007 01:14 AM
SOHC valve cover tapped for oil return $50 IllNastyImpreza NESIC Private Classifieds 1 05-13-2007 04:19 PM
Oil Pan, Valve covers for wrx 2.0 Subie-Gc8 Private 'Wanted' Classifieds 7 08-23-2006 08:01 AM
