Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 08-01-2003, 11:31 PM   #1
Brian Broz
Member#: 13783
2008 2.5i Slow
Default Tons of Stupid UTEC Questions from a dumb loser!
Hi everyone,
I am now (finally) a full stage 4 setup with the APS SR40 (catless). My other engine mods are GFB BOV (set to 100% Vent now...just changed from 50/50) and Perrin Foam filter. I am currently running launch control w/fuel cut...but am gonna remove it this weekend. Too many POPS and backfires!!!
I'm the first to admit I'm a real noob, but I get knock on every map I've downloaded. I am running 94 octane, as well. Could it be the ECU adjusting for the STi injectors I put in last weekend?
The TXS base stage 4 map feels kinda slow to spool, but doen't knock as much...I have also used the Stage 4 19psi (closed loop) map for the 1820 (from WRXhackers)...and man it pulls a LOT harder and quicker (what I think the car should feel like)...It's unbelieveable!, but I get knock at 5200-6000 RPM! What is the best way to modify (the latter) map? Turn down the boost with a laptop (the ABC is already a 1/2 turn out) ? Or adjust fuel/timing (don't know what I'm doing!!)
Or is the best to work from the base stage 4 and adjust from there?
Anyone wlse running an SR40 or could help give me some tips, please feel free to comment! Not that it matters, but I have IC hoses and Perrin Shortram coming soon.
Should I try taking off the BOV (or back to 50/50) and take off launch control? Could those be part of the reason? Oh, and no 4Wheel dyno within thousands of miles :-(
Thanks again for any help!
Cheers
Broz
03 WRX Spec R1
TXS Stage 4 SR40
Brian Broz is offline   Reply With Quote
Old 08-01-2003, 11:51 PM   #2
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
not to steal your thread, but what is the "spec R1" model of the WRX?
ScreaminFast is offline   Reply With Quote
Old 08-02-2003, 12:05 AM   #3
Brian Broz
Member#: 13783
2008 2.5i Slow
120Units in Canada. Sonic Yellow limited paint. Both BBS RK17s w/S03s and Stock 16s w/RE92s. SpecR1 badging on rear and interior WOOO...(#21/120) Momo Air Race Shiftknob WOOO..."upgraded audio system"...fog light covers and I think that's it :-)
Once I find a web host I'll post some pics!
Cheers, now back to the topic at hand!!!
Broz
Old 08-02-2003, 01:38 AM   #4
JayC
Member#: 32144
2003 Impreza WRX
Sonic Yellow
My friend in Toronto has #1. Bought it from a dealership in London.
JayC is offline   Reply With Quote
Old 08-02-2003, 12:49 PM   #5
Brian Broz
Member#: 13783
2008 2.5i Slow
bump...anyone?
Old 08-02-2003, 02:43 PM   #6
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Brian,
That particular turbo is very slow spooling but you should try starting with the STG4FMI map (I know you don't an FMI but trust me).
Your other option is to reduce timing at the load sites you knocked in while running the 1820 map. Run data logger #1 and record the knock event at 52-6K. The UTEC will tell you what load site you're in so you can tune out the knock by reducing timing. You may also need to add fuel but you will need at least an egt gauge to determine whether or not you need to add fuel or pull out timing.
Good luck.
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 08-02-2003, 06:05 PM   #7
Brian Broz
Member#: 13783
2008 2.5i Slow
Ok Phil,
Thanks...the FMIC Closed Loop map works great! Much better now!!! (Of course I remembered to change the UTEC to closed loop mode)
It boosts to 15PSI in 1st 2nd and 3rd bang on (with the abc out 1 turn)...is it ok to turn the ABC out a few more turns until I start playing with boost levels on the UTEC? I heard this may be bad (PTFB?)
Also with the SR40 running catless, would you suggest changing the boost gain from 50 down to 42 or so? The car spools quicker with the FMIC map (than stock stg4), but I think it's capable of 15psi by 3600or so (now it's just under or around 4000rpm)
Any tips (from anyone) are appreciated.
Many thanks,
Brian Broz
Old 08-02-2003, 06:17 PM   #8
Mildmanneredman
Member#: 29962
You probably want the abc turned out 2-3 turns. That's what most people have.
Mildmanneredman is offline   Reply With Quote
OK, I'm just dumb...stupid internet question inside. ScubaruImpreza05 Off-Topic 16 04-17-2010 01:56 PM
stupid noob question from a GOONru the real suby dude Interior & Exterior Modification 8 08-11-2009 05:03 PM
Pros/Cons of a WRX. Questions from a newb. prokhy007 Newbies & FAQs 57 09-08-2006 12:48 AM
Stupid DVR question from somebody who knows nothing about them HoRo1 Off-Topic 2 08-20-2006 04:52 PM
A ton of new pics up from Japan supermarkus North West Impreza Club Forum -- NWIC 5 05-26-2005 01:43 AM
