Old 08-02-2003, 02:16 AM   #1
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Exclamation 04 UTEC Knocking!
HELP! im getting some knock with my UTEC, just installed it the other day, when i shift without letting up on the accelerator, it seems like that causes it a bit, but im not sure, im going to do more testing tomorrow, im Stg2 with 93 octane, TBE, Uppipe, Chopped intake silencer...
started today when racing at quaker, dunno, i wanna tune it out, but need help, I have logs!
Help! =(
GMTarkin is offline   Reply With Quote
Old 08-02-2003, 03:43 AM   #2
QweQwe
Member#: 30791
did you order just a standard UTEC with an off the shelf map for the 02/03 WRX's? cuz just a few days back, there was a post on how TurboXS has NOT been able to get all the bugs out for the 04's ECU, other members were knocking as well, and IIRC one person just said "screw it, no UTEC" or something to that effect..
Your best bet is going with COBB Tuning's Access ECU, where they HAVE cracked the 04 Ecu's and should not knock like ur UTEC is doing.. anyone with an 04 Access ECU who can share? I will be getting the 04 WRX within August and would like to kno how it performs
QweQwe is offline   Reply With Quote
Old 08-02-2003, 04:39 AM   #3
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
No need to cross post in the FI forum when you already posted in the engine mgm't and tuning forum I replied in the other thread, just came across it here too..
PaulRex is offline   Reply With Quote
Old 08-02-2003, 01:32 PM   #4
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
The 04 UTEC's are fine an we have tested them on many 04 WRXs. Issues are isolated to specific vehicle's with problems unrealted to the UTEC.
Well if it picks up knock while flat foot shifting then don't or check your log and reduce timing and or add fuel where it's happening.
You may find that it's just clutch chatter or the "banging" of the gears that's causing noise..
Good luck.
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 08-02-2003, 03:30 PM   #5
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
maybe so, i really dont hear the knock though, just see the cel flashing, and the car starts bogging a bit, because of the utec backing off the timing im sure
Old 08-02-2003, 06:20 PM   #6
Tuning Factory Inc.
Vendor
Member#: 3600
I ran into some problems and it was the software. Reload 3.1 software and try stage 2 new. Should solve any issues. I assume you have the rev 6 board.
Tuning Factory Inc. is offline   Reply With Quote
Old 08-03-2003, 02:22 AM   #7
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Yeah, its rev 6, not 3.1t, came with 3.1, i loaded up stg2 new today, no knock since, but my boost is only at factory levels, however, my abc has the fitting turned 2 turns out from flush, why is my boost low? i thought people were seeing like 16psi like that......oh, i may have to set up a dyno tune date when after i move up to michigan, just out of curiousity, what do you charge?
Mysterious 2004 UTEC knock FIXED! GMTarkin Engine Management & Tuning 4 08-20-2003 01:29 AM
04 Utec knocking!! GMTarkin Engine Management & Tuning 7 08-02-2003 04:16 PM
UTEC Knock Sensitivity Settings AaronC Engine Management & Tuning 1 06-24-2003 05:00 PM
UTEC knock correction Big Turkey Engine Management & Tuning 30 05-15-2003 08:29 AM
Utec knock mikaust Engine Management & Tuning 3 12-01-2002 07:53 PM
