#1 |
Member#: 9237
Vehicle:2008 Saab Turbo X 400+ lbft |
HELP! im getting some knock with my UTEC, just installed it the other day, when i shift without letting up on the accelerator, it seems like that causes it a bit, but im not sure, im going to do more testing tomorrow, im Stg2 with 93 octane, TBE, Uppipe, Chopped intake silencer...
started today when racing at quaker, dunno, i wanna tune it out, but need help, I have logs! Help! =( Rev6 Utec with 3.1 software!
#2 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
#1. Don't power shift!!
#2. Please post your log otherwise how can I help you out!! ![]() Are you running the stg.2 93octane base map? Or have you made changes to it? If you have made changes then post it up |
#3 |
Member#: 9237
I am running Stg2 93 octane map, my logs are pretty long, but here goes
RPM TPS MAP MLP MOD AFR KNOCK % psia IGN COUNT Run at the strip 0740 000 -9.4 00 ECU. 17.3 00000 0742 000 -9.4 00 ECU. 17.1 00000 0707 000 -9.4 00 ECU. 16.5 00000 0870 011 -8.3 00 ECU. 16.7 00000 1522 011 -6.7 00 ECU. 14.2 00000 1970 011 -5.1 00 ECU. 16.1 00000 2548 011 -3.6 00 ECU. 14.8 00000 3100 011 -3.6 00 ECU. 14.1 00000 3683 011 -4.5 00 ECU. 13.3 00000 4541 097 -3.8 10 ECU. 15.2 00000 4823 097 -2.4 10 ECU. 13.9 00000 5216 097 +0.6 30 ECU. 14.2 00000 5104 097 +4.9 50 +24.0 14.6 00000 4816 096 +8.2 70 +23.5 14.4 00000 4604 096 +10.8 70 +22.3 14.6 00000 4025 096 +12.3 70 +20.0 14.7 00000 3707 097 +13.1 70 +18.0 13.5 00000 4351 096 +13.1 70 +21.4 15.1 00000 4796 096 +13.1 70 +23.5 14.7 00000 5167 097 +13.1 70 +24.0 14.7 00000 5717 096 +12.5 70 +24.1 rich 00000 6127 097 +12.1 60 +25.0 rich 00000 6666 096 +11.5 60 +25.0 rich 00000 7246 097 +10.8 60 +25.0 rich 00000 6265 096 +10.0 60 +25.0 24.0 00000 4572 097 +10.4 60 +21.8 rich 00000 4516 096 +11.9 80 +14.0 rich 00008 4649 097 +12.5 80 +14.6 rich 00000 4714 097 +13.3 70 +14.9 rich 00000 4894 097 +13.3 70 +23.9 rich 00000 5128 097 +12.9 70 +24.0 13.1 00000 5274 097 +12.7 70 +24.0 rich 00000 5428 096 +12.7 70 +24.0 rich 00000 5564 096 +12.9 70 +24.0 rich 00000 5889 097 +12.7 70 +24.1 rich 00000 6006 097 +13.3 70 +24.6 rich 00000 6127 096 +12.5 70 +25.0 rich 00000 6207 096 +12.7 60 +25.0 rich 00000 6385 097 +11.9 60 +25.0 rich 00000 6447 097 +11.5 60 +25.0 rich 00000 6561 096 +11.0 60 +25.0 rich 00000 6830 096 +10.6 60 +25.0 rich 00000 7168 097 +11.0 60 +25.0 15.7 00000 4748 096 +10.4 60 +22.8 24.2 00000 4938 097 +11.7 60 +24.0 rich 00000 5208 097 +12.5 80 +24.0 rich 00000 5216 097 +12.5 70 +24.0 rich 00000 5265 096 +13.5 70 +24.0 rich 00000 5316 096 +13.1 70 +24.0 rich 00000 5464 097 +12.7 70 +24.0 rich 00000 5491 096 +12.9 70 +24.0 rich 00000 5574 096 +12.7 70 +24.0 rich 00000 5640 097 +13.1 70 +24.0 rich 00000 5737 096 +13.1 70 +24.4 rich 00000 5767 097 +12.9 70 +24.1 rich 00000 5868 097 +13.5 70 +24.3 rich 00000 6016 097 +13.5 80 +24.8 rich 00000 6049 097 +13.3 70 +25.0 rich 00000 6161 096 +13.1 70 +25.0 rich 00000 6172 097 +12.3 60 +25.0 rich 00000 6172 097 +11.7 60 +25.0 rich 00000 6361 097 +11.7 70 +17.0 rich 00003 6706 096 +11.5 70 +17.0 rich 00000 6435 096 +12.1 70 +25.0 rich 00000 6397 096 +12.1 70 +25.0 rich 00000 6422 096 +11.5 60 +25.0 rich 00000 6693 096 +11.7 60 +25.0 rich 00000 7358 097 +11.3 60 +25.0 rich 00000 5878 097 +10.6 60 +24.0 lean 00001 4768 097 +11.0 60 +15.1 rich 00001 4714 096 +12.1 70 +14.9 rich 00000 4830 096 +13.1 80 +15.4 rich 00000 4823 096 +14.7 90 +23.5 rich 00000 4887 096 +15.5 80 +23.6 rich 00000 4859 097 +15.1 80 +23.6 rich 00000 4997 096 +14.7 80 +23.6 rich 00000 4952 095 +14.3 80 +24.0 rich 00000 5073 096 +13.9 70 +23.9 rich 00000 5027 096 +14.3 80 +24.0 rich 00000 5065 096 +14.5 80 +24.0 rich 00000 5096 096 +13.9 80 +24.0 rich 00000 5112 096 +14.7 80 +24.0 rich 00000 5159 097 +14.7 80 +24.0 rich 00000 5184 097 +14.1 80 +24.0 rich 00000 5005 008 +14.1 00 ECU. rich 00000 5096 000 +8.0 00 ECU. rich 00000 5128 000 +1.5 00 ECU. 24.5 00000 5081 000 -4.7 00 ECU. 24.5 00000 5159 000 -10.6 00 ECU. 24.2 00000 5012 000 -11.4 00 ECU. 24.2 00000 5005 000 -11.8 00 ECU. 24.2 00000 Another run 716 000 -10.0 00 ECU. 15.0 00000 0742 000 -10.0 00 ECU. 15.4 00000 0759 000 -9.8 00 ECU. 15.5 00000 0762 000 -9.8 00 ECU. 15.3 00000 0756 000 -10.0 00 ECU. 14.9 00000 0993 078 -8.1 00 ECU. 14.6 00000 1698 062 -6.1 10 ECU. 12.4 00000 2009 031 -4.0 00 ECU. 14.8 00000 2238 032 -2.0 00 ECU. 14.8 00000 2365 016 -2.0 00 ECU. 14.9 00000 2482 019 -2.0 00 ECU. 14.9 00000 2456 010 -2.4 00 ECU. 14.4 00000 2334 011 -2.8 00 ECU. 15.0 00000 2258 011 -2.8 00 ECU. 14.9 00000 2163 010 -3.2 00 ECU. 14.4 00000 2061 010 -3.2 00 ECU. 14.6 00000 1966 008 -3.0 00 ECU. 14.5 00000 1853 008 -3.0 00 ECU. 14.4 00000 1750 007 -3.4 00 ECU. 14.0 00000 1731 000 -4.0 00 ECU. 13.8 00000 1813 000 -5.9 00 ECU. rich 00000 1646 000 -8.1 00 ECU. rich 00000 1505 000 -10.2 00 ECU. rich 00000 1298 000 -11.6 00 ECU. 14.5 00000 1158 000 -11.8 00 ECU. 20.4 00000 0986 000 -11.8 00 ECU. 17.0 00000 0885 000 -11.4 00 ECU. 12.2 00000 0890 000 -11.0 00 ECU. rich 00000 0939 000 -10.8 00 ECU. rich 00000 0972 000 -10.6 00 ECU. rich 00000 0966 000 -10.6 00 ECU. rich 00000 0972 000 -10.6 00 ECU. rich 00000 0952 000 -10.8 00 ECU. rich 00000 0924 000 -10.8 00 ECU. 12.7 00000 0906 000 -11.0 00 ECU. 13.6 00000 0854 000 -10.8 00 ECU. 14.3 00000 0829 000 -10.8 00 ECU. 14.9 00000 0825 000 -10.8 00 ECU. 15.3 00000 0827 000 -10.6 00 ECU. 15.8 00000 0828 000 -10.4 00 ECU. 16.0 00000 0792 000 -10.4 00 ECU. 16.1 00000 0796 000 -10.2 00 ECU. 16.5 00000 0831 000 -10.2 00 ECU. 16.2 00000 0796 000 -10.2 00 ECU. 16.4 00000 0808 000 -10.2 00 ECU. 16.5 00000 0809 000 -10.2 00 ECU. 16.4 00000 0762 000 -10.2 00 ECU. 16.4 00000 0747 000 -10.0 00 ECU. 16.5 00000 0784 000 -10.0 00 ECU. 16.7 00000 0809 000 -10.0 00 ECU. 16.7 00000 0818 000 -10.0 00 ECU. 16.4 00000 0830 000 -10.0 00 ECU. 15.8 00000 0809 000 -10.2 00 ECU. 15.6 00000 0797 000 -10.2 00 ECU. 15.4 00000 0746 000 -10.4 00 ECU. 15.4 00000 0714 000 -10.4 00 ECU. 15.5 00000 0726 000 -10.2 00 ECU. 16.0 00000 0749 000 -10.2 00 ECU. 16.8 00000 0743 000 -10.2 00 ECU. 16.7 00000 0739 000 -10.2 00 ECU. 16.4 00000 0740 004 -10.0 00 ECU. 15.8 00000 1222 020 -7.9 00 ECU. 16.1 00000 1752 020 -5.9 00 ECU. 14.5 00000 2360 019 -3.8 00 ECU. 15.6 00000 3058 018 -2.0 00 ECU. 14.6 00000 3853 017 -2.6 00 ECU. 13.4 00000 4585 014 -3.2 00 ECU. 13.7 00000 5216 014 -4.3 00 ECU. 14.5 00000 5611 008 -5.9 00 ECU. 12.7 00000 5291 005 -7.9 00 ECU. 12.8 00000 4894 004 -9.6 00 ECU. rich 00000 4728 007 -11.0 00 ECU. rich 00000 4782 010 -11.4 00 ECU. 13.3 00000 5012 012 -10.6 00 ECU. 18.2 00000 5341 012 -10.0 00 ECU. 14.1 00000 5678 010 -9.4 00 ECU. 14.1 00000 5385 005 -9.6 00 ECU. 12.5 00000 5128 007 -10.4 00 ECU. 15.5 00000 5249 007 -11.0 00 ECU. rich 00000 5216 007 -11.4 00 ECU. rich 00000 5208 007 -11.6 00 ECU. rich 00000 5291 007 -11.6 00 ECU. rich 00000 5257 007 -11.6 00 ECU. rich 00000 5341 008 -11.6 00 ECU. rich 00000 5282 007 -11.4 00 ECU. rich 00000 5249 002 -11.8 00 ECU. rich 00000 4901 000 -12.2 00 ECU. rich 00000 4528 000 -12.6 00 ECU. rich 00000 4262 005 -12.8 00 ECU. rich 00000 4268 005 -12.4 00 ECU. 12.1 00000 4230 006 -11.8 00 ECU. 15.2 00000 4295 006 -11.2 00 ECU. 16.1 00000 4312 006 -11.2 00 ECU. 15.0 00000 4385 006 -11.2 00 ECU. 14.7 00000 4462 006 -11.0 00 ECU. 14.7 00000 4528 006 -11.2 00 ECU. 14.3 00000 4591 006 -11.0 00 ECU. 14.4 00000 4623 005 -11.0 00 ECU. 13.9 00000 4662 006 -11.2 00 ECU. 14.2 00000 4668 006 -11.2 00 ECU. 14.6 00000 4741 006 -11.2 00 ECU. 14.6 00000 4775 006 -11.4 00 ECU. 14.3 00000 4721 006 -11.4 00 ECU. 14.2 00000 4761 006 -11.6 00 ECU. 14.6 00000 4796 006 -11.6 00 ECU. 14.3 00000 4816 006 -11.6 00 ECU. 14.2 00000 4837 005 -11.6 00 ECU. 14.6 00000 4816 006 -11.6 00 ECU. 14.3 00000 4837 006 -11.6 00 ECU. 14.4 00000 4830 006 -11.6 00 ECU. 14.7 00000 4844 006 -11.8 00 ECU. 14.1 00000 4844 006 -11.6 00 ECU. 14.5 00000 4894 006 -11.6 00 ECU. 14.5 00000 4844 005 -11.6 00 ECU. 14.4 00000 4894 006 -11.8 00 ECU. 14.3 00000 4873 006 -11.8 00 ECU. 14.4 00000 4880 006 -11.8 00 ECU. 14.6 00000 4866 006 -11.8 00 ECU. 14.4 00000 4852 006 -11.6 00 ECU. 14.6 00000 4909 006 -11.8 00 ECU. 14.5 00000 4909 006 -11.8 00 ECU. 14.4 00000 4901 006 -11.6 00 ECU. 14.4 00000 4887 006 -11.8 00 ECU. 14.5 00000 4873 006 -11.8 00 ECU. 14.6 00000 4916 006 -11.6 00 ECU. 14.5 00000 4873 006 -11.8 00 ECU. 14.7 00000 4909 006 -11.6 00 ECU. 14.7 00000 4887 046 -10.8 00 ECU. 13.3 00000 5200 026 -8.5 00 ECU. 12.7 00000 5159 031 -5.5 00 ECU. 14.8 00000 4844 047 -0.8 00 ECU. 13.5 00000 4701 077 +3.5 50 +23.1 13.8 00000 4775 092 +6.8 60 +23.3 12.5 00000 4768 096 +9.4 60 +15.1 14.1 00001 4655 096 +11.0 70 +14.4 13.7 00000 3862 096 +12.1 70 +10.4 14.3 00000 4198 097 +13.5 80 +16.8 14.7 00000 4721 097 +13.7 70 +16.5 15.2 00001 5192 097 +13.5 70 +16.0 14.9 00000 5518 096 +12.9 70 +16.0 rich 00000 5963 096 +12.3 70 +24.7 rich 00000 6289 096 +12.5 70 +25.0 rich 00000 6747 095 +11.5 60 +25.0 rich 00000 7278 096 +11.0 50 +25.0 rich 00000 7002 097 +10.2 60 +25.0 lean 00000 5509 096 +9.2 50 +24.0 lean 00000 4235 096 +10.4 60 +4.8 rich 00002 4492 097 +11.7 80 +5.8 rich 00000 4694 097 +12.7 80 +6.7 rich 00000 5027 096 +13.9 70 +23.9 rich 00000 5035 096 +13.5 70 +16.0 rich 00005 5167 096 +12.9 70 +16.0 rich 00000 5307 096 +12.9 70 +16.0 rich 00000 5482 096 +13.5 80 +24.0 rich 00000 5688 095 +13.5 80 +24.1 rich 00000 5858 096 +13.5 70 +24.4 rich 00000 6006 096 +12.9 70 +25.0 rich 00000 6195 096 +11.9 60 +25.0 rich 00000 6337 095 +11.7 60 +25.0 rich 00000 6497 095 +11.3 70 +25.0 rich 00000 6613 095 +11.0 60 +25.0 rich 00000 6693 095 +11.0 60 +25.0 rich 00000 7199 095 +10.2 50 +25.0 rich 00000 6734 097 +9.8 50 +25.0 lean 00000 4748 096 +9.8 60 +16.9 13.5 00013 4952 096 +11.0 70 +15.8 rich 00000 5050 095 +12.1 80 +16.0 rich 00000 5216 096 +13.7 80 +16.0 rich 00000 5208 096 +14.5 80 +16.0 rich 00001 5402 096 +14.5 80 +16.0 rich 00000 5324 096 +14.5 80 +16.0 rich 00000 5402 096 +14.1 80 +24.0 rich 00000 5500 095 +14.1 80 +24.0 rich 00000 5509 095 +13.9 70 +24.0 rich 00000 5668 096 +13.9 70 +24.0 rich 00000 5878 096 +14.1 80 +24.0 rich 00000 5858 095 +13.9 80 +16.2 rich 00001 5858 095 +14.1 70 +16.3 rich 00000 5910 096 +14.3 80 +16.7 12.8 00000 6016 096 +12.9 70 +24.8 rich 00000 6105 095 +12.5 60 +25.0 rich 00000 6150 096 +12.1 70 +25.0 rich 00000 6207 096 +11.9 70 +25.0 rich 00000 6301 096 +12.1 70 +25.0 rich 00001 6349 096 +12.3 60 +17.0 rich 00001 6385 095 +12.7 70 +17.0 rich 00000 6459 096 +11.9 70 +25.0 rich 00000 6459 096 +12.1 60 +25.0 rich 00000 6693 096 +11.9 60 +25.0 rich 00000 6587 096 +11.5 70 +25.0 rich 00000 7358 096 +11.9 70 +25.0 rich 00000 6872 097 +11.7 60 +25.0 lean 00000 4837 095 +11.3 60 +14.8 13.2 00008 4688 095 +11.9 70 +15.0 rich 00000 4837 096 +12.7 80 +15.4 rich 00000 4789 096 +13.3 80 +23.5 rich 00000 4909 096 +14.5 80 +23.5 rich 00000 4923 096 +14.3 80 +23.4 rich 00000 4938 096 +13.9 70 +17.6 rich 00003 4938 096 +13.9 80 +15.8 rich 00000 4967 095 +13.7 80 +15.8 rich 00000 4982 096 +14.1 80 +16.0 rich 00000 5128 095 +14.5 80 +24.0 rich 00000 4990 096 +14.7 80 +16.0 rich 00002 5128 096 +14.9 80 +16.0 rich 00000 5104 096 +14.9 80 +16.0 rich 00000 5144 096 +13.9 70 +24.0 rich 00000 5167 096 +13.3 70 +24.0 rich 00000 5224 095 +13.3 70 +24.0 rich 00000 5249 096 +13.3 80 +24.0 rich 00000 5184 095 +13.7 80 +24.0 rich 00000 5299 096 +14.3 80 +24.0 rich 00000 5291 095 +14.1 80 +20.0 rich 00002 5367 096 +14.5 80 +16.0 rich 00002 5324 096 +14.1 80 +16.0 rich 00000 5385 095 +13.9 70 +24.0 rich 00000 5437 096 +13.7 70 +24.0 rich 00000 5341 096 +14.1 80 +24.0 rich 00000 5411 095 +14.5 80 +24.0 rich 00000 5437 096 +15.3 80 +24.0 rich 00000 5509 095 +15.3 80 +24.0 12.9 00000 5500 095 +14.5 70 +24.0 rich 00000 5527 096 +14.3 80 +24.0 rich 00000 5350 002 +13.1 00 ECU. rich 00001 5491 000 +7.6 00 ECU. rich 00000 5411 000 +1.3 00 ECU. 20.6 00000 5341 000 -5.3 00 ECU. 24.5 00000 5232 000 -10.8 00 ECU. 24.0 00000 5151 000 -11.6 00 ECU. 24.2 00000 5081 000 -11.8 00 ECU. 24.5 00000 5005 000 -12.0 00 ECU. 24.0 00000 4990 000 -12.2 00 ECU. 24.2 00000 4873 000 -12.4 00 ECU. 24.2 00000 4930 000 -12.4 00 ECU. 24.5 00000 4741 000 -12.4 00 ECU. 24.0 00000 4694 000 -12.6 00 ECU. 24.0 00000 4708 000 -12.4 00 ECU. 24.2 00000 4541 000 -12.6 00 ECU. 24.2 00000 4462 000 -12.4 00 ECU. 24.0 00000 4409 000 -12.6 00 ECU. 24.2 00000 4323 000 -12.8 00 ECU. 24.5 00000 4224 000 -12.8 00 ECU. 24.2 00000 4177 000 -13.0 00 ECU. 24.0 00000 4151 000 -13.0 00 ECU. 24.0 00000 4065 000 -13.0 00 ECU. 24.0 00000 4016 000 -13.0 00 ECU. 23.7 00000 3996 000 -13.0 00 ECU. 23.7 00000 3935 000 -12.8 00 ECU. 23.7 00000 3894 000 -12.8 00 ECU. 24.2 00000 3840 000 -13.0 00 ECU. 24.0 00000 3792 000 -13.0 00 ECU. 24.2 00000 3762 000 -13.0 00 ECU. 24.0 00000 3703 000 -13.0 00 ECU. 24.0 00000 3654 000 -13.0 00 ECU. 24.0 00000 3623 000 -13.0 00 ECU. 24.2 00000 3561 000 -13.0 00 ECU. 23.7 00000 3531 000 -12.8 00 ECU. 24.2 00000 3486 000 -12.8 00 ECU. 24.0 00000 3404 000 -13.0 00 ECU. 24.2 00000 3411 000 -12.8 00 ECU. 24.0 00000 3323 000 -12.8 00 ECU. 24.2 00000 3226 000 -12.8 00 ECU. 24.0 00000 3195 000 -12.8 00 ECU. 24.2 00000 3126 000 -12.8 00 ECU. 24.2 00000 3069 000 -12.8 00 ECU. 24.0 00000 3019 000 -12.8 00 ECU. 24.0 00000 2962 000 -12.8 00 ECU. 24.0 00000 2898 000 -13.0 00 ECU. 24.0 00000 more on post 2 |
#4 |
Member#: 9237
On the ride home
2798 008 -4.7 00 ECU. 14.1 00000 2871 006 -5.1 00 ECU. 13.7 00000 2908 005 -5.9 00 ECU. 14.1 00000 2970 004 -6.5 00 ECU. 14.6 00000 3019 003 -7.3 00 ECU. 14.8 00000 3052 002 -7.9 00 ECU. 14.9 00000 3118 002 -8.7 00 ECU. 15.2 00000 3159 002 -9.4 00 ECU. 14.9 00000 3198 002 -9.8 00 ECU. 14.4 00000 3223 001 -10.0 00 ECU. 14.0 00000 3264 002 -10.2 00 ECU. 14.1 00000 3316 002 -10.2 00 ECU. 14.7 00000 3326 002 -10.2 00 ECU. 14.7 00000 3408 001 -10.4 00 ECU. 14.4 00000 3408 001 -10.6 00 ECU. 14.3 00000 3425 000 -10.8 00 ECU. 14.3 00000 3486 000 -11.0 00 ECU. 12.9 00000 3483 000 -11.4 00 ECU. 12.7 00000 3523 000 -11.8 00 ECU. 12.0 00000 3519 000 -11.8 00 ECU. rich 00000 3534 000 -12.0 00 ECU. rich 00000 3576 000 -12.2 00 ECU. rich 00000 3580 000 -12.2 00 ECU. rich 00000 3584 000 -12.4 00 ECU. rich 00000 3603 000 -12.6 00 ECU. rich 00000 3635 000 -12.8 00 ECU. rich 00000 3650 000 -12.8 00 ECU. rich 00000 3639 000 -12.6 00 ECU. rich 00000 3658 000 -12.6 00 ECU. rich 00000 3703 000 -12.6 00 ECU. rich 00000 3667 000 -12.6 00 ECU. rich 00000 3703 000 -12.8 00 ECU. rich 00000 3720 000 -12.8 00 ECU. 15.4 00000 3732 000 -13.0 00 ECU. 24.0 00000 3711 000 -13.0 00 ECU. 24.0 00000 3732 000 -13.0 00 ECU. 23.7 00000 3728 000 -13.0 00 ECU. 23.7 00000 3745 000 -12.8 00 ECU. 24.0 00000 3749 000 -12.8 00 ECU. 23.7 00000 3732 000 -12.8 00 ECU. 23.7 00000 3753 000 -12.6 00 ECU. 22.7 00000 3753 000 -12.6 00 ECU. rich 00000 3779 000 -12.4 00 ECU. rich 00000 3835 000 -12.4 00 ECU. 12.1 00000 3831 000 -12.0 00 ECU. 13.4 00000 3858 000 -12.0 00 ECU. 13.9 00000 3875 000 -12.0 00 ECU. 13.3 00000 3889 000 -12.0 00 ECU. 14.1 00000 3916 000 -12.0 00 ECU. 14.1 00000 3944 000 -11.8 00 ECU. 14.0 00000 3954 000 -11.8 00 ECU. 13.9 00000 3987 000 -12.0 00 ECU. 14.3 00000 3972 000 -12.2 00 ECU. 14.0 00000 4020 000 -12.2 00 ECU. 14.1 00000 4011 001 -12.2 00 ECU. 14.1 00000 3996 003 -12.0 00 ECU. 15.1 00000 4105 005 -11.6 00 ECU. 17.6 00000 4050 005 -11.0 00 ECU. 14.3 00000 4100 005 -10.4 00 ECU. 13.7 00000 4156 006 -10.0 00 ECU. 13.3 00000 4198 006 -9.8 00 ECU. 13.5 00000 4235 007 -9.6 00 ECU. 13.5 00000 4251 007 -9.4 00 ECU. 13.5 00000 4284 007 -9.1 00 ECU. 14.4 00000 4329 007 -8.9 00 ECU. 14.4 00000 4317 008 -8.5 00 ECU. 14.6 00000 4391 007 -8.3 00 ECU. 14.7 00000 4432 007 -8.3 00 ECU. 14.2 00000 4438 005 -8.5 00 ECU. 13.8 00000 4450 004 -8.9 00 ECU. 13.7 00000 4480 003 -9.6 00 ECU. 12.1 00000 4510 003 -10.2 00 ECU. 12.5 00000 4492 003 -10.6 00 ECU. 13.8 00000 4510 003 -10.8 00 ECU. 14.7 00000 4522 002 -11.0 00 ECU. 14.8 00000 4535 000 -11.2 00 ECU. 12.2 00000 4415 000 -11.6 00 ECU. rich 00000 4486 000 -12.0 00 ECU. rich 00000 4432 000 -12.2 00 ECU. rich 00000 4420 000 -12.2 00 ECU. rich 00000 4397 000 -12.4 00 ECU. rich 00000 4385 000 -12.4 00 ECU. rich 00000 4329 000 -12.4 00 ECU. rich 00000 4345 001 -12.4 00 ECU. rich 00000 4345 002 -12.2 00 ECU. rich 00000 4306 004 -11.8 00 ECU. 14.3 00000 4462 013 -11.2 00 ECU. 16.7 00000 4498 042 -8.7 00 ECU. 17.6 00000 4528 083 -5.5 10 ECU. 13.7 00000 4636 085 -1.0 30 ECU. 13.5 00000 4909 087 +4.7 60 +23.6 13.8 00000 5136 087 +9.0 70 +24.0 13.8 00000 5241 089 +11.3 70 +24.0 13.8 00000 5491 093 +12.7 60 +24.0 rich 00000 5546 094 +12.7 70 +24.0 rich 00000 5707 092 +12.1 70 +24.0 rich 00000 5984 092 +12.3 70 +25.0 rich 00000 6038 088 +11.9 60 +25.0 rich 00000 5952 000 +7.8 00 ECU. rich 00000 5640 000 +2.1 00 ECU. rich 00000 5307 086 -0.6 10 ECU. rich 00000 4363 087 -0.2 40 +21.5 rich 00000 4498 087 +4.5 80 +16.2 rich 00001 4681 088 +10.8 80 +14.6 rich 00001 4714 042 +13.9 00 ECU. rich 00000 4541 000 +9.0 00 ECU. 14.0 00000 4214 000 +2.7 00 ECU. lean 00000 3935 000 -3.2 00 ECU. 24.2 00000 3627 000 -8.9 00 ECU. 24.0 00000 3217 000 -9.6 00 ECU. 24.0 00000 3223 000 -9.6 00 ECU. 24.0 00000 3236 000 -9.8 00 ECU. 23.7 00000 3261 000 -10.0 00 ECU. 24.0 00000 3223 000 -10.4 00 ECU. 24.2 00000 3217 000 -11.0 00 ECU. 24.0 00000 3192 000 -11.6 00 ECU. 24.2 00000 3189 000 -12.0 00 ECU. 24.0 00000 3150 000 -12.4 00 ECU. 24.2 00000 3147 000 -12.4 00 ECU. 24.0 00000 3121 000 -12.6 00 ECU. 24.0 00000 3126 000 -12.6 00 ECU. 24.5 00000 3095 000 -12.6 00 ECU. 24.2 00000 3092 000 -12.6 00 ECU. 24.2 00000 3072 000 -12.6 00 ECU. 24.0 00000 3066 000 -12.6 00 ECU. 23.7 00000 3041 000 -12.8 00 ECU. 24.2 00000 3022 000 -12.8 00 ECU. 24.2 00000 3046 000 -12.8 00 ECU. 24.0 00000 3030 000 -12.8 00 ECU. 24.0 00000 3013 000 -12.8 00 ECU. 24.0 00000 3003 000 -13.0 00 ECU. 23.7 00000 2989 000 -13.0 00 ECU. 24.0 00000 2955 000 -13.0 00 ECU. 24.2 00000 2942 000 -12.8 00 ECU. 24.2 00000 2934 000 -12.8 00 ECU. 24.2 00000 2926 000 -12.8 00 ECU. 24.0 00000 2918 000 -12.8 00 ECU. 23.7 00000 2921 000 -12.8 00 ECU. 23.7 00000 2944 002 -12.4 00 ECU. 19.2 00000 2873 002 -11.8 00 ECU. 14.2 00000 More on the way home 2866 004 -9.8 00 ECU. 13.7 00000 2881 004 -9.4 00 ECU. 14.1 00000 2896 005 -8.9 00 ECU. 14.6 00000 2906 006 -8.7 00 ECU. 14.6 00000 2929 008 -8.3 00 ECU. 14.4 00000 2957 030 -7.1 00 ECU. 15.2 00000 3019 081 -4.7 10 ECU. 14.5 00000 3041 084 -1.4 20 ECU. 14.2 00000 3118 085 +1.9 30 ECU. 14.4 00000 3180 086 +5.3 50 +18.0 14.1 00000 3297 086 +8.6 70 +18.0 14.3 00000 3425 087 +11.5 80 +18.0 14.8 00000 3450 087 +13.7 80 +18.0 14.5 00000 3595 086 +15.1 80 +18.0 14.7 00000 3703 086 +14.9 80 +18.0 14.7 00000 3707 086 +15.1 80 +18.0 14.7 00000 3827 086 +15.1 90 +18.4 14.5 00000 3916 086 +15.1 80 +19.6 14.7 00000 4035 086 +15.7 80 +20.0 14.6 00000 4120 086 +15.5 80 +20.5 14.7 00000 4224 086 +15.1 80 +20.9 14.7 00000 4317 086 +14.5 70 +21.2 14.0 00000 4409 086 +14.5 80 +21.5 rich 00000 4492 086 +14.5 80 +14.0 rich 00007 4629 086 +14.3 80 +14.4 rich 00000 4675 086 +14.7 80 +14.7 rich 00000 4748 086 +15.1 80 +23.1 rich 00000 4810 072 +14.7 80 +23.4 rich 00000 4741 000 +10.0 00 ECU. rich 00000 4426 000 +3.7 00 ECU. 24.5 00000 4110 000 -2.8 00 ECU. 23.7 00000 3849 000 -8.9 00 ECU. 23.7 00000 3255 000 -9.8 00 ECU. 24.2 00000 3346 000 -9.8 00 ECU. 24.0 00000 3330 000 -9.6 00 ECU. 24.0 00000 3320 000 -9.8 00 ECU. 24.0 00000 3297 000 -10.2 00 ECU. 24.0 00000 Even more... 3703 014 -6.1 00 ECU. 14.3 00000 3775 017 -4.0 00 ECU. 14.2 00000 3792 020 -2.0 00 ECU. 14.7 00000 3849 020 +0.4 00 ECU. 14.6 00000 3875 021 +2.7 00 ECU. 14.4 00000 3949 071 +5.3 50 +19.4 14.8 00000 3987 082 +7.6 60 +19.8 13.3 00000 4084 082 +10.0 70 +20.5 14.2 00000 4192 083 +12.3 80 +20.7 15.0 00000 4273 083 +13.5 80 +21.1 14.9 00000 4329 083 +14.7 80 +21.4 14.9 00000 4426 083 +14.7 80 +21.7 14.6 00000 4522 083 +14.5 80 +21.9 14.8 00000 4566 082 +14.7 80 +22.3 14.5 00000 4688 082 +14.1 80 +23.1 14.5 00000 4714 083 +14.1 70 +15.0 14.8 00004 4775 083 +14.1 80 +15.1 14.7 00000 4887 082 +14.1 80 +15.4 14.4 00000 4923 083 +14.3 80 +24.0 rich 00000 5128 083 +14.9 80 +24.0 rich 00000 5192 082 +14.3 80 +24.0 rich 00000 5274 083 +13.7 70 +24.0 rich 00000 5274 058 +14.1 00 ECU. rich 00000 5042 000 +8.2 00 ECU. rich 00000 4803 000 +2.3 00 ECU. 14.6 00000 3858 069 -2.2 10 ECU. lean 00000 3576 084 -4.9 10 ECU. 17.6 00000 3831 084 -0.6 40 +18.8 18.2 00000 more more 4089 083 +15.7 80 +20.4 14.7 00000 4125 083 +15.7 90 +20.6 14.7 00000 4203 083 +15.5 80 +20.6 14.9 00000 4214 083 +15.9 80 +20.9 rich 00000 4268 083 +15.7 90 +20.8 rich 00000 4301 083 +15.5 80 +21.1 rich 00000 4246 082 +15.9 80 +13.1 rich 00001 4357 082 +15.5 80 +13.2 rich 00000 4340 082 +15.5 80 +13.3 rich 00000 4432 082 +15.7 80 +13.6 rich 00000 4450 083 +15.5 80 +14.4 rich 00020 4420 082 +15.7 80 +13.9 rich 00000 4432 000 +13.7 00 ECU. rich 00000 4403 000 +7.6 00 ECU. 15.0 00000 4426 000 +1.5 00 ECU. lean 00000 4357 000 -5.3 00 ECU. 24.0 00000 4374 000 -9.8 00 ECU. 24.2 00000 4334 000 -10.6 00 ECU. 24.2 00000 4391 000 -11.2 00 ECU. 24.2 00000 I was pretty much trying to push it on the way home to see if it would knock, sure enough, it did...just wanted to make some logs, yah know.. Oh, I turned it to closed boost, and my boost dramatically decreased, and i didnt touch it, no knock on the rest of the way home from that, but once i turned it to factory levels, it started again, so i dont know =( |
#5 |
Member#: 5094
Vehicle:2002 11.96, 1.64, 115mph! |
Try the STG2NEW program and this should fix you up.
Thanks, Phil TurboXS |
#6 |
Member#: 9237
Im running 93 octane though, seems like it knocks in 3rd at 5200 and in 4th at 4500....
I also noticed its more prone to knock with the AC on |
#7 | |
Member#: 4980
-Nathan www.turboxs.com |
#8 |
Member#: 9237
Oh, i will take it, but im just sayin...
| Thread Tools | |
| Display Modes | |
| Mysterious 2004 UTEC knock FIXED! | GMTarkin | Engine Management & Tuning | 4 | 08-20-2003 01:29 AM |
| 04 UTEC Knocking! | GMTarkin | Factory 2.0L Turbo Powertrain | 6 | 08-03-2003 02:22 AM |
| UTEC Knock Sensitivity Settings | AaronC | Engine Management & Tuning | 1 | 06-24-2003 05:00 PM |
| UTEC knock correction | Big Turkey | Engine Management & Tuning | 30 | 05-15-2003 08:29 AM |
| Utec knock | mikaust | Engine Management & Tuning | 3 | 12-01-2002 07:53 PM |
